    Fly-SHT36 Max V3 RP2040 Based CAN-FD Toolboard
    RepRapFirmware on other controllers
    1.6k
    • CrazyCreatorundefined
      CrazyCreator @jay_s_uk
      @jay_s_uk
      You mean the update with terminal and sudo apt update && sudo apt dist-upgrade?
      http://www.crazycreatorcube.com
      CrazyCreatorundefined jay_s_ukundefined 2 Replies Last reply Reply Quote 0
        CrazyCreator @CrazyCreator
        @jay_s_uk
        I think it looks good 🙂
        Thank you
          jay_s_uk @CrazyCreator
          @CrazyCreator ah, you use SBC mode. You'll have to manually upload the binary each time you want to update
          CrazyCreatorundefined 1 Reply Last reply Reply Quote 0
            @jay_s_uk
            This means, whenever there is a RRF update I have to update manually with your Duet3Firmware_SHT36MAX3.uf2 downloaded from github and uploaded then via the DWC?
              @CrazyCreator correct
              CrazyCreatorundefined 2 Replies Last reply Reply Quote 0
                @jay_s_uk
                Many thanks for your support ... i think i write the next days for config the new z-probe-scanner 😄
                  @jay_s_uk
                  So ... Now i have the first Question 😉
                  ; TestFan - Zum testen des FAN Port's am Fly-SHT36 Max V3
                  M950 F10 C"124.out13" Q500	; create fan 10 on pin gpio13 on Fly-SHT36 Max V3 Board and set its frequency
                  M106 P10 C"TEST-Fan" H-1	; set fan 10 value. Thermostatic control is turned OFF
                  I wrote this in my config.g, but without success.
                  The FAN is connected to the GPIO13 FAN0
                  Is a 24V Fan and the jumper is setting on the VCC
                    @CrazyCreator thats incorrect naming
                    the correct names to use can be found in this table here
                    https://teamgloomy.github.io/fly_sht36_max_v3_pins.html#fly-sht36-max-v3-other-pins-in-firmware
                    CrazyCreatorundefined 3 Replies Last reply Reply Quote 0
                      @jay_s_uk Why didn't I see the button? Thank you.
                        @jay_s_uk
                        So the entry for my test fan now looks like this:
                        M950 F10 C"124.out1" Q500
                        M106 P10 S255
                        It also appears in the frontend, but when I increase it with the slider, nothing happens.
                        but on SHT a blue LED lights up synchronously to control the slider
                        I think I need to test my cables and plugs
                          @jay_s_uk
                          I've now checked all the cables and crimped a new one.
                          But the fan remains silent.
                          I've attached a picture with the perhaps silly question: Did I set the jumper for 24V correctly?
                          There's 24V at the connector above, I measured it, and the fan is a 24V fan.
                            @CrazyCreator did you install the fan mosfet?
                              @CrazyCreator looks like you didn't
                              https://teamgloomy.github.io/fly_sht36_max_v3_general.html#fan-mosfets
                                @jay_s_uk
                                Oh dear... How could I have forgotten that? I put the MOSFET in a small bowl so I wouldn't forget it!!!
                                Now the fan works too 🙂
                                  CrazyCreator
                                  So... Let's move on 🙂
                                  Since the SHT36 is working so well, I got a toolboard yesterday and now want to connect 4 SHT36s to it.
                                  Is the CAN wiring in my ugly drawing correct?
                                    @CrazyCreator that looks fine.
                                    You'll need the bypass jumpers in place as these are being treated as stubs.
                                    https://docs.duet3d.com/en/User_manual/Machine_configuration/CAN_connection#stubs
                                    https://docs.duet3d.com/en/Duet3D_hardware/Duet_3_family/Duet_3_Tool_Distribution_Board#h-2-wire-connection
                                      @jay_s_uk Currently, all 8 jumpers are plugged in. I think that's correct, right?
                                        @CrazyCreator yes, that's right
                                          CrazyCreator
                                          Today I finally got back to my printer 🙂 and have a little bit of work ahead of me for tomorrow.
                                          I would like to connect a GL-8FN1 sensor as an X-Endstop to the SHT36.
                                          Unfortunately, I've only found these two options:
                                          And now I'm not sure if the "HVIN" input corresponds to my sensor.
                                          I'm already using the same sensor as a Y-Endstop. It's connected to the MB6HC, of ​​course:
                                          M574 Y1 S1 P"!io2.in" ; configure switch-type (e.g., microswitch) endstop for low end on Y via pin io2.in
                                          Unfortunately, I'm currently a bit unsure about which pins I should use on the SHT36.
                                            @CrazyCreator looks like it runs on 12-24v so same has the HVIN
