    Help with new setup please
    541
    • troydemingundefined
      troydeming
      I just got a replacement duet wifi2 board and upgraded it to reprap 3.5 I am setting it up and am having difficulties getting the axis right. It isn't letting me home them. I have a Folgertech FT-5 with Duet wifi 2 board and a BLtouch. Any help is appreciated
      T3P3Tonyundefined troydemingundefined 3 Replies Last reply Reply Quote 1
      • T3P3Tonyundefined T3P3Tony referenced this topic
        T3P3Tony administrators @troydeming
        @troydeming we need ore information to help you, please see:
        https://forum.duet3d.com/topic/5909/guide-for-posting-requests-for-help
        troydemingundefined 1 Reply Last reply Reply Quote 0
          troydeming @T3P3Tony
          @T3P3Tony
          i tried to put in my config.g but it wont let me it says that I need more reputation first?
            troydeming @troydeming
            @troydeming
            Here is my config g
            ConfigdotG.txt
              @troydeming
              I am reposting your config.g here so its easier to read (use the </> button to post gcode etc so its formatted and easy to read:
              ; Accessories
              M575 P1 S0 B57600 ; configure PanelDue support
              M552 S1 ; configure WiFi adapter
              M586 P0 S1 ; configure HTTP
              ; Smart Drivers
              M569 P0 S1 D2 ; driver 0 goes Forwards(X axis)(s0- back s1-fwd)
              M569 P1 S1 D2 ; driver 1 goes Forwards (Y axis)
              M569 P2 S0 D2 ; driver 2 goes Backwards (Z axis)
              M569 P3 S0 D2 ; driver 3 goes Backwards (extruder 0)
              ; Motor Idle Current Reduction
              M906 I30 ; set motor current idle factor
              M84 S30 ; set motor current idle timeout
              ; Axes
              M584 X2 Y1 Z0 ; set axis mapping
              M350 X16 Y16 Z16 I1 ; configure microstepping with interpolation
              M906 X800 Y800 Z800 ; set axis driver currents
              M92 X160 Y160 Z800 ; configure steps per mm
              M208 X0:300 Y0:300 Z0:400 ; set minimum and maximum axis limits
              M566 X900 Y900 Z12 ; set maximum instantaneous speed changes (mm/min)
              M203 X6000 Y6000 Z180 ; set maximum speeds (mm/min)
              M201 X500 Y500 Z250 ; set accelerations (mm/s^2)
              ; Extruders
              M584 E3 ; set extruder mapping
              M350 E16 I1 ; configure microstepping with interpolation
              M906 E800 ; set extruder driver currents
              M92 E420 ; configure steps per mm
              M566 E120 ; set maximum instantaneous speed changes (mm/min)
              M203 E3600 ; set maximum speeds (mm/min)
              M201 E250 ; set accelerations (mm/s^2)
              ; Kinematics
              M669 K0 ; configure Cartesian kinematics
              ; Probes
              M558 P9 C"^zprobe.in" H5 F120 T6000 ; configure BLTouch probe via slot #0
              G31 P500 X5 Y15 Z0.7 ; set Z probe trigger value, offset and trigger height
              M950 S0 C"exp.heater3" ; create servo #0 for BLtouch
              M574 X1 P"!xstop" S1 ; configure X axis endstop
              M574 Y1 P"!ystop" S1 ; configure Y axis endstop
              M574 Z1 S2 ; configure Z axis endstop
              ; Mesh Bed Compensation
              M557 X25:275 Y25:275 S40:40 ; define grid for mesh bed compensation
              ; Sensors
              M308 S0 P"bedtemp" Y"thermistor" A"Heated Bed" T100000 B4725 C7.06e-8 ; configure sensor #0
              M308 S1 P"e0temp" Y"thermistor" A"Nozzle" T100000 B4725 C7.06e-8 ; configure sensor #1
              M950 H0 C"bedheat" T0 ; create heater #0
              M143 H0 P0 T0 C0 S140 A0 ; configure heater monitor #0 for heater #0
              M307 H0 R2.43 D5.5 E1.35 K0.56 B1 ; configure model of heater #0
              M950 H1 C"e0heat" T1 ; create heater #1
              M143 H1 P0 T1 C0 S350 A0 ; configure heater monitor #0 for heater #1
              M307 H1 R2.43 D5.5 E1.35 K0.56 B0 ; configure model of heater #1
              ; Heated beds
              M140 P0 H0 ; configure heated bed #0
              M950 F0 C"fan0" ; create fan #0
              M106 P0 S0 L0 X1 B0.1 ; configure fan #0
              M950 F1 C"fan2" ; create fan #1
              M106 P1 S0 B0.1 H1 T45 ; configure fan #1
              M563 P0 D0 H1 F0 ; create tool #0
              M568 P0 R0 S0 ; set initial tool #0 active and standby temperatures to
              Try following this documentation:
              https://docs.duet3d.com/User_manual/Connecting_hardware/Sensors_endstops#test-endstop-switches
              and then:
              https://docs.duet3d.com/en/User_manual/Connecting_hardware/Sensors_testing
                @troydeming
                So when I try to home x using g29 x or hitting the home button or the home all button the x will move in the correct direction but stops after about 10 mm.
                • fcwiltundefined
                  fcwilt @troydeming
                  @troydeming said in Help with new setup please:
                  @troydeming
                  You don't use G29 to home, you use G28.
                  Please post your homing files AND be sure and use the </> tag to paste them right into your post so we can all see them without having to download files.
                    troydeming @fcwilt
                    @fcwilt
                    I meant to say g28 dont know why I said g29.
