Duet not connect in anyways - Clue: nozzle fan always on
@droftarts said in Duet not connect in anyways - Clue: nozzle fan always on:
The firmware needs to be flashed to the board itself. If it has been erased (and it looks like it has), you will need to flash it with BOSSA, see https://docs.duet3d.com/User_manual/RepRapFirmware/Updating_firmware#all-other-duet-boards
@droftarts ok, I tried and finally now I can homing the axis. But the board still not connect to wifi connection.
Following the M122 report. What should I do now?
M122
RepRapFirmware for Duet 2 WiFi/Ethernet version 3.4.6 (2023-07-21 14:08:28) running on Duet WiFi 1.02 or later
Board ID: 0JD0M-9P6M2-NW4SN-6J1DG-3SD6J-TUT3L
Used output buffers: 1 of 26 (2 max)
Static ram: 23896
Dynamic ram: 75148 of which 0 recycled
Never used RAM 12964, free system stack 134 words
Tasks: NETWORK(ready,7.8%,517) HEAT(notifyWait,0.0%,317) Move(notifyWait,0.0%,304) MAIN(running,91.1%,440) IDLE(ready,1.0%,30), total 100.0%
Owned mutexes: USB(MAIN)
Last reset 00:01:29 ago, cause: power up
Last software reset at 1988-01-29 20:06, reason: HardFault undefInstr, Platform spinning, available RAM 106152, slot 0
Software reset code 0x4860 HFSR 0x40000000 CFSR 0x00010000 ICSR 0x00000803 BFAR 0xe000ed38 SP 0x2001ffa0 Task none Freestk 232 bad marker
Stack: 00000002 004100b1 200016d4 20000064 00000000 004104fb 00465fa4 01000000 ffffffff ffffffff ffffffff ffffffff ffffffff ffffffff ffffffff ffffffff ffffffff ffffffff ffffffff ffffffff ffffffff ffffffff ffffffff ffffffff ffffffff ffffffff ffffffff
Error status: 0x00
Aux0 errors 0,0,20
Step timer max interval 0
MCU temperature: min 27.4, current 34.4, max 34.4
Supply voltage: min 24.0, current 24.1, max 24.3, under voltage events: 0, over voltage events: 0, power good: yes
Events: 0 queued, 0 completed
Driver 0: standstill, SG min 0
Driver 1: standstill, SG min 117
Driver 2: standstill, SG min n/a
Driver 3: standstill, SG min n/a
Driver 4: standstill, SG min n/a
Driver 5:
Driver 6:
Driver 7:
Driver 8:
Driver 9:
Driver 10:
Driver 11:
Cache data hit count 3031027083
Slowest loop: 6.60ms; fastest: 0.20ms
=== Storage ===
Free file entries: 10
SD card longest read time 3.3ms, write time 0.0ms, max retries 0
DMs created 83, segments created 3, maxWait 17060ms, bed compensation in use: none, comp offset 0.000
=== MainDDARing ===
Scheduled moves 5, completed 5, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1
=== AuxDDARing ===
Segments left: 0
Movement lock held by null
HTTP is idle in state(s) 0
Telnet is idle in state(s) 0
File is idle in state(s) 0
USB is ready with "M122" in state(s) 0
Aux is idle in state(s) 0
Trigger is idle in state(s) 0
Queue is idle in state(s) 0
LCD is idle in state(s) 0
Daemon is idle in state(s) 0
Code queue is empty
=== Network ===
Slowest loop: 1.03ms; fastest: 0.01ms
Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0)
HTTP sessions: 0 of 8
= WiFi =
Interface state: starting2
Module is disabled
ok -
@genioluiz7 From M122, the WiFi has not started up:
= WiFi = Interface state: starting2 Module is disabled Failed messages: pending 0, notready 0, noresp 0 Socket states: 0 0 0 0 0 0 0 0 ok
Send
M552 S1
and see if it reports any status change.If not, you'll need to reflash the WiFi firmware. Fortunately, this is easy. First, make sure you have the 'DuetWiFiServer.bin' file on the SD card. It will be either in the /firmware folder, or in the /sys folder. You can check this on the Duet by sending
M20 P"/firmware"
andM20 P"/sys"
. If it isn't in either, you'll need to copy it onto the SD card, into the /firmware folder, from the 3.4.6 zip file.If it is in the /firmware folder, send
M997 S1
. If it is in the /sys folder, sendM997 S1 P"/sys/DuetWiFiServer.bin"
. This should flash the firmware to the Wifi module. Then sendM552 S1
and see if the WiFi module turns on.After that, you may need to set up the WiFi again. See https://docs.duet3d.com/en/How_to_guides/Getting_connected/Getting_connected_to_your_Duet#h-5-connect-duet-to-network
@droftarts this is what happened
M552 S-1
WiFi module stopped
ok
M552
WiFi module is disabled
ok
M552 S0
ok
M552
WiFi module is being started
ok
M552
ok
M552 S1
Turn off the current WiFi mode before selecting a new one
