    No movement with any command
    MultiAxis Printing
    2.4k
      Remove the SD card from the Duet and use your computer to read the config.g file.
      zecretonundefined 2 Replies Last reply Reply Quote 0
      • zecretonundefined
        zecreton @Phaedrux
        @Phaedrux oops sorry i forgot that
        • zecretonundefined
          zecreton @Phaedrux
          @Phaedrux ; Configuration file for RepRapFirmware on Duet 3 Main Board 6XD
          ; generated by RepRapFirmware Configuration Tool v3.5.3 on Tue Jun 25 2024 21:16:10 GMT-0400 (Eastern Daylight Time)
          ; General
          G90 ; absolute coordinates
          M83 ; relative extruder moves
          M550 P"Duet 3" ; set hostname
          M551 P"Raphaelbreton2008" ; set machine password
          M552 P0.0.0.0 S1 ; configure Ethernet adapter
          M586 P0 S1 ; configure HTTP
          ; Motor Idle Current Reduction
          M906 I30 ; set motor current idle factor
          M84 S30 ; set motor current idle timeout
          ; External Drivers
          M569 P0.0 S1 R0 T5:5:10:0 ; driver 0.0 goes forwards and requires an active-low enable signal (X axis)
          M569 P0.1 S1 R0 T5:5:10:0 ; driver 0.1 goes forwards and requires an active-low enable signal (Y axis)
          M569 P0.2 S1 R0 T5:5:10:0 ; driver 0.2 goes forwards and requires an active-low enable signal (Z axis)
          ; Axes
          M584 X0.0 Y0.1 Z0.2 ; set axis mapping
          M350 X16 Y16 Z16 I0 ; configure microstepping without interpolation
          M92 X80 Y80 Z400 ; configure steps per mm
          M208 X0:1200 Y0:200 Z0:200 ; set minimum and maximum axis limits
          M566 X900 Y900 Z12 ; set maximum instantaneous speed changes (mm/min)
          M203 X6000 Y6000 Z180 ; set maximum speeds (mm/min)
          M201 X500 Y500 Z20 ; set accelerations (mm/s^2)
          ; Kinematics
          M669 K0 ; configure Cartesian kinematics
          M574 X1 P"io0.in" S1 ; configure X axis endstop
          M574 Y1 P"io1.in" S1 ; configure Y axis endstop
          M574 Z1 P"io2.in" S1 ; configure Z axis endstop
            Are you able to connect to the Duet via USB cable and use terminal software like YAT to send commands to it?
            described here: https://docs.duet3d.com/en/How_to_guides/Getting_connected/Getting_connected_to_your_Duet#h-2-connect-your-duet-via-usb
            zecretonundefined 1 Reply Last reply Reply Quote 0
            • zecretonundefined
              zecreton @Phaedrux
              @Phaedrux yes
                What happens if you follow along with the rest of that "Getting connected" guide?
                • zecretonundefined
                  zecreton @Phaedrux
                  @Phaedrux i doesn't work bc when i send M552 S1 P0.0.0.0, it answers with just ok, and when i send M552, i can see that it gave 0.0.0.0 as an ip address
                    How do you have the Duet connected to your network?
                    Does the network cable you have going to the Duet work if you try to connect it to a computer?
                    zecretonundefined Phaedruxundefined 2 Replies Last reply Reply Quote 0
                    • zecretonundefined
                      zecreton @Phaedrux
                      @Phaedrux it is plugged with a ethernet cable in the router
                        Phaedrux Moderator @Phaedrux
                        @Phaedrux said in No movement with any command:
                        zecretonundefined 3 Replies Last reply Reply Quote 0
                        • zecretonundefined
                          zecreton @Phaedrux
                          @Phaedrux yea sorry i didn't have the time to check, do you have the guide?
                          • zecretonundefined
                            zecreton @Phaedrux
                            @Phaedrux nvm i don't know what was the problem but i just powered it on and thew ethernet works fine
                            • zecretonundefined
                              zecreton @Phaedrux
                              @Phaedrux i tested with a multimeter and i can see that in the driver entry, the pul and dir are receiving power, but not the enable, and on the output i don't know what to test
                                Enable is low by default. Your drivers seem to require a high signal.
                                https://docs.duet3d.com/en/User_manual/Connecting_hardware/Motors_connecting_external#configuring-the-enable-polarity
                                See here for changing the enable polarity.
                                • zecretonundefined
                                  zecreton @Phaedrux
                                  @Phaedrux yea i already changed it to high
                                    Have you tested the enable pin output with your multimeter at the board side?
                                    Does the cable have continuity?
                                    Have you tried a different driver output?
                                    https://docs.duet3d.com/duet_boards/duet_3_mb6xd/duet3_mb_6xd_v1.0_later_dvr_conn.png
                                    • zecretonundefined
                                      zecreton @Phaedrux
                                      @Phaedrux i can see a 5v signal when no command is sent, but it drops to 0v when i send a signal, is that normal?
                                      • zecretonundefined
                                        zecreton @Phaedrux
                                        @Phaedrux yea,i get the same thing on the driver side
                                          Phaedrux Moderator @zecreton
                                          @zecreton said in No movement with any command:
                                          Then it sounds like the enable pin isn't actually inverted. What command did you use to invert it?
                                          • zecretonundefined
                                            zecreton @Phaedrux
                                            @Phaedrux M569 PO R1