                    Here are the files
                    ; homex.g
                    ; called to home the X axis
                    ; generated by RepRapFirmware Configuration Tool v3.5.10 on Wed Jan 29 2025 19:21:26 GMT-0500 (Eastern Standard Time)
                    ; increase Z
                    G91 ; relative positioning
                    G1 H2 Z5 ; move Z relative to current position to avoid dragging nozzle over the bed
                    G90 ; absolute positioning
                    ; home X
                    var maxTravel = move.axes[0].max - move.axes[0].min + 5 ; calculate how far X can travel plus 5mm
                    G1 H1 X-300 F1800 ; coarse home in the -X direction
                    G1 X5 F6000 ; move back 5mm
                    G1 H1 X-300 F300 ; fine home in the -X direction
                    ; decrease Z again
                    G1 H2 Z-5 F6000 ; move Z relative to current position
                    ; homey.g
                    ; called to home the Y axis
                    ; increase Z
                    ; home Y
                    var maxTravel = move.axes[1].max - move.axes[1].min + 5 ; calculate how far Y can travel plus 5mm
                    G1 H1 Y-300 F1800 ; coarse home in the -Y direction
                    G1 Y5 F6000 ; move back 5mm
                    G1 H1 Y-300 F300 ; fine home in the -Y direction
                    ; decrease Z again
                    ; homez.g
                    ; called to home the Z axis
                    ; increase Z
                    ; home Z
                    var xCenter = move.compensation.probeGrid.mins[0] + (move.compensation.probeGrid.maxs[0] - move.compensation.probeGrid.mins[0]) / 2 - sensors.probes[0].offsets[0]
                    var yCenter = move.compensation.probeGrid.mins[1] + (move.compensation.probeGrid.maxs[1] - move.compensation.probeGrid.mins[1]) / 2 - sensors.probes[0].offsets[1]
                    G1 X150 Y150 F6000 ; go to bed centre
                    G30 ; probe the bed
                    troydemingundefined fcwiltundefined 2 Replies Last reply Reply Quote 0
                      @troydeming
                      I just saw the following error on startup.
                      Error in start-up file macro line 58: Pin name needed for switch-type endstop on Z axis
                        droftarts administrators @troydeming
                        That's due to this line:
                        Though I think you may have changed this from S2 to S1? Either way, it's not needed if you use the probe for homing the Z axis with G30, so delete the line, or comment out the line with ; at the beginning.
                        Are you still having problems with the X and Y axis homing? Maybe repost your config.g if you have made changes to it.
                        • fcwiltundefined
                          fcwilt @troydeming
                          @troydeming
                          I see you compute various values, example var.maxTravel, and then don't use them.
                          Did you at one time use them?
                          Now this is just me, my two cents, feel free to ignore because you don't talk to crazy folks - On all of my printers I install a Z end-stop sensor for homing Z, which means I don't have to home X and Y first, which must be done so the Z probe can be used for homing Z. Being able to home Z first also means, when homing X and Y, I don't need to jog Z out of the way with those G1 H2 moves, which under certain circumstances can drive Z against end of the axis, which makes unpleasant noises, which upset my dogs.
                            troydeming @droftarts
                            @droftarts Thank You for your help. The error stopped but I am still having the same issue with homing. Here is the current config.g
                            ;; Configuration file for RepRapFirmware on Duet 2 WiFi
                            ; generated by RepRapFirmware Configuration Tool v3.5.10 on Wed Jan 29 2025 19:21:22 GMT-0500 (Eastern Standard Time)
                            ; General
                            G90 ; absolute coordinates
                            M83 ; relative extruder moves
                            M550 P"Alumiman FT5 v3.5" ; set hostname
                            ; Accessories
                            ; Smart Drivers
                            ; Axes
                            M208 X-5:300 Y0:300 Z0:400 ; set minimum and maximum axis limits
                            ; Extruders
                            ; Kinematics
                            ; Probes
                            ;M574 Z1 S1 ; configure Z axis endstop
                            ; Sensors
                            ; Heated beds
                            M568 P0 R0 S0 ; set initial tool #0 active and standby temperatures to 0C
                            • fcwiltundefined
                              fcwilt @troydeming
                              @troydeming
                              Just to be sure we are all on the same page, what is the issue you are having with homing?
                                troydeming @fcwilt
                                @fcwilt
                                when I home x the carriage only moves 10-20 cm then it stops and the bed then rises 20 cm
                                • fcwiltundefined
                                  fcwilt @troydeming
                                  @fcwilt
                                  Can you jog each axis (X Y Z) separately from the DWC jog buttons?
                                  You can use this command to allow jogging axes that are not homed:
                                  M564: Limit axes
                                  Parameters
                                  Hnnn H1 = forbid movement of axes that have not been homed, H0 = allow movement of axes that have not been homed (firmware 1.21 and later)
                                  Snnn S1 = limit movement within axis boundaries, S0 = allow movement outside boundaries
                                  If you can jog each axis separately have you verified that jogging a certain amount from the DWC actually moves the axis that amount?
                                    troydeming @fcwilt
                                    @fcwilt
                                    Thank you for that I am able to jog them now. Now I found out that when I jog X the Z is moving. I double checked the wiring and its all correct. So now I am going down the rabbit hole of why the two are crossed in the mapping.
                                    I am showing right now.
                                    ;M584 X2 Y1 Z0 ; set axis mapping
                                    It seems right to me but is it?
                                      @troydeming
                                      I just looked it up and I have them configured backwards.
                                      • fcwiltundefined
                                        fcwilt @troydeming
                                        @troydeming
                                        That might make homing not work quite right.
                                          troydeming @fcwilt
                                          @fcwilt
                                          I got it working finally. Therre was a fault in the wiring.
                                          • Phaedruxundefined Phaedrux has marked this topic as solved