ok
M552 S-1
WiFi module stopped
ok
M552 S0
ok
M552
ok
M587 S"Ditaranto_living" P"mozzarella55"
Error: M587: Failed to add SSID to remembered list: SPI timeout
ok
M20 P"/firmware"
Begin file list
Duet2CombinedFirmware.bin
Duet2Firmware_SBC.bin
Duet2_SDiap32_Maestro.bin
Duet2_SDiap32_WiFiEth.bin
Duet3Firmware_EXP1HCL.bin
Duet3Firmware_EXP1XD.bin
Duet3Firmware_EXP3HC.bin
Duet3Firmware_MB6HC.bin
Duet3Firmware_MB6XD.bin
Duet3Firmware_Mini5plus.uf2
Duet3Firmware_TOOL1LC.bin
Duet3_SDiap32_MB6HC.bin
Duet3_SDiap32_MB6XD.bin
Duet3_SDiap32_Mini5plus.bin
DuetMaestroFirmware.bin
DuetWiFiModule_32S3.bin
DuetWiFiServer.bin
End file list
ok
M20 P"/sys"
Begin file list
bed.g
cancel.g
config-override.g
config.g
config.g.bak
config.json
deployprobe.g
Duet2CombinedIAP.bin
Duet3_SDiap_MB6HC.bin
DuetMaestroIAP.bin
DuetWiFiServer.bin
dwc-settings.json
favicon.ico.gz
heightmap.csv
homeall.g
homedelta.g
homex.g
homey.g
homez.g
iap4e.bin
index.html.gz
manifest.json.gz
pause.g
precache-manifest.319c6f973151dddcc9a89a7350cae2bc.js.gz
resume.g
retractprobe.g
service-worker.js.gz
sleep.g
stop.g
tfree0.g
tpost0.g
tpre0.g
resurrect.g
End file list
ok
M997 S1
T:180.0 /0.0 T0:180.0 /0.0 B:50.0 /0.0
Trying to connect at 230400 baud: failed
Trying to connect at 115200 baud: failed
Trying to connect at 74880 baud: failed
Trying to connect at 9600 baud: failed
Error: Installation failed due to comm write error
ok
T:144.0 /0.0 T0:144.0 /0.0 B:47.4 /0.0
ok -
The .bin is in the SD card but the command I sent didn't produce the expected result
@genioluiz7 The last command you sent was M552 S0, which tries to turn the WiFi module on but in idle mode. You need to turn it off again with
M552 S-1
, then runM997 S1
.Ian
You need to turn it off again with M552 S-1, then run M997 S1.
I do it. Tell me what you think
This the results:
M552 S-1
WiFi module stopped
ok
M552
ok
M552 S0
ok
M552
ok
M552 S-1
WiFi module stopped
ok
M997 S1
T0:21.5 /0.0 B:23.0 /0.0
ok -
@genioluiz7 Can you comment out the M552 in config.g? I think it's stuck trying to start the WiFi module. Then reset the Duet, connect via USB and serial terminal, then send M997 S1 without sending any other M552 commands.
where I have to insert the comment M552? Please, can you specify more prcisely what I've to edit in config.g?
I'll post you my config.g here; Configuration file for Duet WiFi (firmware version 3.3)
; generated by RepRapFirmware Configuration Tool v3.3.16 on Fri Aug 04 2023 19:59:42 GMT+0200 (Ora legale dell’Europa centrale); General preferences
M550 P"Chiron" ; set printer name; Network
M552 S1 ; enable network
M586 P0 S1 ; enable HTTP
M586 P1 S0 ; disable FTP
M569 P0 S0 ; physical drive 0 goes backwards
M569 P2 S0 ; physical drive 2 goes backwards
M569 P4 S0 ; physical drive 4 goes backwards
M584 X0 Y1 Z2:4 E3 ; set drive mapping
M92 X80.00 Y100.00 Z400.00 E420.00 ; set steps per mm
M566 X900.00 Y900.00 Z10.00 E120.00 ; set maximum instantaneous speed changes (mm/min)
M906 X1000 Y1000 Z1000 E900 I30 ; set motor currents (mA) and motor idle factor in per cent
M84 S0 ; Disable motor idle current reduction; Axis Limits
M208 X-15 Y-15 Z0 S1 ; set axis minima
M208 X400 Y400 Z440 S0 ; set axis maxima; Endstops
M574 X1 S1 P"!xstop" ; configure switch-type (e.g. microswitch) endstop for low end on X via pin xstop
M574 Y1 S1 P"!ystop" ; configure switch-type (e.g. microswitch) endstop for low end on Y via pin ystop
M574 Z1 S1 P"zstop+e1stop" ; configure active-high endstop for low end on Z via pin zstop and e1stop; Z-Probe
M558 P0 H5 F120 T6000 ; disable Z probe but set dive height, probe speed and travel speed
M557 X15:385 Y15:385 S120 ; define mesh grid; Heaters
M143 H1 S285 ; set temperature limit for heater 1 to 285C; Fans
M911 S10 R11 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; set voltage thresholds and actions to run on power loss -
@genioluiz7 said in Duet not connect in anyways - Clue: nozzle fan always on:
By comment out, I mean 'stop that command running'. So here:
... ; Network M552 S1 ; enable network M586 P0 S1 ; enable HTTP M586 P1 S0 ; disable FTP M586 P2 S0 ; disable Telnet ...
put a
at the beginning of the M552 line, eg:... ; M552 S1 ; enable network ...
