    No movement with any command
    MultiAxis Printing
    2.9k
    • zecretonundefined
      zecreton @Phaedrux
      @Phaedrux no
        droftarts administrators @zecreton
        @zecreton You get this message when there's no SD card in the Duet, and it assumes that it is connected to a Raspberry Pi in SBC mode. I guess you're connected over USB? Send M122 to check if the SD card is recognised.
        Check SD card and reading it: https://docs.duet3d.com/en/User_manual/RepRapFirmware/SD_card#troubleshooting-sd-card-issues
        zecretonundefined 1 Reply Last reply Reply Quote 0
        • zecretonundefined
          zecreton @droftarts
          @droftarts the sd card was not correctly in the slot idk why, but now im getting an ip adress of 0.0.0.0 and even with the ethernet cable disconnected, it says it is enabled
            Please copy and paste the text of your config.g into a post here.
            • zecretonundefined
              zecreton @Phaedrux
              @Phaedrux i can't access dwc
                Remove the SD card from the Duet and use your computer to read the config.g file.
                zecretonundefined 2 Replies Last reply Reply Quote 0
                • zecretonundefined
                  zecreton @Phaedrux
                  @Phaedrux oops sorry i forgot that
                  • zecretonundefined
                    zecreton @Phaedrux
                    @Phaedrux ; Configuration file for RepRapFirmware on Duet 3 Main Board 6XD
                    ; generated by RepRapFirmware Configuration Tool v3.5.3 on Tue Jun 25 2024 21:16:10 GMT-0400 (Eastern Daylight Time)
                    ; General
                    G90 ; absolute coordinates
                    M83 ; relative extruder moves
                    M550 P"Duet 3" ; set hostname
                    M551 P"Raphaelbreton2008" ; set machine password
                    M552 P0.0.0.0 S1 ; configure Ethernet adapter
                    M586 P0 S1 ; configure HTTP
                    ; Motor Idle Current Reduction
                    M906 I30 ; set motor current idle factor
                    M84 S30 ; set motor current idle timeout
                    ; External Drivers
                    M569 P0.0 S1 R0 T5:5:10:0 ; driver 0.0 goes forwards and requires an active-low enable signal (X axis)
                    M569 P0.1 S1 R0 T5:5:10:0 ; driver 0.1 goes forwards and requires an active-low enable signal (Y axis)
                    M569 P0.2 S1 R0 T5:5:10:0 ; driver 0.2 goes forwards and requires an active-low enable signal (Z axis)
                    ; Axes
                    M584 X0.0 Y0.1 Z0.2 ; set axis mapping
                    M350 X16 Y16 Z16 I0 ; configure microstepping without interpolation
                    M92 X80 Y80 Z400 ; configure steps per mm
                    M208 X0:1200 Y0:200 Z0:200 ; set minimum and maximum axis limits
                    M566 X900 Y900 Z12 ; set maximum instantaneous speed changes (mm/min)
                    M203 X6000 Y6000 Z180 ; set maximum speeds (mm/min)
                    M201 X500 Y500 Z20 ; set accelerations (mm/s^2)
                    ; Kinematics
                    M669 K0 ; configure Cartesian kinematics
                    M574 X1 P"io0.in" S1 ; configure X axis endstop
                    M574 Y1 P"io1.in" S1 ; configure Y axis endstop
                    M574 Z1 P"io2.in" S1 ; configure Z axis endstop
                      Are you able to connect to the Duet via USB cable and use terminal software like YAT to send commands to it?
                      described here: https://docs.duet3d.com/en/How_to_guides/Getting_connected/Getting_connected_to_your_Duet#h-2-connect-your-duet-via-usb
                      • zecretonundefined
                        zecreton @Phaedrux
                        @Phaedrux yes
                          What happens if you follow along with the rest of that "Getting connected" guide?
                          • zecretonundefined
                            zecreton @Phaedrux
                            @Phaedrux i doesn't work bc when i send M552 S1 P0.0.0.0, it answers with just ok, and when i send M552, i can see that it gave 0.0.0.0 as an ip address
                              How do you have the Duet connected to your network?
                              Does the network cable you have going to the Duet work if you try to connect it to a computer?
                              zecretonundefined Phaedruxundefined 2 Replies Last reply Reply Quote 0
                              • zecretonundefined
                                zecreton @Phaedrux
                                @Phaedrux it is plugged with a ethernet cable in the router
                                  Phaedrux Moderator @Phaedrux
                                  @Phaedrux said in No movement with any command:
                                  zecretonundefined 3 Replies Last reply Reply Quote 0
                                  • zecretonundefined
                                    zecreton @Phaedrux
                                    @Phaedrux yea sorry i didn't have the time to check, do you have the guide?
                                    • zecretonundefined
                                      zecreton @Phaedrux
                                      @Phaedrux nvm i don't know what was the problem but i just powered it on and thew ethernet works fine
                                      • zecretonundefined
                                        zecreton @Phaedrux
                                        @Phaedrux i tested with a multimeter and i can see that in the driver entry, the pul and dir are receiving power, but not the enable, and on the output i don't know what to test
                                          Enable is low by default. Your drivers seem to require a high signal.
                                          https://docs.duet3d.com/en/User_manual/Connecting_hardware/Motors_connecting_external#configuring-the-enable-polarity
                                          See here for changing the enable polarity.
                                          • zecretonundefined
                                            zecreton @Phaedrux
                                            @Phaedrux yea i already changed it to high
