    Fly-SHT36 Max V3 RP2040 Based CAN-FD Toolboard
    RepRapFirmware on other controllers
    1.5k
      jay_s_uk @CrazyCreator
      @CrazyCreator you would initially have to flash the firmware via USB and then connect to it via CAN. Subsequent updates are done by DWC. Info on the wiki that was linked to earlier
      CrazyCreatorundefined 1 Reply Last reply Reply Quote 0
      • CrazyCreatorundefined
        CrazyCreator @jay_s_uk
        @jay_s_uk
        I've now connected the SHT to my Mac and have a normal USB drive there... I simply copy the Duet3Firmware_SHT36MAX3.uf2 to it and that's it?
        Is it supposed to be that simple?
        http://www.crazycreatorcube.com
          @CrazyCreator that's it. Nice and simple
            @jay_s_uk
            Wow... How cool is that?
            Two blue lights glow continuously, the bottom one flashes. I think that's how it's supposed to be.
            Ok... Then I'll connect it and get back to you when it comes to the entries in the config.g.
              @CrazyCreator that's correct. The light will flash fast until you connect to a mainboard. It'll then flash at the same speed as the mainboard
                CrazyCreator
                @jay_s_uk
                Mmm... Actually, everything looks fine; the SHT is displayed in the CAN Manager.
                But M997 B124 reports an error.
                  @CrazyCreator if you've not loaded our firmware through DWC, M997 B124 will show an error.
                  Looks like its working fine though. That's good news!
                    @jay_s_uk
                    Ahhhh ... I have to upload the firmware that I previously loaded onto the USB drive again via dwc?
                      @CrazyCreator no, theres no need to run M997 B124.
                      Next time you update, it'll do so automatically and it'll ask you to update.
                      M122 B124 will show you that all works well
                        @jay_s_uk
                        You mean the update with terminal and sudo apt update && sudo apt dist-upgrade?
                        CrazyCreatorundefined jay_s_ukundefined 2 Replies Last reply Reply Quote 0
                          CrazyCreator @CrazyCreator
                          @jay_s_uk
                          I think it looks good 🙂
                          Thank you
                            @CrazyCreator ah, you use SBC mode. You'll have to manually upload the binary each time you want to update
                              @jay_s_uk
                              This means, whenever there is a RRF update I have to update manually with your Duet3Firmware_SHT36MAX3.uf2 downloaded from github and uploaded then via the DWC?
                                @CrazyCreator correct
                                CrazyCreatorundefined 2 Replies Last reply Reply Quote 0
                                  @jay_s_uk
                                  Many thanks for your support ... i think i write the next days for config the new z-probe-scanner 😄
                                    @jay_s_uk
                                    So ... Now i have the first Question 😉
                                    ; TestFan - Zum testen des FAN Port's am Fly-SHT36 Max V3
                                    M950 F10 C"124.out13" Q500	; create fan 10 on pin gpio13 on Fly-SHT36 Max V3 Board and set its frequency
                                    M106 P10 C"TEST-Fan" H-1	; set fan 10 value. Thermostatic control is turned OFF
                                    I wrote this in my config.g, but without success.
                                    The FAN is connected to the GPIO13 FAN0
                                    Is a 24V Fan and the jumper is setting on the VCC
                                      @CrazyCreator thats incorrect naming
                                      the correct names to use can be found in this table here
                                      https://teamgloomy.github.io/fly_sht36_max_v3_pins.html#fly-sht36-max-v3-other-pins-in-firmware
                                      CrazyCreatorundefined 3 Replies Last reply Reply Quote 0
                                        @jay_s_uk Why didn't I see the button? Thank you.
                                          @jay_s_uk
                                          So the entry for my test fan now looks like this:
                                          M950 F10 C"124.out1" Q500
                                          M106 P10 S255
                                          It also appears in the frontend, but when I increase it with the slider, nothing happens.
                                          but on SHT a blue LED lights up synchronously to control the slider
                                          I think I need to test my cables and plugs
                                            @jay_s_uk
                                            I've now checked all the cables and crimped a new one.
                                            But the fan remains silent.
                                            I've attached a picture with the perhaps silly question: Did I set the jumper for 24V correctly?
                                            There's 24V at the connector above, I measured it, and the fan is a 24V fan.
