    Sorry , i still can not fiqure this out
    236
    • Richard Fundefined
      Richard F
      The custom bed temps are not being applied
      Screenshot 2024-04-27 122250.png to the heater dropdown box
      ; Configuration file for RepRapFirmware on Duet 3 Mini 5+ WiFi
      ; generated by RepRapFirmware Configuration Tool v3.5.0-rc.3 on Thu Mar 14 2024 13:43:02 GMT+0000 (Greenwich Mean Time)
      ; General
      M550 P"Duet 3"   ; set hostname
      ;M911 S19.8 R22 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; set voltage thresholds and actions to run on power loss
      M552 S1
      ;M587 S"HeX" P"Spyder30"            ; configure WiFi adapter
      M586 P0 S1                         ; configure HTTP
      ; LED Strips
      ;M950 E0 C"io1.out" T2 ; configure LED strip #0
      ; Smart Drivers
      M569 P0.0 S0 D3 V3                                                     ; driver 0.0 goes forwards (X axis)
      M569 P0.1 S0 D3 V3                                                     ; driver 0.1 goes forwards (Y axis)
      M569 P0.2 S0 D3 V3                                                     ; driver 0.2 goes forwards (Z axis)
      M569 P20.0 S0 D3 V3
      ; Motor Idle Current Reduction
      M906 I50                                                               ; set motor current idle factor
      M84 S50        ; set motor current idle timeout
      ; Axes
      M584 X0.0 Y0.1 Z0.2                                                    ; set axis mapping
      M350 X16 Y16 Z16 I1                                                    ; configure microstepping with interpolation
      M906 X800 Y1000 Z700                                                ; set axis driver currents
      M92 X80 Y80 Z400                                                       ; configure steps per mm
      M208 X0:300 Y0:215 Z-3:160                                             ; set minimum and maximum axis limits
      M566 X15 Y15 Z20                                                       ; set maximum instantaneous speed changes (mm/min)
      M203 X3000 Y3000 Z500                                                  ; set maximum speeds (mm/min)
      M201 X300 Y300 Z30                                                     ; set accelerations (mm/s^2)
      ; Extruders
      M584 E20.0                                                             ; set extruder mapping
      M350 E16 I1                                                            ; configure microstepping with interpolation
      M906 E1000                                                              ; set extruder driver currents
      M92 E397                                                               ; configure steps per mm
      M566 E800                                                              ; set maximum instantaneous speed changes (mm/min)
      M203 E2000                                                            ; set maximum speeds (mm/min)
      M201 E400                                                            ; set accelerations (mm/s^2)
      ; Kinematics
      M669 K0                                                              ; configure Cartesian kinematics
      M574 X1 P"!io5.in" S1                                                  ; configure X axis endstop
      M574 Y1 P"!io6.in" S1                                                  ; configure Y axis endstop
      ;M574 Z1 P"!io0.in" S1                                                  ; configure Z axis endstop
      M574 Z1 S2 ;P"20.io0.in"
      ; Probes
      M558 K0 P8 C"20.io0.in" H1.2 F20000 T1000                        ; configure metal proximity sensor via slot #0
      G31 P500 X20 Y-20 Z-0
      ;GRID
      M557 X35:290 Y35:210 S80:50     F8000                            ; set Z probe trigger value, offset, and trigger height
      ; Sensors
      ;nozzle
      M308 S0 P"20.temp0" Y"thermistor" A"Nozzle" T100000 B4388 C7.06e-8
       ;bed
      M308 S1 P"temp2" Y"thermistor" A"Bed"  T100000 B4388 C7.06e-8 ;
      ; Nozzle
      M950 H0 C"20.out0" T0
      ;M140 P0 H1                                     ; create heater #0 for the nozzle
      M143 H0 P0 T0 C0 S300 A0                          ; configure nozzle heater monitor
      ; Heaters  BED
      M950 H1 C"out0" T1                                  ; create heater #1 for the bed
      M140 P1 H1                                          ; assign bed heater to heater 1
      M143 H1 P1 T1 C0 S110 A0                            ; configure bed heater monitor
      ;M950 F0 C"20.out1"                                  ; create part cooling fan
      ;M106 P0 S0 L0 X1 B0.1                               ; configure fan 0
      M950 F1 C"20.out2"                                  ; create hotend cooling fan
      M106 P1 S0 L0 X1 B0.1                               ; configure fan 1
      M563 P0 S"Evo" D0  H0 F0
       M568 P0 R0 S0
       T0
      ![Screenshot 2024-04-27 122623.png](/assets/uploads/files/1714217202536-screenshot-2024-04-27-122623.png)
      Beta server ?
      Richard Fundefined 1 Reply Last reply Reply Quote 0
        Richard F @Richard F
        beta server ?
        Exerqtorundefined 1 Reply Last reply Reply Quote 0
        • Exerqtorundefined
          Exerqtor @Richard F
          @Richard-F
          Why don't you move over to 3.5.1 stable instead of 3.5.0-rc4? It's no bugs in 3.5.0-rc4 that should cause this behaviour that i know of, but running a stable release is usually prefered.
            Richard F @Exerqtor
            @Exerqtor ok thanks , ill try that .
            • achrnundefined
              achrn
              The bed settings are in sys/dwc-settings.json What do you have in that file? It's one long line, they should be towards the end so start there and work backwards.
                @Richard-F im now on 3.5.1
                i have 2 bed heaters showing but i only have 1 , and both bed and nozzle are reading the same temps .. Cant see what could be causing this in the code 😞
                v
                  jay_s_uk @Richard F
                  @Richard-F you have 2 M140s. Best post your whole config.g
                  Richard Fundefined 2 Replies Last reply Reply Quote 0
                    Richard F @jay_s_uk
                    This post is deleted!
                      Richard F @jay_s_uk
                      ; General
                      M552 S1
                      ; LED Strips
                      ; Smart Drivers
                      M569 P20.0 S0 D3 V3
                      ; Axes
                      ; Extruders
                      ; Kinematics
                      ; Probes
                      ;GRID
                      ; Sensors
                      ;nozzle
                       ;bed
                      ; Nozzle
                      M140 P0 H0                                     ; create heater #0 for the nozzle
                      ;Heaters  BED
                       M568 P0 R0 S0
                       T0
                        @Richard-F i got rid of 2nd m140 , i have one bed heater.. (fixed)
                          ; Sensors
                          ;nozzle
                           ;bed
                          ; Nozzle
                          ; Heaters  BED
                          M143 H1 P1 T1 C0 S100 A0                            ; configure bed heater monitor
                            @Richard-F
                            Ive still no idea why its not letting me set custom bed temps though , everything's just been updated to the latest fw
                              You can close thread now if you like
                              @Richard-F for future problems , i fixed it by turning these off Screenshot 2024-04-27 142838.png
                              • T3P3Tonyundefined T3P3Tony marked this topic as a question
                              • T3P3Tonyundefined T3P3Tony has marked this topic as solved
