    Sovol SV08 Multiple Motion System Upgrade.
    My Duet controlled machine
    8
    255
    29.7k
      jay_s_uk @dwuk3d
      @dwuk that's one for @dc42 to look at then with sensorless homing on CAN boards being a new feature
        droftarts administrators @dwuk3d
        @dwuk said in Sovol SV08 Multiple Motion System Upgrade.:
        The other issue is the fact that after quite a few goes at trying to get sensorless homing working on the 2nd Gantry (the U & V axis) I have found out that it doesn't work on Mini5+'s used as a tool board - even with the latest 3.6 firmware.
        I thought the 3.6.0-beta.3 release had it partially working on the Mini5+ as-expansion, possibly only on drivers 0, 1 and 5. I’ve been testing this, and @dc42 has supplied me with fixed firmware that fully works. Let me know if you would like to try it.
          dc42 administrators @dwuk3d
          There's a build at https://www.dropbox.com/scl/fo/bx70c7u0bshq79ez83mnn/AKMj4UCEimtQuGYxRj_d0ew?rlkey=7yiq3x5fcae3v2ogslfocx1op&dl=0 in which this is fixed.
          dwuk3dundefined 2 Replies Last reply Reply Quote 0
          • dwuk3dundefined
            dwuk3d @dc42
            @dc42 Thanks will try that out this afternoon - will use sensorless just for testing purposes - and move over to switches at some point.
            • dwuk3dundefined
              dwuk3d
              Good progress made on wiring up first extruder.
              Main issues I faced were:
              1. Sizes of connectors - 95% of the Sovol connectors are tiny 1.25mm Female, and most of the Duet are 2mm Female. So made up some adaptors 1.25mm Male to 2mm Female - found a nice kit with pre-crimped 1.25mm wires and sockets and plugs.
              Didn't want to cut off existing connectors as may want to go back, plus wires a bit short to reach board too.
              1. Inductive Probe 24V power - ended up splicing in an extra plug on the VIN power feed - but not ideal as it means two plugs to disconnect
              2. Blower fans - The extruder has two - one of which is 3 pin and the other 2 pin - so wired them together, and - with VOUT and Tacho In on Out_2. and GND from unused IO1.
              3. Heater power is a 2mm Female - whereas the 1LC is a screw connector. Didn't have any 2 way Male Sockets - so cut down 5 way temporarily - have order some pre-crimped from the same place as the 1.25mm ones as a more permanent solution. Also had trouble getting the crimped cable to fit into the screw connector.
              Overall though - ready for a test this afternoon.
              Wiring still a bit messy - and adaptors longer than they need to be - but not 100% where I am going to end up placing the 1LC board - so left them long for now.
              0466238B-41BA-46A1-8B65-8F9E8F856DC7.jpeg A6BB9C7C-8480-4FDB-8BE4-52D1A4F30ADB_1_102_o.jpeg
              • dwuk3dundefined
                dwuk3d @dc42
                @dc42 Thanks tried firmware but couldn't get it to work. I got a message about changing to StealthChop - which I did for the two drivers on the Mini5+ - everything else is on Spreadcycle.
                Then it just kept saying that my speed was either too fast or too slow.
                Reread the documentation here a few times - but can't really figure out what I need to change to get it to work.
                Current relevant settings are:
                ; Smart Drivers
                M569 P0.0 S1 D2 ; driver 0.0 goes forwards (Z axis)
                M569 P0.1 S1 D2 ; driver 0.1 goes forwards (Z axis)
                M569 P0.2 S0 D2 ; driver 0.2 goes backwards (Z axis)
                M569 P0.3 S1 D2 ; driver 0.3 goes forwards (X axis)
                M569 P0.4 S0 D2 ; driver 0.4 goes backwards (Y axis)
                M569 P0.5 S0 D2 ; driver 0.5 goes backwards (Z axis)
                M569 P1.0 S0 D3 V2000 ; driver 1.0 goes backwards (U axis)
                M569 P1.1 S0 D3 V2000 ; driver 1.1 goes backwards (V axis)
                M569 P121.0 S1 D2 ; driver 121.0 goes forwards (extruder 0)
                ; Motor Idle Current Reduction
                M906 I30 ; set motor current idle factor
                M84 S30 ; set motor current idle timeout
                ; Axes
                M584 X0.3 Y0.4 Z0.1:0.2:0.0:0.5 U1.0 V1.1 ; set axis mapping
                M350 X16 Y16 Z16 U16 V16 I1 ; configure microstepping with interpolation
                M906 X800 Y800 Z800 U800 V800 ; set axis driver currents
                M92 X80 Y80 Z533.33 U80 V80 ; configure steps per mm
                M208 X0:200 Y0:200 Z0:200 U0:200 V0:200 ; set minimum and maximum axis limits
                M566 X900 Y900 Z12 U900 V900 ; set maximum instantaneous speed changes (mm/min)
                M203 X6000 Y6000 Z180 U6000 V6000 ; set maximum speeds (mm/min)
                M201 X500 Y500 Z20 U500 V500 ; set accelerations (mm/s^2)
                M574 X2 S3 ; configure X axis endstop
                M574 Y1 S3 ; configure Y axis endstop
