    Like Z Banding
    1.3k
    • Ce72undefined
      Ce72 @Notepad
      @Notepad I might be going a bit off topic for the forum section, but this banding issue has only started since I refixed my beds Keenovo silicon heater with RTV. When I did this there was no signs of damage on the heater but there were areas of the heater not in contact when the bed where the adhesive had let go. I’m no electrician 😕 I have checked the resistance of my heater with a multimetre, and it read 67.2 ohms, working on UK mains being 240v with a 750w heater I worked out it should be around 76.8 ohms. Is this within margin of error?
      I carried out a number of M303 PID tunes on the heater letting it return back to room temperature each time. And got these results.
      Warning: heater behaviour was not consistent during tuning on all tests
      M307 H0 R0.845 K0.256:0.000 D5.16 E1.35 S1.00 B0
      M307 H0 R0.854 K0.400:0.000 D5.40 E1.35 S1.00 B0
      M307 H0 R0.862 K0.264:0.000 D5.29 E1.35 S1.00 B0
      M307 H0 R0.859 K0.301:0.000 D4.90 E1.35 S1.00 B0
      I’m wondering if these variations are signs of my heater dying? And could this be the route cause of the banding issue only showing up on the longer model prints rather than the short test prints?
      Any thoughts??
      Notepadundefined 1 Reply Last reply Reply Quote 0
      • Ce72undefined
        Ce72 @o_lampe
        @o_lampe I have tried a few different PA settings from 0.03 upto 0.08 and it had very little to no effect on the banding unfortunatly.
        • Notepadundefined
          Notepad @Ce72
          @Ce72 There is a possibility it could be the relay controlling the heater bed. If its an AC relay, they do tend to fail deadly if they get to hot
          The real bamboo printer manufacturer
          Ce72undefined 1 Reply Last reply Reply Quote 0
          • Ce72undefined
            Ce72 @Notepad
            @Notepad Thank you for posting back to me, I am not fully clued up with electronics, but my understanding is from what your saying is that the heater seems ok, but it could be the relay starting to fail causing the control fluctuation.
            I am not sure what you mean by fails deadly, I take it you mean open circuit? I am glad to say when I built the machine, I grounded both the metal bed plate and the relay down to the plug’s earth pin and not just the frame. I know not to take risks with the mains.
            The pic shows the relay I am using to clarify, and if that is the case I will replace it before switching the printer on again.
            droftartsundefined Notepadundefined 2 Replies Last reply Reply Quote 0
              droftarts administrators @Ce72
              @Ce72 Can you post your config.g?
              • Ce72undefined
                Ce72 @droftarts
                @droftarts I know theres a better way of doing this but I'm not sure how
                ; reconfigured HevORT V1 file for V2.8 on Sat Sep 14 2024
                ; Port Layout
                ;      Mainboard                       Ext board
                ;      0.0   Extruder                  1.0 Front Left
                ;      0.1   Y Back Left               1.1 Rear Middle
                ;      0.2   Y Front Right             1.2 Front Right
                ;      0.3   X Back Right
                ;      0.4   X Front Left
                G4 S2                                                   ; wait for expansion boards to start
                G90                                                     ; send absolute coordinates...
                M83                                                     ; ...but relative extruder moves
                M550 P"HevORT"                                          ; set printer name
                M669 K1                                                 ; select CoreXY mode
                ;M552 P0.0.0.0 S1                                       ; enable network and acquire dynamic address via DHCP
                ;M586 P0 S1                                             ; enable HTTP
                ;M586 P1 S0                                             ; disable FTP
                ;M586 P2 S0                                             ; disable Telnet
                M569 P0.0 S1                                            ; physical drive 0.0 goes forwards Extruder
                M569 P0.1 S1                                            ; physical drive 0.1 goes forwards Y1 stepper
                M569 P0.2 S1                                            ; physical drive 0.2 goes forwards Y2 stepper
                M569 P0.3 S1                                            ; physical drive 0.3 goes forwards X1 stepper
                M569 P0.4 S1                                            ; physical drive 0.4 goes forwards X2 stepper
                M569 P1.0 S1                                            ; physical drive 1.0 goes forwards Z1 stepper on extension board
                M569 P1.1 S1                                            ; physical drive 1.1 goes forwards Z2 stepper on extension board
                M569 P1.2 S1                                            ; physical drive 1.2 goes forwards Z3 stepper on extension board
                M584 E0.0 X0.3:0.4 Y0.1:0.2 Z1.0:1.1:1.2                ; set drive mapping
