Sovol SV08 Multiple Motion System Upgrade.
My Duet controlled machine
8
232
25.5k
    dwuk3d
    Managed to get Voron Tap type probing to work on the front gantry, and printing now working fairly well. Time now to return to the alignment probes.
    Electromagnet wired up - on Mini5+ 6A output - which has a flyback diode ok
    ; Electro Magnet
    M950 P4 C"1.out1"
    M42 P4 S0
    Magnet seems to work ok - and hold pliers on anything above S30
    Next on to Servo - decided to use on of these, as I have a few in stock
    Powering it with 6v for now - via a LM2596 Buck Converter from the main input PSU
    Tried it on io0 - but it didn't work as no PWM (although no error message).
    Switched to io1 and now working
    M950 S0 C"1.io1.out" ; Probe Servo
    M280 P0 S60 ; Set Servo
    Made hole in case to hold servo next to bed.
    F64B40A1-7775-4CF1-AF55-C8B39DE06F92_1_201_a.jpeg A54AAD31-F841-4A10-ACBE-91D0BCE7BCB0_1_201_a.jpeg
    3d printing of parts and macro's tomorrow.
    undefined 1 Reply Last reply 15 Mar 2025, 07:08 Reply Quote 1
      o_lampe @dwuk3d
      @dwuk3d Those digital servos can draw a lot of current. You'd not want to block the arm or run it above the spec'd angle or the buck converter might fail.
      undefined 1 Reply Last reply 15 Mar 2025, 21:13 Reply Quote 0
        dwuk3d @o_lampe
        @o_lampe Thanks - yes I was a little worried about that - I can't find it documented anywhere how much power the Servo uses.
        It goes up to 8.4 volts - so decided to keep it down to 6v, plus also am turning off the servo as soon as I have done any moves.
        Might switch to a geared stepper at some point
          dwuk3d
          Auto alignment with ball probe complete.
          Original plan was to use the electro magnet on the bed - but it is quite weak - despite specs being near to the permanent magnet that works very well.
          So switched to having the magnet off the bed grabbing a big circular plate.
          Not sure how much it is really needed.
          Also ordered a bigger magnet - but not sure if I will need to use it.
          Demo video of homing, levelling, deployment of probe and alignment attached.
          https://youtu.be/kpVAuKwoTiQ
          undefined 1 Reply Last reply 16 Mar 2025, 06:53 Reply Quote 1
            o_lampe @dwuk3d
            @dwuk3d Nice video, but I watched it without sound.
            The problem with any nozzle touch probes is, you have to make sure the surface is completely clean. (and conductive too?)
            I hope your homing macros are ready for "murphy's law"
            undefined 1 Reply Last reply 16 Mar 2025, 07:21 Reply Quote 0
              dwuk3d @o_lampe
              @o_lampe Thanks - sorry about the music - will have to get a bit more creative with that - and maybe think about some narration.
              Agreed about the nozzles needing to be clean, will have to add in some auto cleaning as part of my start up phase. I've put a cleaning pad on the swing out arm - but haven't done the automation for this yet.
              The ball probe is mechanical - so no worries about conductivity.
              I think my ultimate solution is likely to be a 3 stage approach - with the inductive probe or an eddy probe to find the ball probe and do some basic alignment, then using a cleaned nozzle pressing on the ball probe for a 2nd phase of alignment, with then a final check using the camera for fine adjustments,
              There is some software to do the camera based adjustments automatically - but I suspect that it will be hard to get that to work reliably too - especially in different lighting conditions and with different bits of waste on the nozzle.
              undefined 1 Reply Last reply 16 Mar 2025, 18:19 Reply Quote 0
                dwuk3d @dwuk3d
                @dwuk3d Added Nozzle cleaning into alignment process, also decided to start making use of Daemon.g for timeouts of things like magnets, servo's, hot ends - which seems to be working ok.
                Only issue is with the hot ends - where if the process is left on when a print is about to start then the daemon.g could drop in and switch tools - so will need to disable any tool based timers when prints are started.
                Example switch on Servo and Magnet - in Probe Deploy Macro.
                M42 P5 S1 ; Servo On
                if exists(global.servo5Off) == false
                global servo5Off = 0
                set global.servo5Off = state.upTime + 120
                M42 P4 S255 ; Magnet on
                if exists(global.magnetOff) == false
                global magnetOff = 0
                set global.magnetOff = state.upTime + 200
                Example Daemon.g
                ;daemon.g
                if global.servo5Off != 0 && global.servo5Off < state.upTime
                M42 P5 S0 ; Servo Off
                set global.servo5Off = 0
                echo "daemon.g servo5 switched off"
                if global.magnetOff != 0 && global.magnetOff < state.upTime
                M42 P4 S0 ; Magnet off
                set global.magnetOff = 0
                echo "daemon.g magnet switched off"
                if exists(global.T1Off)
                if global.T1Off != 0 && global.T1Off < state.upTime
                M596 P0
                T1
                M109 S0
                set global.T1Off = 0
                echo "daemon.g T1 switched off"
                if exists(global.T0Off)
                if global.T0Off != 0 && global.T0Off < state.upTime
                M596 P1
                T0
                M109 S0
                set global.T0Off = 0
                echo "daemon.g T0 switched off"
                undefined 1 Reply Last reply 18 Mar 2025, 08:50 Reply Quote 0
                  dwuk3d @dwuk3d
                  @dwuk3d Trying out various different options for head cleaner location while still waiting for Nema8 and Nema11 Z lifters to arrive.
