    Firmware 1.20 released
    Firmware installation
    20
    89
    14.2k
      I am pleased to announce the release of firmware version 1.20 at https://github.com/dc42/RepRapFirmware/releases.
      Compared to firmware 1.19, this release includes more than 70 new features and improvements, along with nearly 40 bug fixes. For the list and the upgrade notes, see https://github.com/dc42/RepRapFirmware/blob/dev/WHATS_NEW.md.
      EDIT: For those of you already running 1.20RC4, the changes since that version are:
      • Fixed the sending of motor currents to DWC
      • Fixed (I think) the problem of newly-uploaded WiFi module firmware not working immediately if the previously-installed firmware used a different SDK version
      • peirofundefined
        peirof
        Hi…
        For cutiosity... Examples of printers of more 3 axis?
        Thanks
          @peirof:
          Hi…
          For curiosity... Examples of printers of more 3 axis?
          Thanks
          The ones I can remember:
          IDEX printers (dual X carriages) - 4 axes (RRF treats the second X carriage as an additional axis)
          Kulitorum's concrete printer - 4 axes (the 4th axis rotates the concrete extruder)
          Ian (deckingman's) printer with dual CoreXY gantries - 5 axes
          Various printers that split the (N) Z motors during homing, so they can be homed separately - 2 + (N) axes (one temporary axis per additional Z motor)
          Someone's (sorry, I can't remember who it was) printer with dual X, dual Y and dual Z axes - 6 axes
            Chrishamm has now released DWC 1.20, so I've updated the release to include it instead of DWC 1.20 RC3.
            • MarMedundefined
              MarMed
              So thankful for this release! Wait for thermostatic fans on power off, adjustable PWM frequency, and so much more!
              Thanks!
                deckingman
                @dc42:
                Confirmed fixed. Thanks.
                • Synapsisundefined
                  Synapsis
                  Just wanted to say that I updated with no problems very straight forward and reconnected to my network upstairs with noproblems
                  and then reconnected to a different network downstairs and also here no problems. connects right away to the router every time for now.
                    @Synapsis:
                    Thanks for your feedback!
                    • BMMalundefined
                      BMMal
                      I've been running for a few hours now with no significant problems. Only thing I can complain about is that since 1.20 went to RC, my WiFi issues are more prevalent again. A while back I was wondering if I was running too high of a step frequency due to the Step Errors and causing some kind of under-run. Never really figured anything out about that though or if it is at all related.
                      [[language]]
                      Used output buffers: 3 of 32 (15 max)
                      RepRapFirmware for Duet WiFi version 1.20 running on Duet WiFi 1.0 + DueX5
                      Board ID: 08D6M-91AST-L23S4-7JTD8-3S86K-1PX1K
                      Static ram used: 15448
                      Dynamic ram used: 99992
                      Recycled dynamic ram: 3344
                      Stack ram used: 1392 current, 8440 maximum
                      Never used ram: 3848
                      Last reset 03:59:41 ago, cause: software
                      Last software reset at 2017-12-26 13:20, reason: User, spinning module GCodes, available RAM 3848 bytes (slot 0)
                      Software reset code 0x0003 HFSR 0x00000000, CFSR 0x00000000, ICSR 0x0441f000, BFAR 0xe000ed38, SP 0xffffffff
                      Error status: 2
                      Free file entries: 8
                      SD card longest block write time: 404.0ms
                      MCU temperature: min 26.3, current 27.7, max 28.4
                      Supply voltage: min 24.2, current 24.5, max 25.0, under voltage events: 0, over voltage events: 0
                      Driver 0: ok, SG min/max 0/787
                      Driver 1: ok, SG min/max 0/1023
                      Driver 2: standstill, SG min/max 0/1023
                      Driver 3: standstill, SG min/max 0/585
                      Driver 5: ok, SG min/max 0/1023
                      Driver 6: standstill, SG min/max 0/543
                      Driver 7: standstill, SG min/max not available
                      Expansion motor(s) stall indication: yes
                      Date/time: 2017-12-26 17:24:08
                      Slowest main loop (seconds): 0.407292; fastest: 0.000045
                      MaxReps: 5, StepErrors: 12803, FreeDm: 164, MinFreeDm 150, MaxWait: 4260061081ms, Underruns: 0, 1
                      Scheduled moves: 216447, completed moves: 216420
                      Bed compensation in use: none
                      Heater 0 is on, I-accum = 0.0
                      Heater 3 is on, I-accum = 0.0
                      Segments left: 1
                      Stack records: 3 allocated, 0 in use
                      Movement lock held by null
                      http is idle in state(s) 0
                      telnet is idle in state(s) 0
                      file is doing "G1 X252.578 Y56.169 E0.0484" in state(s) 0
                      serial is idle in state(s) 0
                      aux is idle in state(s) 0
                      daemon is idle in state(s) 0
                      queue is idle in state(s) 0
                      Code queue is empty.
