    PID Tuning Procedure
    2.8k
    • CarlBossonundefined
      CarlBosson @stuartofmt
      @stuartofmt
      Do I just copy and past the code
      into a new Macro in the User interface?
      stuartofmtundefined 1 Reply Last reply Reply Quote 0
      • stuartofmtundefined
        stuartofmt @CarlBosson
        @CarlBosson said in PID Tuning Procedure:
        @stuartofmt
        No, that would be a bad idea as the PID tuning parameters (in the first macro) depend a lot on your printer.
        I offered up the macro as a way of assisting in understanding some of the parameters, assuming you may have been familiar with running macros.
        Can you descibe your machine ? From the config file it looks to have two different hotend heaters (H1 and H2) and a bed heater (H0) ? If so, how do you switch between the two different hotends?
        Also - it looks like you may be running old versions of the firmware and DWC - can you comfirm by posting the output of M122
        CarlBossonundefined 2 Replies Last reply Reply Quote 0
          @stuartofmt said in PID Tuning Procedure:
          This is a custom Machine. It used to be a Folger Tech FT-5 large volume printer 300mm X 300mm X 300mm. The only thing original now is a few stepper motors and the frame. We are running the Duet E3D mother board and E3D Titan Aqua extruder. There is a 110Vac heated bed controlled by the use of an SSR. This also has a custom built enclosure and heaters controlled by an externally mounted din rail Watlow controller. Early on I tried to use the Duet to control the chamber heaters but I ran out of time. I may come back to this.
          There should only be two heaters. The hot end and the heated bed. If there are more, then this might be a hold over from the chamber heating attempt.
          I am sure I have not upgraded the firmware since the original install so I am sure it is old.
          I had never seen a 3D Printer when I was tasked too build this one, and now have a few Enders at home to learn on. I could use some help making this printer what I know it can be.
          I will get you the M122 next.
          Carl
            @stuartofmt
            SENDING:M122
            RepRapFirmware for Duet 2 WiFi/Ethernet version 2.05.1 running on Duet WiFi 1.02 or later
            Board ID: 08DGM-917DA-G4MSD-6J1FA-3SJ6N-T8T39
            Used output buffers: 1 of 24 (13 max)
            Static ram: 25712
            Dynamic ram: 93344 of which 484 recycled
            Exception stack ram used: 496
            Never used ram: 11036
            Tasks: NETWORK(ready,628) HEAT(blocked,720) MAIN(running,3760) IDLE(ready,160)
            Owned mutexes:
            Last reset 05:04:57 ago, cause: power up
            Last software reset at 2023-06-16 10:27, reason: User, spinning module GCodes, available RAM 11592 bytes (slot 2)
            Error status: 10
            [ERROR] Error status: 10
            Free file entries: 10
            SD card longest block write time: 504.0ms, max retries 0
            MCU temperature: min 26.7, current 44.1, max 48.3
            Supply voltage: min 0.9, current 24.6, max 24.8, under voltage events: 2, over voltage events: 0, power good: yes
            Driver 0: standstill, SG min/max 0/361
            Driver 1: standstill, SG min/max 0/232
            Driver 3: standstill, SG min/max 0/1023
            Date/time: 2024-02-20 15:37:13
            Slowest loop: 47.05ms; fastest: 0.05ms
            Hiccups: 0, FreeDm: 160, MinFreeDm: 140, MaxWait: 12289133ms
            === DDARing ===
            Heater 0 is on, I-accum = 0.1
            Heater 1 is on, I-accum = 0.9
            Segments left: 0
            Stack records: 4 allocated, 0 in use
            Movement lock held by null
            http is idle in state(s) 0
            telnet is idle in state(s) 0
            file is idle in state(s) 0
            serial is ready with "M122" in state(s) 0
            aux is idle in state(s) 0
            daemon is idle in state(s) 0
            queue is idle in state(s) 0
            Code queue is empty.
            === Network ===
            Slowest loop: 505.69ms; fastest: 0.00ms
            HTTP sessions: 0 of 8
            • WiFi -
              Network state is running
              WiFi firmware version 1.21
              WiFi MAC address cc:50:e3:0d:29:ce
              WiFi Vcc 3.40, reset reason Turned on by main processor
              WiFi flash size 4194304, free heap 17096
              WiFi IP address 192.168.1.151
              WiFi signal strength -61dBm, reconnections 0, sleep mode modem
              Phaedrux Moderator @CarlBosson
              Firmware Version: 2.05.1 (2020-02-09b1)
              WiFi Server Version: 1.21
              Web Interface Version: 1.22.6
              Your firmware versions are very out of date. Most of the code suggestions you will get here likely won't work as expected.
              I suggest you update your firmware. You'll need to generate a fresh config set for RRF3. https://configtool.reprapfirmware.org/
              If you still have access to DWC. Upload these zip files, one at a time in the system tab. Don't extract them first. Reboot after each. Use M115 in the gcode console to verify the firmware has been applied.
              https://github.com/Duet3D/RepRapFirmware/releases/download/3.0/Duet2and3Firmware-3.0.zip
              https://github.com/Duet3D/RepRapFirmware/releases/download/3.3/Duet2and3Firmware-3.3.zip
              https://github.com/Duet3D/RepRapFirmware/releases/download/3.4.5/Duet2and3Firmware-3.4.6.zip
              CarlBossonundefined 3 Replies Last reply Reply Quote 0
                droftarts administrators @CarlBosson
                @CarlBosson If you don't want to update the firmware, you can still tune the heaters. You just can't tune them as a tool. Use M303 H1 S200 instead.