                  Not sure whether to put the cleaner at the front of the gantry - so that it can be wiped in 2 dimensions,
                  or just on the end of the Y gantry - so can only be wiped in the X direction.
                  I suppose I could add another servo at the end of the Y gantry, or some sort of 3d printed mechanism to make the Y wiper move backwards and forwards a little bit.
                  Long thin arms working quite well on low Z heights - as they bend slightly rather than fouling on the bed.
                  93D9553A-0FF4-49E6-8768-03B06F873D23.jpeg 4B2F4CDE-36F2-47BA-8D7E-398DF3B744CB_1_102_o.jpeg
                  undefined 1 Reply Last reply 18 Mar 2025, 15:47 Reply Quote 0
                    dwuk3d @dwuk3d
                    @dwuk3d NEMA11 stepper arrived.
                    Doesn't work quite like I expected as there is a thread inside the motor - so the lead screw has to be held for the motor to move.
                    Also quite heavy and bit big - so think I will hold off until the lead screw NEMA8 arrives.
                    Motor size comparison
                      dwuk3d
                      I think Nema8 might end up working quite well for the Z hoppers.
                      Decided to try and create some sort of lead screw for the existing NEMA8 I got a few weeks ago.
                      Took quite a few iterations - but ended up doing my first ever 'captive print' - with an M4 Hex Headed Bolt captured inside a coupler print.
                      As its a bolt rather than lead screw then it is quite sloppy - but might be able to use that as a slight advantage as will hopefully be able to use a single optical end stop for both
                      a) The homing of the Nema8 based Z hopper
                      b) The X axis
                      c) Z Axis tapping too.
                      Have replaced Servo on the rear gantry with the Nema8 motor and it is looking good so far.
                      Comparison photo with the slow soon to be replaced front gantry stepper, rear gantry with almost completely installed NEMA8, with 3 way optical end stop below, plus the NEMA11 motor also included.
                      Had to move the 1LC tool board about 16mm to the left to accommodate the taller stepper/lead screw combination.
                      undefined 1 Reply Last reply 20 Mar 2025, 05:52 Reply Quote 0
                        o_lampe @dwuk3d
                        @dwuk3d said in Sovol SV08 Multiple Motion System Upgrade.:
                        Vertical slop is a 1st layer killer.
                        Although it might have advantages with other stuff, you sure don't want to risk bad adhesion to the bed.
                        Maybe you can add a spring to reduce backlash?
                        undefined 1 Reply Last reply 20 Mar 2025, 07:52 Reply Quote 0
                          dwuk3d @o_lampe
                          @o_lampe Thanks will try a spring over the bolt.
                          Will be interesting to compare the 'bolt' version with the proper lead screw Nema8 version I have ordered.
                            dwuk3d
                            Nema8 motor working quite well as a zlifter on rear gantry - so have ordered a few more for other extruders.
                            Will create a short video next showing use of a single optical endstop for U,A and Z Axis.
                            In the meantime - another interesting video from teaching tech with a comparison between Marlin, Klipper and RRF - with another little mention of this project in the RRF section about 9mins30 in.
                            https://youtu.be/fahU6UXl7g8?si=W7gJpKrv2_YfzKT-
                            undefined 1 Reply Last reply 22 Mar 2025, 09:15 Reply Quote 0
                              dwuk3d @dwuk3d
                              @dwuk3d Initially I was finding that the Nema 8 motors were not powerful enough to reliably lift the gantry.
                              The Non Lead screw one was I thought rated at 0.4a and the Lead Screw one at 0.24A.
                              However it looks like on further investigation that the Non lead Screw one is actually rated at 0.8A - and when I set it to 0.6A in Config.g it is working very reliably.
                              Before I found this out I ordered some smaller (28mm) Nema11-s however as the Nema8's look ok I have ordered two more of those too
                              Short video attached of Nema8 in operation, and also showing what may or may not be a good idea - using the same (very cheap) optical sensor for
                              1. MicroZ (A Axis)
                              2. U Axis
                              3. Z Axis tapping
                              In order to swap the 122.io2.in pin between the 3 axis - I found I had to first swap the other axis to dummy IO pins - so that they would release 122.io2.in - so that it could be assigned to the correct axis using M558 commands.
                              https://youtu.be/0jkH4YBIZDc
                                dwuk3d
                                Little time saver GCode command created,
                                M98.1 - For running Macro's - without needing to specify the full path, or .G suffix
                                M98.1 A"ClearAllocs"
                                Instead of
                                M98 P"0:/macros/ClearAllocs.g"
                                ;m98.1.g - Run Macro
                                if exists(param.A)
                                var P ="0:/macros/"^{param.A}
                                if fileexists(var.P)
                                M98 P{var.P}
                                else
                                var P2 =var.P^".g"
                                if fileexists(var.P2)
                                M98 P{var.P2}
                                else
                                echo "M98.1 Macro file not found",{var.P}
                                else
                                echo "M98.1 Macro Parameter A not found"
                                  dwuk3d
                                  Got a bit distracted today by the BondTech INDX - which looks like a very interesting Nozzle Changing solution - although I suspect it might end up being a bit expensive to be practical for my Proof of Concept.