                      Network state is running
                      WiFi firmware version 1.20
                      WiFi MAC address a0:20:a6:16:e6:c6
                      WiFi Vcc 3.26, reset reason Turned on by main processor
                      WiFi flash size 4194304, free heap 16752
                      WiFi IP address 10.0.0.115
                      WiFi signal strength -31dBm, reconnections 0, sleep mode modem
                      HTTP sessions: 1 of 8
                      Socket states: 2 0 0 0 0 0 0 0
                      Responder states: HTTP(1) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0)
                      Duet Ethernet - Most likely the most recent Edge firmware
                      Duet X5
                      7" Panel Due V2
                      Cartesian, 4 Nozzles with Flex3Drives, Heated Chamber, Simple Switch Filament Sensing
                      • Ak Ericundefined
                        Ak Eric
                        Have done a few prints now with 1.20 on a DuetEthernet/delta : No issues so far.
                          @BMMal:
                          Your MaxReps figure is low so there isn't a problem with the step rate. But I would like to investigate why you have so many step errors. Can you provide the Gcode file and your config.g file?
                          • BMMalundefined
                            BMMal
                            @dc42:
                            @BMMal:
                            You can get the files from here: https://www.dropbox.com/sh/4er7llhg7vifkfu/AADv9KP6UQct_5WiclzfOFOia?dl=0
                            Duet X5
                            7" Panel Due V2
                            • anglachelundefined
                              anglachel
                              Haven't upgraded my firmware yet (want to finish current project before I change anything on the printer) I was looking changes I need to make to my config…
                              would it make more sense to start logging as custom g-code in slic3r, rather than in the config.g?
                              For start gcode:
                              M929 S0 ; stop any existing logs that might be running
                              M929 P"[input_filename_base].log" S1	;Start logging
                              ```and at the end
                              M929 S0 ; Stop logging
                                Thanks! I have reproduced the step errors, both on the bench and in the simulator. I have located the reason for the vast majority of the step errors, and fixed it. The step errors are benign and should not affect print quality. I am still getting a small number of step errors reported with a different cause, and I will investigate those today.
                                I already found another bug that needs to be fixed in 1.20 (also present in 1.19) concerning filament sensor support, so I am planning a 1.20.1 release, which will also have the fixes for the step error reports.
                                • Thomllamaundefined
                                  Thomllama
                                  OK then, I just today fired up my Duet Wifi on my CoreXY after many months of idle. Was mounted for a short time on m old i3 clone just for kicks. anyway, it's still running 1.8. what do I have to do to update? just get all those files? upload to SD card and then run the update like is in the Docs for 1.9? Honestly I tried the 1.9 update back then and it failed miserably. had to re set to 1.8.
                                  Do want to update as right now the wifi won't connect every time I reboot or just fire it up for the day. I have to go and kick my computer's Wifi over the the Duet. do the 192.1.1…. then the window pops up asking for the wifi info.. select network and type in password and reboot and then it'll work,... till I have to reboot again and I'll have to go through the whole process once more. Ugg. anyway, it's late and I'm off to bed.. hoping tomorrow to be a bit better a day for it 😉
                                    One way is to upload the new DuetWiFiFirmware.bin and DuetWiFiServer.bin files WITHOUT installing them (or copy them to the SD card on a PC). Also comment out the M552 S1 command in config.g. Then connect via USB and send M997 S0 to update the main firmware. You can watch the progress on PanelDue if you have one. After a minute you should be able to reconnect via USB, then send M997 S1 to update the WiFi firmware. Then follow the "getting connected" instructions for firmware 1.19 and later on the wiki.
                                    • vhowardundefined
                                      vhoward
                                      I upgraded from 1.19 to 1.20. Now my BL Touch does not work correctly. It self tests fine, but when I home z, the probe does deploy, but now my printer tries to drive the nozzle through the heat bed. It does not stop.
                                      If I down grade to 1.19 on the firmware, do I need to downgrade the wifi server also?
                                        Thomllama
                                        @dc42:
                                        did exactly that.. Uploaded and told it not to install. Turned off the wifi, disconnected everything and brought over to computer -
                                        plugged into USB, connect with Printrun(pronto face) type in M997 S0,.. keep getting errors.. Remove SD card and plug in direct to computer.. Can't drag and drop the file won't let me. ?? now what?
                                          Thomllama
                                          I seriously think my WiFi module is bad. this thing has been nothing but issues, drops connection. won't reconnect 1/2 the time with out a complete power down and restart and then I always had to go in and reconfigure the network info. Every single time. did everything you stated above ad it won't work. Now I can't even get the wifi to turn back on under 1.8. 😕
                                            Thomllama
                                            M552 S1
                                            SENDING:M552 S1
                                            WiFi module started
                                            Error: Failed to initialise WiFi module, code -10
                                            [ERROR] Error: Failed to initialise WiFi module, code -10
                                            or,…
                                            M552 S0
                                            SENDING:M552 S0
                                            WiFi module started