                CarlBossonundefined 1 Reply Last reply Reply Quote 0
                  CarlBosson @Phaedrux
                  This post is deleted!
                    @Phaedrux
                    Thank you for all your help. Sorry for the late response, I have been out sick. Things are a little busy now and I have playing catch up, I may have to take this machine home to work on it. I am sure I will have questions as I go. Thanks and have a great day.
                    Carl
                      CarlBosson @droftarts
                      @droftarts said in PID Tuning Procedure:
                      Thank you for your input and the option that you offer. I think I will try to fix it once and for all. "I know that is a fantasy".
                      Carl
                        @Phaedrux I have updated to firmware Ver 3.3.
                        But the kink you sent to Ver 3.4.6 says file not found?
                          @CarlBosson sorry typo
                          https://github.com/Duet3D/RepRapFirmware/releases/download/3.4.6/Duet2and3Firmware-3.4.6.zip
                            @Phaedrux Ok I have that done.
                            I need to be honest. I am in way over my head! Thank you for all the help.
                            Yesterday I connected to my home network and had access to the DWC but now it will not connect to the same IP address. When I enter M587 via YAT I get the following message?
                            M587
                            Failed to retrieve network list: another SPI transfer is pending
                            ok
                              @Phaedrux Current M122
                              M122
                              RepRapFirmware for Duet 2 WiFi/Ethernet version 3.3 (2021-06-15 21:44:54) running on Duet WiFi 1.02 or later
                              Used output buffers: 1 of 24 (4 max)
                              Static ram: 23876
                              Dynamic ram: 73796 of which 84 recycled
                              Never used RAM 16660, free system stack 170 words
                              Tasks: NETWORK(ready,7.7%,521) HEAT(delaying,0.0%,386) Move(notifyWait,0.1%,364) MAIN(running,92.1%,461) IDLE(ready,0.1%,29), total 100.0%
                              Owned mutexes: USB(MAIN)
                              Last reset 00:21:12 ago, cause: power up
                              Last software reset details not available
                              Error status: 0x00
                              Step timer max interval 0
                              MCU temperature: min 37.0, current 40.3, max 40.8
                              Supply voltage: min 0.3, current 24.6, max 24.7, under voltage events: 1, over voltage events: 0, power good: yes
                              Driver 0: position 0, standstill, SG min/max not available
                              Driver 1: position 0, standstill, SG min/max not available
                              Driver 2: position 0, standstill, SG min/max not available
                              Driver 3: position 0, standstill, SG min/max not available
                              Driver 4: position 0, standstill, SG min/max not available
                              Driver 5: position 0
                              Driver 6: position 0
                              Driver 7: position 0
                              Driver 8: position 0
                              Driver 9: position 0
                              Driver 10: position 0
                              Driver 11: position 0
                              Slowest loop: 101.25ms; fastest: 0.13ms
                              === Storage ===
                              SD card longest read time 0.9ms, write time 0.0ms, max retries 0
                              === MainDDARing ===
                              === AuxDDARing ===
                              Bed heaters = -1 -1 -1 -1, chamberHeaters = -1 -1 -1 -1
                              Segments left: 0
                              HTTP is idle in state(s) 0
                              Telnet is idle in state(s) 0
                              File is idle in state(s) 0
                              USB is ready with "M122" in state(s) 0
                              Aux is idle in state(s) 0
                              Trigger is idle in state(s) 0
                              Queue is idle in state(s) 0
                              LCD is idle in state(s) 0
                              Daemon is idle in state(s) 0
                              === Network ===
                              Slowest loop: 0.33ms; fastest: 0.00ms
                              • WiFi -
                                Network state is starting2
                                WiFi module is disabled
                                Failed messages: pending 0, notready 1, noresp 0
                                ok
                                @Phaedrux Here are my attempts to restart the wifi below
                                • WiFi -
                                  ok
                                  M552
                                  WiFi module is being started
                                  ok
                                  M552
                                  ok
                                  M552
                                  ok
                                  M552 S-1
                                  WiFi module stopped
                                  ok
                                  M552
                                  ok
                                  M552 S0
                                  ok
                                  M552
                                  ok
                                  M587
                                  ok
                                  Try sending these commands to reflash the wifi module as it sounds like it may have failed on 3.3 which has happened before. Make sure you have the wifiserver bin file in the new firmwares folder.
                                  M552 S-1
                                  M552 S0
                                  M997 S1
                                  M552 S1
                                    @Phaedrux I am sorry, I did not see that you posted yesterday. I will work on this this afternoon and supply feedback.
                                    I also completed the RepRap firrmwareconfigtool you suggested and have it saved but not yet installed. do I upload that into the system folder the same way as the firmware updates?
                                    Carl
                                      Yes at the end of the config tool process you can download your config files as a zip file. Upload that zip file to the system tab in DWC to install them. Backup your SD card first if you want to preserve your existing configuration files.
                                        @Phaedrux
                                        I have connected via YAT and USB. Keyed in M552 S0 and get the following:
                                        M552 S1
                                        Turn off the current WiFi mode before selecting a new one
                                        ok
                                        I backed up the SD Card yesterday in preparation.
                                          @Phaedrux
                                          I am still at a complete stand still here. Were you waiting for input from me?
                                          Carl
                                            Yes. Have you sent these commands and what is the output of each?
                                            M552 S-1
                                            M552 S0
                                            M552 S1
                                            M997 S1