                M574 Z1 S4 ; configure Z axis endstop
                M574 U2 S3 ; configure U axis endstop
                M574 V1 S3 ; configure V axis endstop
                ; Custom settings
                M915 X Y U V R0 F0
                ; homeu.g
                ; called to home the U axis
                ; generated by RepRapFirmware Configuration Tool v3.5.10 on Thu Jan 23 2025 15:02:10 GMT+0000 (Greenwich Mean Time)
                M913 U40 V40
                M400
                ; increase Z
                G91 ; relative positioning
                G1 H2 Z5 F12000 ; move Z relative to current position to avoid dragging nozzle over the bed
                G90 ; absolute positioning
                ; home U
                var maxTravel = move.axes[0].max - move.axes[0].min + 5 ; calculate how far X can travel plus 5mm
                G1 H1 U{var.maxTravel} F2000 ; coarse home in the +U direction
                G1 U-5 F6000 ; move back 5mm
                G1 H1 U{var.maxTravel} F700 ; fine home in the +U direction
                ; decrease Z again
                G1 H2 Z-5 F6000 ; move Z relative to current position
                M400
                M913 U100 V100
                M400
                  @dwuk please read https://docs.duet3d.com/en/User_manual/Connecting_hardware/Sensors_stall_detection. The TMC2209 drivers on the Mini5+ are quite finicky as regards getting stall detection to work. You need to at least reduce the M569 V parameter to a lower value (at least during stall homing) to avoid the "too slow" error message,
                  dwuk3dundefined 1 Reply Last reply Reply Quote 0
                  • o_lampeundefined
                    o_lampe @dwuk3d
                    Mirror or copy mode should work OK, but optical sensors are the best.
                    • dwuk3dundefined
                      dwuk3d
                      Progress update.
                      Upgraded Axis with proper Pulley Posts and Proper Linear Rail Carriage on the UV gantry.
                      Just need to upgrade UV gantry pulley posts.
                      The 5mm linear rail for the pulley posts was pretty hard to cut - had to use angle grinder.
                      All Axis working and Homing working on X,Y & Z.
                      I will pursue getting sensorless homing working on U & V - but will also install switches or optional sensors on X,Y,U & V before going too much further.
                      Z Inductive probe working with logic shifter - but waiting to see if there is a better solution.
                      Heated bed, Extruder and 2 of 3 fans all working - but I haven't done any heater tuning yet.
                      Next step tomorrow is to work out how to do Z Offets - as I followed the commissioning instructions - but it keeps setting Z to zero at the trigger height.
                      Will then do some distance and extrusion length calibration before hopefully trying my first print on the XYZ gantry tomorrow.
                      Next step after that and end stops is the upgrades to the 2nd Extruder on the UV gantry - which is currently still connected to the Klipper board. IMG_6630.JPG
                      • o_lampeundefined
                        o_lampe @dwuk3d
                        @dwuk One thing I noticed in an earlier picture was some scratching belts:
                        I thought it was just temporary, but it still seems a problem.
                        • dwuk3dundefined
                          dwuk3d @o_lampe
                          @o_lampe Well spotted - yes it is due to the extra IDEX carriage I left on the rear gantry.
                          If I take off the plastic coupler from the carriage there is a risk of the carriage falling off the end of the rail and I think it is that which is clashing with the belts.
                          For the IDEX phase I am going to need to move the pulley positions slightly forward to avoid the problem you spotted - but in the meantime I don't think it is causing any great issues other than limiting travel - but will find out when I do some more testing.
                          I am starting to think about Reprap IDEX kinematics -
                          I was pleasantly surprised to find that CoreXYUV seems to support two CoreXY gantries ok - but for IDEX on top of CoreXYUV I think I am going to have to work out how you define completely new Kinematics (if thats possible) otherwise it is going to end up with loads more fairly complicated post-processing.
                          I think what I would really need is to be able to have an X and 'x' axis for each gantry that I can specify both coordinates for in G0-G3 commands (or Macro replacements) I.e. For mirror mode / duplicate mode etc.- Rather than using a command to change the mode between Toolchange/Duplicate and Mirror - it should be fairly easy to work out and send two X coordinates in the same G0-G3 command to achieve the desired effect.
