    No movement with any command
    MultiAxis Printing
    2.5k
    • zecretonundefined
      zecreton @Phaedrux
      @Phaedrux yes
        What happens if you follow along with the rest of that "Getting connected" guide?
        zecretonundefined 1 Reply Last reply Reply Quote 0
        • zecretonundefined
          zecreton @Phaedrux
          @Phaedrux i doesn't work bc when i send M552 S1 P0.0.0.0, it answers with just ok, and when i send M552, i can see that it gave 0.0.0.0 as an ip address
            How do you have the Duet connected to your network?
            Does the network cable you have going to the Duet work if you try to connect it to a computer?
            zecretonundefined Phaedruxundefined 2 Replies Last reply Reply Quote 0
            • zecretonundefined
              zecreton @Phaedrux
              @Phaedrux it is plugged with a ethernet cable in the router
                Phaedrux Moderator @Phaedrux
                @Phaedrux said in No movement with any command:
                zecretonundefined 3 Replies Last reply Reply Quote 0
                • zecretonundefined
                  zecreton @Phaedrux
                  @Phaedrux yea sorry i didn't have the time to check, do you have the guide?
                  • zecretonundefined
                    zecreton @Phaedrux
                    @Phaedrux nvm i don't know what was the problem but i just powered it on and thew ethernet works fine
                    • zecretonundefined
                      zecreton @Phaedrux
                      @Phaedrux i tested with a multimeter and i can see that in the driver entry, the pul and dir are receiving power, but not the enable, and on the output i don't know what to test
                        Enable is low by default. Your drivers seem to require a high signal.
                        https://docs.duet3d.com/en/User_manual/Connecting_hardware/Motors_connecting_external#configuring-the-enable-polarity
                        See here for changing the enable polarity.
                        • zecretonundefined
                          zecreton @Phaedrux
                          @Phaedrux yea i already changed it to high
                            Have you tested the enable pin output with your multimeter at the board side?
                            Does the cable have continuity?
                            Have you tried a different driver output?
                            https://docs.duet3d.com/duet_boards/duet_3_mb6xd/duet3_mb_6xd_v1.0_later_dvr_conn.png
                            zecretonundefined 2 Replies Last reply Reply Quote 0
                            • zecretonundefined
                              zecreton @Phaedrux
                              @Phaedrux i can see a 5v signal when no command is sent, but it drops to 0v when i send a signal, is that normal?
                              • zecretonundefined
                                zecreton @Phaedrux
                                @Phaedrux yea,i get the same thing on the driver side
                                  Phaedrux Moderator @zecreton
                                  @zecreton said in No movement with any command:
                                  Then it sounds like the enable pin isn't actually inverted. What command did you use to invert it?
                                  • zecretonundefined
                                    zecreton @Phaedrux
                                    @Phaedrux M569 PO R1
                                      You have a 6XD so this won't work.
                                      What position is your enable polarity jumper in?
                                      https://docs.duet3d.com/duet_boards/duet_3_mb6xd/duet_3_mb6xd_wiring_latest.png
                                      1 x 3-pin Jumper Driver Enable Polarity A jumper in the "left" position is used for external drivers which are enabled when a voltage is applied to the enable connection (Active Enable). A jumper in the "right" position is used for external drivers which are disabled when a voltage is applied to the enable connection (Active Disable) (Note the v0.1 boards have the silkscreen reversed).
                                      https://docs.duet3d.com/Duet3D_hardware/Duet_3_family/Duet_3_Mainboard_6XD_Hardware_Overview#connecting-external-motor-drivers
                                      droftartsundefined zecretonundefined 2 Replies Last reply Reply Quote 0
                                        droftarts administrators @Phaedrux
                                        Is that in the documentation somewhere? On Slack @dc42 said:
                                        M569 R parameter does have an effect on the 6XD. The jumper just sets the default value in case a M569 command with R parameter isn't seen. The main aim of this is to power up with the drivers disabled.
                                        I've updated the documentation here to make it clearer: https://docs.duet3d.com/en/Duet3D_hardware/Duet_3_family/Duet_3_Mainboard_6XD_Hardware_Overview#connecting-external-motor-drivers
                                        However...
                                        M569 PO R1
                                        You have used an upper case letter 'o' for the P parameter, it should be a zero 0. Did it not report an error? Should be:
                                        M569 P0 R1
                                        • zecretonundefined
                                          zecreton @droftarts
                                          @droftarts
                                          M569 P0 R1
                                          i made an error in the message but i did send M569 P0 R1, sorry
                                          droftartsundefined dc42undefined 2 Replies Last reply Reply Quote 0
                                            droftarts administrators @zecreton
                                            @zecreton Are you sure the axes are homed? You cannot move any axis if it is not homed. Though you should get an error message if you try and move an axis and it isn't homed. If you're still bench testing this, you could also send M564 H0 S0. This allows movement of axes that have not been homed, and allows movement outside boundaries set by M208. Add it to your config.g.
                                            When you command a move, does DWC update the X position to show this change? If it does, then it is most likely sending the step and direction pulses.
                                            Did you disconnect the ENA wires? If you do, you will still need to supply 5V to DIR+ and PUL+. Maybe post new pictures of how it is wired now.
