    how the heating control operates
    748
    • luca Massimilianoundefined
      luca Massimiliano
      good morning I have a RepRapFirmware for Duet 2 WiFi/Ethernet version 3.2.2 I'm trying to calibrate my 2 new CHC V6 Hotend Ceramic hotend at 24 60 w volt NTC100K B3950 here are the commands and responses:
      first Hotend
      ************COMMAND **********
      M303 H1 S275 (275 temperature because my wire requires max 270)
      _ANSWER
      Warning: heater behavior was not consistent during tuning
      Auto tuning heater 1 completed after 4 idle and 25 tuning cycles in 413 seconds. This heater needs the following M307 command:
      M307 H1 R4.649 C105.2 D1.62 S1.00 V23.8
      Send M500 to save this command in config-override.g
      _ANSWER
      Warning: M307: Heater 1 appears to be over-powered. If left on at full power, its temperature is predicted to reach 514C
        jay_s_uk @luca Massimiliano
        @luca-Massimiliano best update to 3.5.2 as the heater tuning has improved since then.
        luca Massimilianoundefined 1 Reply Last reply Reply Quote 0
          luca Massimiliano @jay_s_uk
          THANKS WHERE CAN I DOWNLOAD version 3.5.2 COULD IT BE THIS?https://configtool.reprapfirmware.org/
            @luca-Massimiliano https://github.com/Duet3D/RepRapFirmware/releases/tag/3.5.2
            And tune as a tool rather than a heater
            M303 T0 S275
            luca Massimilianoundefined 2 Replies Last reply Reply Quote 0
              This post is deleted!
                @jay_s_uk said in how the heating control operates:
                M303 T0 S275
                THANKS FOR YOUR HELP, I HAVE SOLVED IT
                luca Massimilianoundefined 1 Reply Last reply Reply Quote 1
                • jay_s_ukundefined jay_s_uk marked this topic as a question
                • jay_s_ukundefined jay_s_uk has marked this topic as solved
                  luca Massimiliano @luca Massimiliano
                  @luca-Massimiliano
                  GOOD MORNING I HAVE A Duet 2 WiFi, AFTER THE UPDATE TO THE LATEST VERSION 3.5.2 ON THE DASHBORD, ONCE THE SET HEATER TEMPERATURE HAS BEEN REACHED, THE EXTRUSION CONTROL BAR CANNOT BE USED, INSTEAD THE DISPLAY IF USED GIVES THE FOLLOWING ERROR error: attempting to extrude with no tools selected. here is the config
                  M308 S0 P"bedtemp" Y"thermistor" T100000 B3950 ; configure sensor 0 as thermistor on pin bedtemp
                  M140H0 ; map heated bed to heater 0
                  M308 S1 P"e0temp" Y"thermistor" T100000 B4388 ; configure sensor 1 as thermistor on pin e0temp
                  M308 S2 P"e1temp" Y"thermistor" T100000 B4388 ; configure sensor 2 as thermistor on pin e1temp
                  M950 H2 C"e1heat" T2 ; create nozzle heater output on e1heat and map it to sensor 2
                  M307 H2 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit
                  M143 H2 S280 ; set temperature limit for heater 2 to 280C
                  M106 P0 S0 H1 T100 ; set fan 0 value. Thermostatic control is turned on
                  M106 P1 S1 H2 T100 ; set fan 1 value. Thermostatic control is turned on
                  M563 P1 S"LUCA1" D0 H1 F0 ; define tool 1
                  G10 P1 X12.8 Y3.9 Z0 ; set tool 1 axis offsets
                  M563 P2 S"LUCA2" D1 H2 F0 ; define tools 2
                  G10 P2 X-12.8 Y3.9 Z0 ; set tool 2 axis offsets
                  G10 P2 R0 S0 ; set initial tool 2 active and standby temperatures to 0C
                    @luca-Massimiliano you need a tool to be active.
                    Send Tx where X is the tool number that you want to drive
                      @jay_s_uk
                      how should I put it in the config
                        @luca-Massimiliano you have two tools so it depends which one you want to be active when you first turn on the machine
                        Either add T1 to the end of the config or T2
                        oliofundefined luca Massimilianoundefined 2 Replies Last reply Reply Quote 0
                        • oliofundefined
                          oliof @jay_s_uk
                          @jay_s_uk rather T0 or T1?
                            @jay_s_uk
                            I don't understand in which config .g command should I add t0 and t1? the problem is that the commands on the dashboard and on the duet display are not activated if I send the extrusion error: trying to extrude with no tools selected.
                            • oliofundefined
                              oliof @luca Massimiliano
                              @luca-Massimiliano just add either T0 or T1 on the end of config.g
                                jay_s_uk @oliof
                                @oliof he has the tools setup as T1 and T2
                                @luca-Massimiliano said in how the heating control operates:
                                • oliofundefined
                                  oliof @jay_s_uk
                                  @jay_s_uk well ok then (-: That'll confuse the average slicer tho
                                    @jay_s_uk
                                    I inserted t1 and t2 without anything else and it works, but I never did it in previous versions and it worked anyway, has it been changed in this version?
                                      luca Massimiliano @oliof
                                      @oliof
                                      now I try to send a print with slicer,
                                        @luca-Massimiliano you shouldn't insert both of them into the config, just one of them.
                                        you can only have one active tool at a time.
                                        and no changes i'm aware of in that area for ages
                                          @jay_s_uk Now I try again but with a declared tool if activated first the second one doesn't work
                                          luca Massimilianoundefined jay_s_ukundefined 2 Replies Last reply Reply Quote 0
                                            @luca-Massimiliano
                                            I had version 3.2.2 before and didn't declare the first extruder
