    Sovol SV08 Multiple Motion System Upgrade.
    My Duet controlled machine
    8
    239
    26.4k
    • dwuk3dundefined
      dwuk3d @dwuk3d
      https://www.aliexpress.com/item/1005008402852335.html
      https://www.aliexpress.com/item/1005004769535321.html
        droftarts administrators @dwuk3d
        @dwuk3d said in Sovol SV08 Multiple Motion System Upgrade.:
        Update - found a command by looking at the RRF code - M606 S1.
        This seems to be needed to get the parallel printing to work - it is not mentioned in the Multi Motion System documentation - but is in the Gcode dictionary.
        Thanks for pointing this out, this may be the reason that multiple motion systems haven't been working for people. Unfortunately, it mostly beyond my test rig (and comprehension) to test! However, from your description, I think I understand how it should be used. I've a couple of the paragraphs in the documentation to highlight M606:
        https://docs.duet3d.com/en/User_manual/RepRapFirmware/Multiple_motion_systems#enabling-and-selecting-a-motion-queue
        https://docs.duet3d.com/en/User_manual/RepRapFirmware/Multiple_motion_systems#command-streams-from-file
        Can you check they are correct from your understanding, please?
        dwuk3dundefined 1 Reply Last reply Reply Quote 0
        • dwuk3dundefined
          dwuk3d @droftarts
          @droftarts Looks good. The only comment I have is that in my current test configuration I have the M606 near the end of the Start Gcode in Orca Slicer, not at the start of the print file - just before it starts actual printing - as I didn't need homing etc. to be parallel processed.
          I wouldn't personally expect to put it in the start.g - as I wouldn't want every print to be forked, also I guess the Macro issue mentioned in this post might start occurring.
          https://forum.duet3d.com/topic/35023/mutiple-motion-systems-macro-conflicts-in-3-5/20?_=1741787414435
          • dwuk3dundefined
            dwuk3d
            Managed to get Voron Tap type probing to work on the front gantry, and printing now working fairly well. Time now to return to the alignment probes.
            Electromagnet wired up - on Mini5+ 6A output - which has a flyback diode ok
            ; Electro Magnet
            M950 P4 C"1.out1"
            M42 P4 S0
            Magnet seems to work ok - and hold pliers on anything above S30
            Next on to Servo - decided to use on of these, as I have a few in stock
            Powering it with 6v for now - via a LM2596 Buck Converter from the main input PSU
            Tried it on io0 - but it didn't work as no PWM (although no error message).
            Switched to io1 and now working
            M950 S0 C"1.io1.out"  ; Probe Servo
            M280 P0 S60  ; Set Servo
            Made hole in case to hold servo next to bed.
            F64B40A1-7775-4CF1-AF55-C8B39DE06F92_1_201_a.jpeg A54AAD31-F841-4A10-ACBE-91D0BCE7BCB0_1_201_a.jpeg
            3d printing of parts and macro's tomorrow.
            o_lampeundefined 1 Reply Last reply Reply Quote 1
            • o_lampeundefined
              o_lampe @dwuk3d
              @dwuk3d Those digital servos can draw a lot of current. You'd not want to block the arm or run it above the spec'd angle or the buck converter might fail.
              • dwuk3dundefined
                dwuk3d @o_lampe
                @o_lampe Thanks - yes I was a little worried about that - I can't find it documented anywhere how much power the Servo uses.
                It goes up to 8.4 volts - so decided to keep it down to 6v, plus also am turning off the servo as soon as I have done any moves.
                Might switch to a geared stepper at some point
                • dwuk3dundefined
                  dwuk3d
                  Auto alignment with ball probe complete.
                  Original plan was to use the electro magnet on the bed - but it is quite weak - despite specs being near to the permanent magnet that works very well.
                  So switched to having the magnet off the bed grabbing a big circular plate.
                  Not sure how much it is really needed.
                  Also ordered a bigger magnet - but not sure if I will need to use it.
                  Demo video of homing, levelling, deployment of probe and alignment attached.
                  https://youtu.be/kpVAuKwoTiQ
                  • o_lampeundefined
                    o_lampe @dwuk3d
                    @dwuk3d Nice video, but I watched it without sound.
                    The problem with any nozzle touch probes is, you have to make sure the surface is completely clean. (and conductive too?)
