    Multiple motion system
    69
    2.6k
    • Alvaundefined
      Alva @gloomyandy
      @gloomyandy Okay, I will wait for the release then. Thank you
        droftarts administrators @Alva
        @Alva It is available now: https://github.com/Duet3D/RepRapFirmware/releases/tag/3.6.0-beta.2
        Alvaundefined 1 Reply Last reply Reply Quote 0
        • Alvaundefined
          Alva @droftarts
          • daemon(2).g
          • mini(1).gcode
            Hello , i have updated the machine to 3.6.0.beta2 and tried a simple logic as seen in the mini-1.gcode which is attached. while it starts the print i manually set the flag to enable the daemon.g and the daemon.g is also attached. And the same error occurred again. 😞 Do you think there is something wrong with the way that i understood the second motion system? or am i doing something wrong? weird that my logic worked in 3.5. fw version.
            Please let me know. Thank you. 🙂
          • Alvaundefined
            Alva @Alva
            @Alva Looks like there was a mistake in the 3.6.0.beta2 release and David updated the new one today. I will try out that one.
            dc42undefined 3 Replies Last reply Reply Quote 0
              dc42 administrators @Alva
              @Alva here are a couple of clarifications:
              • When you select a tool (which becomes the current tool for the current motion system), the axes that X and Y are mapped to for that tool become owned by the current motion system.
              • It's fine to drive the two motion systems from different GCode streams.
                @Alva I just noticed this in your mini(1).gcode file:
                G4 P0 S0.5
                You should use either P or S in G4, not both. Similarly in daemon.g. However, this doesn't explain the error.
                  @Alva my best guess is that the move G1 X0 Y0 U0 in mini(1).gcode hasn't completed when daemon.g starts commanding U axis motion. This shouldn't be possible, because if U hasn't finished moving then U should still be owned by MS0, so the attempt to move it in daemon.g should fail with the "axis already owned by another MS" message. I'll check the M400 code.
                  • Alvaundefined
                    Alva @dc42
                    @dc42 I have edited the code and logic a bit. Found different cases:
                    ; File Name: 		/sys/daemon.g
                    if(!exists(global.daemonStop))
                    	global daemonStop = false	; Set to 1 to stop the daemon.g, it can be use to upload a new daemon.g file
                    while( global.daemonStop == false )
                        if(state.status== "processing")
                            G91
                            M596 P1
                            G1 U5 F300
                            M596
                        G4 P0
                    M99; Exit
                    test_2nd_MS.gcode
                    7add628d-3f09-4e4c-ac6e-54d79d08056d-image.png .
                    This happened when i activated the daemon before the move to X0 Y0. But if i activate the daemon after that then it works perfectly. Cannot relate whats going on.
                    set global.daemonStop = true ; stopped the daemon
                    M118 S{"starting to move"}
                    G90
                    G1 X0 Y0
                    M400 S1
                    G91
                    set global.daemonStop = false ; activated the daemon which only use U axis
                    G1 X100 Y100 F200
                    M400 S1
                    G90
                    M118 S{"move done"}
                    M99
                    • Alvaundefined
                      Alva @Alva
                      • Alvaundefined
                        Alva @Alva
                        @Alva Looks like it is a timing problem or something.
                          @Alva thanks, I will try to replicate it.
                          • Alvaundefined
                            Alva @dc42
                            @dc42 Thank you 🙏
                              @Alva I have reproduced this and I am looking into it.
                                @Alva I created https://github.com/Duet3D/RepRapFirmware/issues/1064 and I am testing a fix.
                                dc42 created this issue in Duet3D/RepRapFirmware
                                closed Use of multiple motion systems causes Code 3 halts in 3.6 beta1 and beta2 releases #1064
                                  @Alva please try the new Duet 3 Mini firmware binary at https://www.dropbox.com/scl/fo/pasag1g18orahwvn49qp2/ABWgw6D-TyKWxxurTmGwiUE?rlkey=r9h3rjyw1l4wh7xbr8yho37gw&dl=0.
                                  • Alvaundefined
                                    Alva @dc42
                                    @dc42 It seems to be working. I have tried all the above conditions and works as intended. Can i expect the same fix for Duet3 6HC board as well, as i observed the same behavior in it as well. Thank you 🙂
                                      @Alva I have just put a 6HC build at the same location.
                                      • Alvaundefined
                                        Alva @dc42
                                        @dc42 Thank you , I will check it out
                                          T3P3Tony administrators @Alva
                                          @Alva please can you confirm if you have tested this.
                                          • Alvaundefined
                                            Alva @T3P3Tony
                                            @T3P3Tony Hello sorry, i haven't checked it out. The 6HC board i have is bit different from the original version. So i need to build it differently. I am actually waiting for the beta 3 version of the firmware now.
