    3 fans on tool board 1lc?
    652
    • gnydickundefined
      gnydick
      I'd like to be able to control 3 fans on a toolboard.
      1. cold section, thermostatically controlled
      2. primary part cooling fan
      3. secondary cooling fan
      I have some relatively powerful blower fans on my tools and when printing fast I want to use both of them, but when printing slower, only one of them.
      Any ideas?
      jay_s_ukundefined gloomyandyundefined 2 Replies Last reply Reply Quote 0
        jay_s_uk @gnydick
        @gnydick there are only 2 controllable fan outputs.
        You would have to add some sort of relay or MOSFET module and control it using one of the iox.out pins
        Or run an extra cable and use a fan connection on the mainboard
        • gnydickundefined
          gnydick @jay_s_uk
          @jay_s_uk if there was another .out, then I'd be able to just assign it to a fan, wouldn't I? There are no .out's left.
          • gloomyandyundefined
            gloomyandy @gnydick
            @gnydick You can't normally connect io0.out directly to a fan. But if any of the fans are 4 wire you may be able to control the speed with the logic level output, you would need to check the voltage required by the fan on the pwm input and the current it might draw. That's assuming you are not already using io0.out for something like a bl-touch. You may be able to use io0.in as a logic level output (again assuming it is not already being used), but I'm not sure if it is pwm capable or if there is any risk to the board if you do that.
            gnydickundefined 1 Reply Last reply Reply Quote 2
            • gnydickundefined
              gnydick @gloomyandy
              @gloomyandy, yep, I'm using IO0 for filament sensor/eject button
                gloomyandy @gnydick
                @gnydick are you using both io0.in and io0.out?
                  gloomyandy @gnydick
                  @gnydick What version of the 1lc do you have?
                  • gnydickundefined
                    gnydick @gloomyandy
                    @gloomyandy yes, using all of the pins. The latest version.
                    gloomyandyundefined dc42undefined 2 Replies Last reply Reply Quote 0
                      gloomyandy @gnydick
                      @gnydick Assuming it is a rev 1.3 board (possibly also on 1.2), there is an unpopulated pad for IO_3.in which you may be able to solder a wire to. I'm not sure if this can be used as an output though at least for pwm output, if not you may be able to shuffle some of the pins you are already using around and use io_3.in for an input. Other than that I think you are out of luck.
                        dc42 administrators @gnydick
                        @gnydick said in 3 fans on tool board 1lc?:
                        Including io0.out ? You said you were using IO0 for the filament sensor eject button, but I would have thought you only needed to use io0.in for that.
                        • gnydickundefined
                          gnydick @dc42
                          @dc42 2 switches, filament out sense, and eject button the specs are here, https://www.orbiterprojects.com/orbiter-filament-sensor/
                            @gnydick you could free up IO0.OUT by using one of the buttons on the tool board for filament unload instead of the one on the filament monitor; or you could connect the filament monitor button to the IO3_IN pads instead.
                            • gnydickundefined
                              gnydick @dc42
                              @dc42 very true, very true.
                              • dwuk3dundefined
                                dwuk3d
                                @gnydick - did you manage to get a 3rd fan working ok using the suggestion by @dc42 ?
                                I am trying to wire up a Sovol SV08 extruder (which also has 3 fans) - I was thinking I would have to run separate cables for the 3rd fan - but it would be neater if I could avoid this.
                                My current thinking is in the attached diagram.
                                jay_s_ukundefined gnydickundefined 2 Replies Last reply Reply Quote 0
                                  jay_s_uk @dwuk3d
                                  @dwuk assuming 2 fans are the part cooling fans, could you not just run them in parallel off the same connector? Assuming combined they pull less than 1A
                                  dwuk3dundefined 1 Reply Last reply Reply Quote 1
                                  • dwuk3dundefined
                                    dwuk3d @jay_s_uk
                                    @jay_s_uk I think you might be right. Checking the wiring the two cooling fans are connected to FAN2 and FAN4 on the Sovol Board.
                                    Which are in turn defined as generic fans fan0 and fan1 - in printer.cfg
                                    [fan_generic fan0] # back model cooling fan
                                    pin: extra_mcu:PA7
                                    max_power: 1.0
                                    [fan_generic fan1] # front model cooling fan
                                    pin: extra_mcu:PB1
                                    max_power: 1.0
                                    From looking at the macro.cfg - it looks like fan0 and fan1 are switched on and off together - so will try wiring them both up to Out2 as you suggest
                                    Next issue is the fans are probably 24v - so might have to change the fans?
                                    [gcode_macro M106]
                                    gcode:
                                    {% set fan = 'fan' + (params.P|int if params.P is defined else 0)|string %}
                                    {% set speed = (params.S|float / 255 if params.S is defined else 1.0) %}
                                    {% if fan == 'fan3'%}
                                    SET_FAN_SPEED FAN={fan} SPEED={speed}
                                    {% else %}
                                    SET_FAN_SPEED FAN={'fan0'} SPEED={speed}
                                    SET_FAN_SPEED FAN={'fan1'} SPEED={speed}
                                    {% endif %}
                                    [gcode_macro M107]
                                    gcode:
                                    SET_FAN_SPEED FAN={fan} SPEED=0
                                    {% else %}
                                    SET_FAN_SPEED FAN={'fan0'} SPEED=0
                                    SET_FAN_SPEED FAN={'fan1'} SPEED=0
                                    {% endif %}
                                      T3P3Tony administrators @dwuk3d
                                      @dwuk said in 3 fans on tool board 1lc?:
                                      What voltage are you supplying the toolboard?
                                      dwuk3dundefined 2 Replies Last reply Reply Quote 0
                                      • dwuk3dundefined
                                        dwuk3d @T3P3Tony
                                        @T3P3Tony I think I'm going to need 24v for the hot end - so 24v input I guess.
                                        • dwuk3dundefined
                                          dwuk3d @T3P3Tony
                                          @T3P3Tony Ah - I see you can select the output voltage as being VIN (I didn't spot that initially) - so I think that way I will be able to get 24v on Out1 and Out2 - so that should solve my fan issue. thanks
                                          • gnydickundefined
                                            gnydick @dwuk3d
                                            @dwuk I just ended up getting blowers without tachs and wiring them up in parallel.