                M906 X2096. Y2096. Z1179. E995.6 I30                    ; set motor currents (mA) and motor idle factor in percent
                M917 X70 Y70 Z80 E70                                    ; Set motor standstill current reduction
                ;M970 X0 Y0 Z0 E0                                        ; Enable/disable phase stepping
                ;M970.1 X1000.0 Y2000.0 Z1000.0 E1000.0                  ; Configure phase stepping velocity constant
                ;M970.2 X50000.0 Y50000.0 Z50000.0 E50000.0              ; Configure phase stepping acceleration constant
                M84 S30                                                 ; set idle timeout
                M671 X-28.0:168.35:364.7 Y40.0:348.8:20.0 S10.          ; Z leadscrew positions
                M350 X16 Y16 Z16 E16 I1                                 ; configure microstepping with interpolation
                M92 X80.1 Y80.1 Z800.00 E394.00                         ; set steps per mm
                M203 X30000.00 Y30000.00 Z250.00 E1200.00               ; set maximum speeds (mm/min)
                M201 X20000.0 Y20000.0 Z50.00 E500.00                   ; set accelerations (mm/s^2)
                M204 P10000. T10000.                                      ; Max Acceleration
                M566 X900. Y900. Z60. E120.                             ; set maximum instantaneous speed changes (mm/min)
                M205 X15. Y15. Z1. E2.                                  ; set working instantaneous speed changes (mm/sec)
                M572 D0 S0.080                                          ; Preasure advance
                M208 X0 Y0 Z0 S1                                        ; set axis minimium
                M208 X285.0 Y295.0 Z340 S0                              ; set axis maximium
                M574 X1 S1 P"!io0.in"                                   ; configure active-high endstop for low end on X via pin !io0.in
                M574 Y1 S1 P"io1.in"                                    ; configure active-high endstop for low end on Y via pin !io1.in
                ; Z-Probes
                ; Probe 1 BL Touch
                M950 S0 C"io7.out"                                      ; create servo pin 0 for BLTouch
                M558 K0 P9 C"^io7.in" H10 F300:120 T6000                ; set Z probe type to bltouch and the dive height + speeds
                ;M558 H30                                               ;*** Remove this line after delta calibration has been done and new delta parameters have been saved
                G31 P500 X0. Y-35.09 Z1.65                              ; set Z probe trigger value, offset and trigger height
                ; Probe 2 Scanning Z probe
                M558 K1 P11 C"120.i2c.ldc1612" F36000 T36000            ; configure SZP as probe 1, type 11, on CAN address 120
                G31 K1 Z2.15 Y27.                                       ; define probe 1 offsets and trigger height
                M558.2 K1 S16 R134773                                   ; set drive current and reading offset
                M308 A"SZP coil" S10 Y"thermistor" P"120.temp0"         ; thermistor on coil
                M955 P120.0 I56                                         ; Add accelerometer on SZP with CAN address 120 and specify orientation
                M557 X10.0:275.0 Y35.0:285.0 S10                        ; define mesh grid
                ; Heaters & Sensors
                M308 S0 P"temp0" Y"thermistor" T100000 B3950            ; configure sensor 0 as thermistor on pin temp0               BED TEMP
                M950 H0 C"out0" T0                                      ; create bed heater output on out0 and map it to sensor 0
                M307 H0 R0.859 K0.301:0.000 D4.90 E1.35 S1.00 B0        ; BED HEATER PID SETTINGS
                M140 H0                                                 ; map heated bed to heater 0
                M143 H0 S135                                            ; set temperature limit for heater 0 to 120C
                M308 S1 P"temp1" Y"thermistor" T100000 B4725 C7.06e-8   ; configure sensor 1 as Termistor on pin temp1  EXTRUDER TEMP
                M950 H1 C"out1" T1                                      ; create nozzle heater output on out1 and map it to sensor 1
                M307 H1 R5.007 K0.417:0.603 D2.71 E1.35 S1.00 B0 V23.6
                ;M307 H1 R5.395 K0.416:0.839 D2.53 E1.35 S1.00 B0 V23.7  ; PID Tune
                M143 H1 S300                                            ; set temperature limit for heater 1 to 300C
                M308 S2 A"Chamber" P"temp2" Y"thermistor" T100000 B4138 ; configure sensor 0 as thermistor on pin temp2               CHAMBER TEMP SENSOR
                M308 S3 A"CPAP Pump" P"temp3" Y"pt1000" R2200           ; configure sensor 0 as thermistor on pin temp3               CPAP TEMP SENSOR
                M308 S11 Y"mcu-temp" A"MCU"                             ; defines sensor 10 as MCU temperature sensor                 MCU TEMP SENSOR
                ;M308 S12 Y"drivers" A"Stepper Drivers"                 ; defines sensor 11 as stepper driver temperature             STEPPER TEMP SENSOR
                M950 F0 C"1.out3"                                       ; create fan 0 on pin out3 on Expansion board                 PART COOLING FAN