                          So what I will be looking for is something like CoreXxYUuV for dual gantry IDEX.
                          With .Zabcd - for the Z hoppers, and then finally. CoreXxYUuVy - for the occasionally moving bed phase (5).
                          My current thinking on IDEX too is that I will stick with the Ratrig VCore4 approach of two extra Y motors per gantry initially (although it would be nice to reduce this down to one extra per ganty) - but I think I will try putting them at the front rather than the back to help balance the weight on my flying gantries.
                          • dwuk3dundefined
                            dwuk3d @dc42
                            @dc42 Have spent a fair bit of time trying to get this sensorless homing on the tool board Mini5+ to work - I reduced V right down to 100 - but I still can't get it to accept a speed - it just keeps saying too slow or too fast - so will give up on this for now - and go back to adding switches.
                            I think I will add some switches directly on the extruder for the U/X Axis - to take advantage of the inputs available on the 1LC boards.
                            Have applied the Io1.in Z probe change to both extruders now and tidyed up the wiring on the two extruders a fair bit.
                            I think I need to get U & V end stops working properly - then 4 Z bed levelling working properly before I attempt my first print - as at present the rear axis seems to droop a bit - probably due to the 4 motors on it at the back.
                            • o_lampeundefined
                              o_lampe @dwuk3d
                              "Goodby toolchanger" then? Isn't there a way to distribute the steppers to the left and right, keeping the front available for extra tools? Steppers aren't exactly lightweight and you'll need some beefy motors to overcome the friction of the idler pulley-orgy.
                              I mentioned it before, but my hashPrinter only needed 4 motors for 4 semi-independent toolheads. The super simple gantry was the reason why I built it.
                              • dwuk3dundefined
                                dwuk3d @o_lampe
                                @o_lampe Yes would be good if I could get down to 4 motors for 4 heads.
                                May well explore other multi head options at some point - I guess the disadvantage of a hash printer is not easily being able to move heads not in use out of the way.
                                I think it will be easier though in terms of belt paths to keep with the double Y axis approach - with belts just going between the front and back.
                                Trying to keep to one extra motor per gantry would I think need the belts to run around both sides and either across the back or across the gantry.
                                I'm not thinking of putting motors side by side at the front - just on top or below - so I don't think it will affect tool changing.
                                On look at it a bit more closely I think on the bottom isn't going to work - so will just put one motor on the front top on each gantry - with the other two at the back.
                                • dwuk3dundefined
                                  dwuk3d
                                  End stops now working on U & V axis - so the next thing I need to work out is how to home Z - I have 2 x Z probes and depending on how the Flying Gantry has settled either one or the other triggers first.
                                  Ideally I would like a way of Z homing where it tries to home - and stops if either of the probes are triggered, perhaps with one gantry right at the front and the other at the back.
                                  I tried specifying both as switches in a M574 - but it didn't like it.
                                  Then I guess what I would like to do is then joggle around the front and rear Z axis motors until both probes trigger very close to each other.
                                  I can't work out how to do this at the moment, so in the meantime I think I will Z home on the rear probe, but move it is close to the front probe first - so that the front gantry doesn't hit the bed if it is lower.
                                  Will then try 4 Z motor adjustment.
                                  Probably also need to put in some basic method of avoid the heads or gantries being able to move in to each other in normal ad hoc moves if that's possible.0ED2B512-DD71-4717-BD68-681C8F556816.jpeg IMG_6638.JPG
                                  U & V end stops both put in the 1LC driver board - which saves on wiring - but does mean U has to be homed first - otherwise the V end stop won't hit the plate I setup for it.
                                  • dwuk3dundefined
                                    dwuk3d @dwuk3d
                                    @dwuk Upgrade PSU to a meanwell one - I can see why people seem to like them - its almost silent, rather than being really noisy like the previous one.
                                    I think I might be getting somewhere with my homing
                                    Based on here
                                    https://docs.duet3d.com/User_manual/Connecting_hardware/Z_probe_auto_levelling#axis-levelling-using-endstops
                                    I think I might have to split my 4xZ motors in to 2 separate AXIS (back and front), then move the two gantries to the back and front, then allocate the two probes to the two separated Z Axis, and then move down on both axis down at the same time - and hopefully it will move down until both probes are triggered.
                                    • dwuk3dundefined
                                      dwuk3d
                                      Think I have figured a way to get the Z motors level.
                                      Step 1 - Define an extra AXIS A in Config.g with same parameters as Z - but set to a dummy drive and switch.
                                      Step 2 - Align Back and Forward.