@droftarts
Many thanks. Ok. Is it correct? (See the code below)After do that, how can I upload the edited config.g from the SD card to the board?
M586 P2 S0 ; disable Telnet -
@genioluiz7 Yes, that's correct. If you edited it on the SD card, that's all you need to do. If you edited config.g on your PC, then you need to copy it to the SD card. Then replace the SD card in the Duet and reset.
The config.g file is read by the Duet at start up. It shouldn't now try to turn on. Connect via USB and send M997 S1.
If the WiFi updates correctly, and sending M552 S1 turns it on (check with M122), then you will need to edit config.g to enable networking at start up, by removing the
from the M552 S1 line.Ian
@droftarts nothing. It didn't work. How we proceed now?
M997 S1
T0:20.6 /0.0 B:20.9 /0.0
ok
M122
Static ram: 23896
Never used RAM 13036, free system stack 193 words
Tasks: NETWORK(ready,26.2%,384) HEAT(notifyWait,0.0%,333) Move(notifyWait,0.0%,363) MAIN(running,73.2%,460) IDLE(ready,0.5%,30), total 100.0%
Last reset 00:02:30 ago, cause: reset button or watchdog
Last software reset time unknown, reason: User, GCodes spinning, available RAM 9748, slot 2
Error status: 0x00
Aux0 errors 0,0,0
MCU temperature: min 29.7, current 34.6, max 34.9
Supply voltage: min 1.6, current 1.7, max 1.8, under voltage events: 0, over voltage events: 0, power good: no
Driver 0: ok, SG min n/a
Driver 1: ok, SG min n/a
Driver 2: ok, SG min n/a
Driver 3: ok, SG min n/a
Driver 4: ok, SG min n/a
Driver 5:
Driver 6:
Driver 7:
Driver 8:
Driver 9:
Driver 10:
Driver 11:
Slowest loop: 14.09ms; fastest: 0.14ms
=== Storage ===
SD card longest read time 3.9ms, write time 0.0ms, max retries 0
DMs created 83, segments created 0, maxWait 0ms, bed compensation in use: none, comp offset 0.000
=== MainDDARing ===
=== AuxDDARing ===
Segments left: 0
Code queue is empty
=== Network ===
Slowest loop: 1001.24ms; fastest: 0.00ms
= WiFi =
Interface state: disabled
Module is disabled
ok -
@genioluiz7 I'm not sure. Try sending
M552 S0
to put it in idle mode, thenM997 S1
.If that doesn't work, I think whatever event caused the firmware to be deleted in the first place may have damaged the WiFi module. Looking back at the first M122 report you posted, it says:
We have found "HardFault undefInstr" (undefined instructions) are quite often associated with ESD (static discharge) events.
@droftarts So, how can I verify this?
I saw during the tests that the blu led on the wifi module sometimes flashes. Maybe is a signal that it is still alive
There is somenthing else we can try to do? -
@genioluiz7 did you try using M997 S1 to reinstall the WiFi firmware?
@dc42 yes I tried but nothing happened. What do you think?
@genioluiz7 I've read back through the forum thread, and it does seem that the WiFi module has failed. Because the firmware on the Duet was also erased, I'd suspect either a wiring short or ESD "static electricity" shock has caused it to fail. The way that the Duet circuit is designed is that short circuits to the 3.3V rail are first absorbed by the SD card holder and WiFi module, hopefully before the main processor, so that they fail first. They are easier to replace than the main processor.
Most likely you will need to replace the WiFi module. If you can't do this yourself, there may be others local to you that can help, see https://forum.duet3d.com/topic/13875/community-repairs. Unfortunately Duet3D does not carry out these repairs itself. Otherwise, I think you will need to replace the Duet board.
@droftarts, I've replaced the WiFi module. Now what have I to do?
I post a picture of the LEDs that are on now.
@genioluiz7 flash it using M997 S1
@jay_s_uk as you can see the 'diag' light is on, between the SD card and USB.
So I follow the next instruction you send me previous in this conversation:
On Duet 2, in normal operation:- the DIAG LED will turn on as power is applied, then turn off as soon as the firmware starts loading, usually less than 0.5 second.
- In normal operation, it will turn back on if the probe type is set to M558 P1 in config.g. Removing the SD card and resetting should switch it off. Apart from this case, the DIAG LED should normally be off.
- Errors in config.g may cause the Duet to get stuck in a boot loop, which will cause the DIAG LED to be on permanently. Remove SD card and reset.
- If the reset button is stuck in (rare), or has been mounted so it is pushed in by an enclosure, the Duet will get stuck in a boot loop, which will cause the DIAG LED to be on permanently. Check there is clearance around the reset button, or use some tweezers to gently pull the button out.
- If the firmware has been erased the DIAG LED will be on permanently.
Diag LED still on
I tried also to flash it with BOSSA, with the erase pin but the LED doesn't turn off.
Now when I connect via USB the YAT software doesn't detect the COM10