                M106 P0 S0 X180 H-1                                     ; set fan 0 value. Thermostatic control is turned oFF
                M950 F1 C"out7" Q250                                    ; create fan 1 on pin out7 and set its frequency              EXTRUDER FAN
                M106 P1 S1 H1 T45                                       ; set fan 1 value. Thermostatic control is turned on
                M950 F2 C"!out5+out5.tach" Q250                         ; create fan 2 on pin out5 and set its frequency              MCU COOLING FAN
                M106 P2 H11 T45:60                                      ; set fan 2 value. Thermostatic control is turned on
                M950 F3 C"!out6+out6.tach" Q250                         ; create fan 3 on pin out6 and set its frequency              CHAMBER FAN
                M106 P3 H2 T30:35                                       ; set fan 3 value. Thermostatic control is turned on
                M563 P0 D0 H1 F0                                        ; define tool 0
                G10 P0 X0 Y0 Z0                                         ; set tool 0 axis offsets
                G10 P0 R0 S0                                            ; set initial tool 0 active and standby temperatures to 0C
                ; Axis Correction
                M556 S80 X0. Y0. Z0.                                    ; Axis Correction
                ; Input shaping
                M593 P"mzv" F45.0 S0.1                                  ; use ZVD input shaping to cancel ringing at 67.0Hz
        ; Shaping Options  "none" "zvd" "zvdd" "zvddd" "mzv" "ei2" "ei3"
                ;M593 P"none"                                           ; disable input shaping
                ; LED Settings
                ;M150 X1                                                ; Set LED Type      ( PRE 3.5.0 FORMAT)
                M950 E0 C"led" T1 U32                                   ; create a RGB Neopixel LED strip on the LED port    (3.5.0 FORMAT)
                M150 R255 U255 B255 P200 S10 F1                         ; Left side White
                M150 R31 U81 B255 P220 S11 F1                           ; Blue back
                M150 R255 U255 B255 P200 S10 F0                         ; Right side white
                M950 E1 C"io2.out" T1 U10                                  ; create a RGB Neopixel LED strip in Electric box on the io2 port
                M150 R255 U255 B255 P200 S10 F0                         ; Left side White
                T0        ; Call T0
                M501        ; load saved parameters from non-volatile memory
                • Notepadundefined
                  Notepad @Ce72
                  @Ce72 "Fail Deadly" is simply just the opposite of "Fail Safe". A failsafe relay would open the circuit stopping power from transferring. These SSR style relays all tend to faildeadly if they get too hot. Normally these relays run quite cold, but if its getting towards the EOL, there is a chance its accidently keeping the power on for too long causing heat based pulsing, similar to BangBang z banding. This would explain your PID tuning inaccuracies.
                  Its very unlikely as these relays are pretty robust, But I have had 2 personally die on me even when they are joined with the officially recommended W70 Passive Heatsink.
                  • Ce72undefined
                    Ce72 @Notepad
                    @Notepad Well, I have now changed the SSR, but I am still getting some fluctuation, but at least some are fault free. Here are the results:
                    M307 H0 R0.863 K0.260:0.000 D5.37 E1.35 S1.00 B0 XXXXXX
                    M307 H0 R0.875 K0.265:0.000 D5.36 E1.35 S1.00 B0 XXXXXX
                    M307 H0 R0.874 K0.346:0.000 D5.72 E1.35 S1.00 B0
                    M307 H0 R0.856 K0.307:0.000 D4.85 E1.35 S1.00 B0
                    M307 H0 R0.852 K0.301:0.000 D5.32 E1.35 S1.00 B0 XXXXXX
                    XXXXXX = Warning: heater behaviour was not consistent during tuning
                    My next step of thinking down this rabbit hole of fluctuation is, where I have used RTV to refix the silicon heater could the layer be too thick or uneven (It’s not easy stuff to work with) causing a slow transition of heat, resulting in a slow reaction that the PID loop is struggling with?
                    Does anyone know of anywhere in the UK, where I can get a good 330 x 330mm 240v high temp (I print a lot of ABS and the like) silicon heater. At a good price and quick delivery? As even Keenovo has started using a NTC 100K thermistor on there heaters which from what I understand can be a pain to setup and not that great for the higher temps.
                    • o_lampeundefined
                      o_lampe @Ce72
                      @Ce72 said in Like Z Banding:
                      Bed temps are pretty low compared to extruder temps. I don't see a problem here?
                      Whenever a NTC failed on me, it was a lousy crimpjob or broken thermistor leg from too much motion.
                      • Ce72undefined
                        Ce72 @o_lampe
                        @o_lampe Thank you for pointing that out, I have ordered a new heater, and when it's been installed I will post back here the results hopefully it will cure the banding issue.