                    I hope your homing macros are ready for "murphy's law"
                    • dwuk3dundefined
                      dwuk3d @o_lampe
                      @o_lampe Thanks - sorry about the music - will have to get a bit more creative with that - and maybe think about some narration.
                      Agreed about the nozzles needing to be clean, will have to add in some auto cleaning as part of my start up phase. I've put a cleaning pad on the swing out arm - but haven't done the automation for this yet.
                      The ball probe is mechanical - so no worries about conductivity.
                      I think my ultimate solution is likely to be a 3 stage approach - with the inductive probe or an eddy probe to find the ball probe and do some basic alignment, then using a cleaned nozzle pressing on the ball probe for a 2nd phase of alignment, with then a final check using the camera for fine adjustments,
                      There is some software to do the camera based adjustments automatically - but I suspect that it will be hard to get that to work reliably too - especially in different lighting conditions and with different bits of waste on the nozzle.
                      • dwuk3dundefined
                        dwuk3d @dwuk3d
                        @dwuk3d Added Nozzle cleaning into alignment process, also decided to start making use of Daemon.g for timeouts of things like magnets, servo's, hot ends - which seems to be working ok.
                        Only issue is with the hot ends - where if the process is left on when a print is about to start then the daemon.g could drop in and switch tools - so will need to disable any tool based timers when prints are started.
                        Example switch on Servo and Magnet - in Probe Deploy Macro.
                        M42 P5 S1 ; Servo On
                        if exists(global.servo5Off) == false
                            global servo5Off = 0
                        set global.servo5Off = state.upTime + 120
                        M42 P4 S255 ; Magnet on
                        if exists(global.magnetOff) == false
                            global magnetOff = 0
                        set global.magnetOff = state.upTime + 200
                        Example Daemon.g
                        ;daemon.g
                            if global.servo5Off != 0 && global.servo5Off < state.upTime
                                M42 P5 S0 ; Servo Off
                                set global.servo5Off = 0
                                echo "daemon.g servo5 switched off"
                            if global.magnetOff != 0 && global.magnetOff < state.upTime
                                M42 P4 S0 ; Magnet off
                                set global.magnetOff = 0
                                echo "daemon.g magnet switched off"
                        if exists(global.T1Off)
                            if global.T1Off != 0 && global.T1Off < state.upTime
                                M596 P0
                                T1
                                M109 S0
                                set global.T1Off = 0
                                echo "daemon.g T1 switched off"
                        if exists(global.T0Off)
                            if global.T0Off != 0 && global.T0Off < state.upTime
                                M596 P1
                                T0
                                M109 S0
                                set global.T0Off = 0
                                echo "daemon.g T0 switched off"
                        • dwuk3dundefined
                          dwuk3d @dwuk3d
                          @dwuk3d Trying out various different options for head cleaner location while still waiting for Nema8 and Nema11 Z lifters to arrive.
                          Not sure whether to put the cleaner at the front of the gantry - so that it can be wiped in 2 dimensions,
                          or just on the end of the Y gantry - so can only be wiped in the X direction.
                          I suppose I could add another servo at the end of the Y gantry, or some sort of 3d printed mechanism to make the Y wiper move backwards and forwards a little bit.
                          Long thin arms working quite well on low Z heights - as they bend slightly rather than fouling on the bed.
                          93D9553A-0FF4-49E6-8768-03B06F873D23.jpeg 4B2F4CDE-36F2-47BA-8D7E-398DF3B744CB_1_102_o.jpeg
                          • dwuk3dundefined
                            dwuk3d @dwuk3d
                            @dwuk3d NEMA11 stepper arrived.
                            Doesn't work quite like I expected as there is a thread inside the motor - so the lead screw has to be held for the motor to move.
                            Also quite heavy and bit big - so think I will hold off until the lead screw NEMA8 arrives.
                            Motor size comparison
                            • dwuk3dundefined
                              dwuk3d
                              I think Nema8 might end up working quite well for the Z hoppers.
                              Decided to try and create some sort of lead screw for the existing NEMA8 I got a few weeks ago.
                              Took quite a few iterations - but ended up doing my first ever 'captive print' - with an M4 Hex Headed Bolt captured inside a coupler print.
                              As its a bolt rather than lead screw then it is quite sloppy - but might be able to use that as a slight advantage as will hopefully be able to use a single optical end stop for both
                              a) The homing of the Nema8 based Z hopper
                              b) The X axis
                              c) Z Axis tapping too.