                                  https://youtu.be/BCmGoP0uNlM?si=9z8oPViQpQ6cfGIo
                                  Double Gantry SV08 - with 9 way INDX on each gantry - for parallel tool changes and parallel printing
                                  A0ECF6B8-01ED-4F55-A20D-23393EB243D9.png A2CFB6F6-F85E-4748-AB93-4F7B38D2DFB6.png
                                  Double IDEX version ultimate parallel printing / multi colour solution
                                  undefined 1 Reply Last reply 25 Mar 2025, 05:52 Reply Quote 2
                                    o_lampe @dwuk3d
                                    @dwuk3d I played around with multicolor prints, but they all looked like (R)designed by Toys'R'us.
                                    It was hard to find decent colors and mixing hotends where a fail, too.
                                    undefined 1 Reply Last reply 25 Mar 2025, 07:07 Reply Quote 0
                                      dwuk3d @o_lampe
                                      @o_lampe thanks for all of your input on my project.
                                      I've not tried any colour mixing - but agree that it would be good if they come up with a really good way of doing full colour printing without needing masses of different pre-coloured filaments.
                                      The ink injection method recently featured by teaching tech looks like it has some potential - but I was put off trying it by the slightly washed out look, and high postage costs quoted for the prototype.
                                      I've tried a few different non mixing methods such as Prusa MMU2, Mosaic Palette and IDEX plus combinations- but didn't really have anything I wanted to print until I decided to start doing ship modelling, plus when Bambulab finally came out with a reliable solution that can produce some surprisingly detailed results
                                      • lots of stuff about my multi colour printing stuff here if anyone is interested https://forum.bambulab.com/t/cruise-ship-print/5122
                                      The multi colour challenge I am trying to address is print time - as even tool changers are quite slow when you have 1000s of colour changes in a model - especially when the printing and tool changing are single threaded.
                                      I'm also though trying to get the print time of big objects single or multi colour down too without needing them to be split into multiple parts.
                                      I think massive printers like the Elegoo Orangestorm Giga would really benefit from having 4, 9 or even 16 heads.
                                        dwuk3d
                                        Still working on Z hoppers - taking longer than I expected to get working well.
                                        I've moved the Z hopper off of the tool board holder onto the main extruder holder - which has the advantage that it doesn't need to be offloaded when I get to the tool changer stage. Will need two sets of wires going to each extruder - one for the Z Hopper, and one for the Tool with the 1LC board and PTFE.
                                        Not completely sure they will be strong enough - they are not very heavy - so I could put a 2nd one on the other side - and run them in parallel - with double the current. Would also be better to be lifting from both sides - but does seem a bit excessive to have 2 motors.
                                        Another option is to switch the 'lead bolt' from M4 0.7mm pitch to M3 0.5mm pitch - as that will increase the gearing.
                                        Size comparison with the larger NEMA11 motor - I'm still waiting for shorter ones to be delivered.
                                        Also had a nasty accident with my alignment camera - accidentally took the gantry down to 5mm nearly over the top of it.
                                        Luckily it still seems to work
                                        New 3.6.0.rc1+3 looks like it solves my motion system non release issue - so should hopefully be able to proceed with further testing now on that version. Will be good to turn on head avoidance, plus will probably switch the XY gantry into M596 P0 now that the UV no longer has the servo on it.
                                          dwuk3d
                                          Nema8 update - spent quite a lot of time yesterday (in between looking at Bambulab H2D videos) trying to get my improved Nema8 design to work.
                                          Either the motors are getting weaker or my design has introduced more resistance - as the motors no longer seem to be able to lift the extruders despite a few changes to the 3d printed components and oiling up the linear rail.
                                          Also managed to mess up firmware on Mini5+ and 6HC board again as I thought 3.6.0 Rc1+3 might be having some impact on Nema8 motor power -
                                          Accidentally downgraded to 3.4.0 instead of 3.5.4 - which the Mini5 board doesn't like moving up from.
                                          Had to manually update the Mini5+ again via SD card, and erase a reflash the firmware on the 6HC board too. Luckily I followed my own instructions on how to overcome the Mini5+ 3.4.0 upgrade issue earlier in this thread.
                                          Same Nema8 lifting power issue with 3.5.4 though - so will move back to 3.6.0rc1+3.
                                          I think I am probably wasting too much time on Z hoppers trying to keep the extruders as light as possible - will drop the Nema8's for now and try to over-engineer instead by trying some of the heavier more powerful motors and thicker support structures next.
                                          Probably best to get everything working functionally and with good print quality up to at least the double IDEX phase - then worry about optimising weight as part of later speed tuning phase.
                                          undefined 1 Reply Last reply 27 Mar 2025, 05:53 Reply Quote 0
                                          138 out of 232