                        • Ce72undefined
                          Ce72
                          So, this is now confusing, I have replaced the relay and fitted a new Silicon heater back to the original setup, which ran perfectly fine for 2 years. And when I run the PID tuning cycle I now constantly get:
                          M307 H0 R0.779 K0.208:0.000 D5.70 E1.35 S1.00 B0
                          M307 H0 R0.776 K0.270:0.000 D5.24 E1.35 S1.00 B0
                          M307 H0 R0.789 K0.265:0.000 D5.85 E1.35 S1.00 B0
                          M307 H0 R0.779 K0.247:0.000 D5.35 E1.35 S1.00 B0
                          M307 H0 R0.778 K0.257:0.000 D5.49 E1.35 S1.00 B0
                          Could it be the heater output on the mainboard? Is it possible to use a spare extruder output as I’m running through a relay? To test.
                          Has anyone got any suggestions?
                            @Ce72 Most likely is that the thermal pad's thermistor is too close to the heating element, so reads higher than the rest of the bed surface when the heater is on (localised hotter temperature), then cools quicker than expected as heat dissipates through the bed. This tends to make the heating cycles shorter as they go on, causing the inconsistent behaviour, and long tuning cycle.
                            However, the tuning numbers you're getting are all pretty close, I'd think choosing the median for each parameter would be fine. If it triggers heater errors when heating normally, you can manually adjust it, see https://docs.duet3d.com/User_manual/Connecting_hardware/Heaters_tuning#manual-adjustments-to-the-heater-model-parameters
                            • Ce72undefined
                              Ce72
                              Hi Ian thank you for pointing me in the right direction to set the PID tune.
                              Then I run some tests to see If the banding had finally gone, unfortunately not so I decided to run some other tests to see if I could isolate the problem or ever just work out what effects the banding pattern.
                              This is the first test print after changing the heater and SSR as well as retuning the extruder PID. banding is the same as before.
                              The next test I turned off the bed heater after the first couple of layers. To see if the banding was being affected by the bang-bang theory being caused by the bed heater but the banding was still the same. This left me wondering if it was a back to a mechanical issue the good old Z wobble as nothing electrical or extruder seemed to be affecting the outcome.
                              The last test I did after reimaging the pi (hey try anything at this point ) This time I resized the test model from a 40mm cube the a 80mm square by 25mm high same slicing profile as before but this time the banding was a lot closer together than before, To me me this eliminates a mechanical problem as the pattern frequence is so far away from the ball screw pitch.
                              As mentioned earlier in this thread I have also tried a diffent slicer, so it’s also not that 😕 I’m running out of things to try so any further suggestions from anyonre would be greatly appreciated
                              And sorry for the long post.
                              tasundefined 1 Reply Last reply Reply Quote 0
                              • tasundefined
                                tas @Ce72
                                @Ce72 Just to eliminate it as a possibility can you turn of Pressure Advance to see if there is any effect.
                                • Ce72undefined
                                  Ce72 @tas
                                  @tas Hi, Here's the result of of No PA
                                    I'm inclined to think it's a mechanical issue either in the extruder or Z axis.
                                    • mikeabuilderundefined
                                      mikeabuilder
                                      Here's a wild theory - there's some interaction between the bed heater and the extruder heater, such that when the bed heater turns on, the power to the extruder heater is reduced slightly, leading to small variations in the flow of plastic. If the duty cycle on the bed heater is regular, it could lead to a regular pattern in the output.
                                      It seems unlikely because the relay you pictured shows your bed is heated by AC. But maybe something on the control side is sinking too much current.
                                      You could test by monitoring the voltage and duty cycle to the extruder heater.
                                      • Ce72undefined
                                        Ce72 @mikeabuilder
                                        @mikeabuilder Hi, Thank you for your thoughts, but after going down the rabbit hole replacing the SSR and bed heater, I tried running a test print with the bed heater turned off to try and eliminate the bed heater and I still had the same results. but I'm not that clued up on electrics to know if that would negate any effects.
                                        • Ce72undefined
                                          Ce72 @Ce72
                                          @Ce72 Hi, thank you for your input and any suggested test are much appreciated. I have tried changing the extruder gears and that unfortunatly had no effect, as for z wobble I would have thought the pattern would be the same on all faces, but what I have noticed is that the pattern changes direction and not on opposite face so it just adds to my confusion 😕
                                            @Ce72 Are these printed square to the XY axis? If so, try printing at 45 degrees to XY. As your printer is a core XY, this isolates the movement of each motor. As it seems to change direction depending on which side it's on, I'd guess that it's actually something to do with either the X or Y axis. How are the second motors on each of the X and Y axes wired? Are they wired in series (or parallel) with each other, so each axis is running from one stepper driver, or is each XY motor wired to it's own stepper driver?
                                            Check all stepper motor pulleys are not moving on the stepper motor shaft, and that all motors are actually moving under power (ie no cabling issues). All motors should be exactly the same. Maybe post your config.g, and response to M122.