                                      Move front gantry to near front centre and rear gantry to near rear centre
                                      ;Set Z axis to Probe 0 - front gantry
                                      M574 Z1 S2 K0
                                      ;Set A axis to Probe 1 - rear gantry
                                      M574 A1 S2 K1
                                      ;Split Gantries - front and back
                                      M584 Z2:5 A0:1 P6
                                      ;Move both gantries down until they hit their probes
                                      G91
                                      G1 H1 Z-999 A-999
                                      Step 3 - Align Left and Right
                                      ; Now Move Gantries close to each other in the centre of the bed,
                                      ; Plus move rear gantry print head to near to the left and front to near to the right
                                      ; Resplit Axis - with A left and Z right
                                      M584 Z1:5 A0:2 P6
                                      ; Now Move down to end stops again
                                      G91
                                      G1 H1 Z-999 A-999
                                      ; Now all 4 z's are I think closer to alignment.
                                      Step 4 - Re Merge Z
                                      M584 Z1:2:0:5 P5
                                      • dwuk3dundefined
                                        dwuk3d
                                        Homing working -
                                        See short video demo
                                        https://youtube.com/shorts/oHtVsdHTPQc?si=w-lnOgmzNzxqfvRK
                                        Lots of refinements to do - but basic homing and 4 AXIS levelling done
                                        • dwuk3dundefined
                                          dwuk3d
                                          Tuned heaters today. The heads worked ok, got this from the print bed
                                          28/01/2025, 11:29:21 Warning: heater behaviour was not consistent during tuning
                                          Auto tuning heater 0 completed after 3 idle and 25 tuning cycles in 4667 seconds. This heater needs the following M307 command:
                                          M307 H0 R0.527 K0.163:0.000 D5.70 E1.35 S1.00 B0
                                          Edit the M307 H0 command in config.g to match this. Omit the V parameter if the heater is not powered from VIN.
                                          Will try using it anyway to see what happens.
                                          Also decided to try backing up settings today - tried various methods and ended up using FTP with VSCODE. Annoyingly I some how ended up losing my HomeX,Y,Z and All settings - so had to re do them.
                                          Improved the Z homing as part of this.
                                          Now ready to try some mesh levelling.
                                          • dwuk3dundefined
                                            dwuk3d
                                            Gradually getting there with bed levelling.
                                            Found my two probes trigger at slightly different heights, plus the nozzles are also at different heights too - so will add some manual adjustment capability in before trying first print.
                                            I can't get auto 4 axis calibration to work - it keeps saying it is not supported for the kinematics. I've tried coreXY too and it still says the same thing.
                                            So I have settled for now on probing and a level of auto adjustment in bed.g that seems to work.
                                            My HomeZ does still seem to mess up the gantry levelling, and I am getting some issues with probes getting stuck on in the software.
                                            But I think with this bed.g I now have a pretty flat Z axis after a few iterations.
                                            M671 X410:-60:-60:410 Y420:-10:420,-10
                                            M400
                                            while true
                                                G1 X300 Y200 F20000
                                                G30 P0 X300 Y200 Z-99999 ; probe near a leadscrew
                                                var adjust1 = (sensors.probes[0].lastStopHeight)
                                                G1 X20 Y20 F20000
                                                G30 P1 X20 Y20 Z-99999 ; probe near a leadscrew
                                                var adjust2 = (sensors.probes[0].lastStopHeight)
                                                G1 X20 Y200 F20000
                                                G30 P2 X20 Y200 Z-99999 ; probe near a leadscrew
                                                var adjust0 = (sensors.probes[0].lastStopHeight)
                                                G1 X300 Y20 F20000
                                                G30 P3 X300 Y20 Z-99999 S-1 ; probe near a leadscrew and calibrate 4 motors
                                                var adjust5 = (sensors.probes[0].lastStopHeight)
                                                echo var.adjust1, var.adjust2, var.adjust0, var.adjust5
                                                if (abs(var.adjust1) < 0.01 && abs(var.adjust2) < 0.01 && abs(var.adjust0) < 0.01 && abs(var.adjust5) < 0.01)   || iterations > 6
                                                    break
                                                G91
                                                if abs(var.adjust1) < 1
                                                    set var.adjust1 = var.adjust1 * 2
                                                if abs(var.adjust2) < 1
                                                    set var.adjust2 = var.adjust2 * 2
                                                    set var.adjust0 = var.adjust0 * 2
                                                    set var.adjust5 = var.adjust5 * 2
                                                M584 A1 P6
                                                G1 A{var.adjust1}
                                                M584 A2 P6
                                                G1 A{var.adjust2}
                                                M584 A0 P6
                                                G1 A{var.adjust0}
                                                M584 A5 P6
                                                G1 A{var.adjust5}
                                            M400
                                            G1 Z0 F2000
                                            G92 Z2.55