                              Have replaced Servo on the rear gantry with the Nema8 motor and it is looking good so far.
                              Comparison photo with the slow soon to be replaced front gantry stepper, rear gantry with almost completely installed NEMA8, with 3 way optical end stop below, plus the NEMA11 motor also included.
                              Had to move the 1LC tool board about 16mm to the left to accommodate the taller stepper/lead screw combination.
                              • o_lampeundefined
                                o_lampe @dwuk3d
                                Vertical slop is a 1st layer killer.
                                Although it might have advantages with other stuff, you sure don't want to risk bad adhesion to the bed.
                                Maybe you can add a spring to reduce backlash?
                                • dwuk3dundefined
                                  dwuk3d @o_lampe
                                  @o_lampe Thanks will try a spring over the bolt.
                                  Will be interesting to compare the 'bolt' version with the proper lead screw Nema8 version I have ordered.
                                  • dwuk3dundefined
                                    dwuk3d
                                    Nema8 motor working quite well as a zlifter on rear gantry - so have ordered a few more for other extruders.
                                    Will create a short video next showing use of a single optical endstop for U,A and Z Axis.
                                    In the meantime - another interesting video from teaching tech with a comparison between Marlin, Klipper and RRF - with another little mention of this project in the RRF section about 9mins30 in.
                                    https://youtu.be/fahU6UXl7g8?si=W7gJpKrv2_YfzKT-
                                    • dwuk3dundefined
                                      dwuk3d @dwuk3d
                                      @dwuk3d Initially I was finding that the Nema 8 motors were not powerful enough to reliably lift the gantry.
                                      The Non Lead screw one was I thought rated at 0.4a and the Lead Screw one at 0.24A.
                                      However it looks like on further investigation that the Non lead Screw one is actually rated at 0.8A - and when I set it to 0.6A in Config.g it is working very reliably.
                                      Before I found this out I ordered some smaller (28mm) Nema11-s however as the Nema8's look ok I have ordered two more of those too
                                      Short video attached of Nema8 in operation, and also showing what may or may not be a good idea - using the same (very cheap) optical sensor for
                                      1. MicroZ (A Axis)
                                      2. U Axis
                                      3. Z Axis tapping
                                      In order to swap the 122.io2.in pin between the 3 axis - I found I had to first swap the other axis to dummy IO pins - so that they would release 122.io2.in - so that it could be assigned to the correct axis using M558 commands.
                                      https://youtu.be/0jkH4YBIZDc
                                      • dwuk3dundefined
                                        dwuk3d
                                        Little time saver GCode command created,
                                        M98.1 - For running Macro's - without needing to specify the full path, or .G suffix
                                        M98.1 A"ClearAllocs"
                                        Instead of
                                        M98 P"0:/macros/ClearAllocs.g"
                                        ;m98.1.g - Run Macro
                                        if exists(param.A)
                                            var P ="0:/macros/"^{param.A}
                                            if fileexists(var.P)
                                                M98 P{var.P}
                                            else
                                                var P2 =var.P^".g"
                                                if fileexists(var.P2)
                                                    M98 P{var.P2}
                                                else
                                                    echo "M98.1 Macro file not found",{var.P}
                                        else
                                            echo "M98.1 Macro Parameter A not found"
                                        • dwuk3dundefined
                                          dwuk3d
                                          Got a bit distracted today by the BondTech INDX - which looks like a very interesting Nozzle Changing solution - although I suspect it might end up being a bit expensive to be practical for my Proof of Concept.
                                          https://youtu.be/BCmGoP0uNlM?si=9z8oPViQpQ6cfGIo
                                          Double Gantry SV08 - with 9 way INDX on each gantry - for parallel tool changes and parallel printing
                                          A0ECF6B8-01ED-4F55-A20D-23393EB243D9.png A2CFB6F6-F85E-4748-AB93-4F7B38D2DFB6.png
                                          Double IDEX version ultimate parallel printing / multi colour solution
                                          o_lampeundefined 1 Reply Last reply Reply Quote 2
                                          • o_lampeundefined
                                            o_lampe @dwuk3d
                                            @dwuk3d I played around with multicolor prints, but they all looked like (R)designed by Toys'R'us.
                                            It was hard to find decent colors and mixing hotends where a fail, too.
