    Sovol SV08 Multiple Motion System Upgrade.
    My Duet controlled machine
    8
    272
    39.5k
    • dwuk3dundefined
      dwuk3d @o_lampe
      @o_lampe thanks for all of your input on my project.
      I've not tried any colour mixing - but agree that it would be good if they come up with a really good way of doing full colour printing without needing masses of different pre-coloured filaments.
      The ink injection method recently featured by teaching tech looks like it has some potential - but I was put off trying it by the slightly washed out look, and high postage costs quoted for the prototype.
      I've tried a few different non mixing methods such as Prusa MMU2, Mosaic Palette and IDEX plus combinations- but didn't really have anything I wanted to print until I decided to start doing ship modelling, plus when Bambulab finally came out with a reliable solution that can produce some surprisingly detailed results
      • lots of stuff about my multi colour printing stuff here if anyone is interested https://forum.bambulab.com/t/cruise-ship-print/5122
      The multi colour challenge I am trying to address is print time - as even tool changers are quite slow when you have 1000s of colour changes in a model - especially when the printing and tool changing are single threaded.
      I'm also though trying to get the print time of big objects single or multi colour down too without needing them to be split into multiple parts.
      I think massive printers like the Elegoo Orangestorm Giga would really benefit from having 4, 9 or even 16 heads.
      • dwuk3dundefined
        dwuk3d
        Still working on Z hoppers - taking longer than I expected to get working well.
        I've moved the Z hopper off of the tool board holder onto the main extruder holder - which has the advantage that it doesn't need to be offloaded when I get to the tool changer stage. Will need two sets of wires going to each extruder - one for the Z Hopper, and one for the Tool with the 1LC board and PTFE.
        Not completely sure they will be strong enough - they are not very heavy - so I could put a 2nd one on the other side - and run them in parallel - with double the current. Would also be better to be lifting from both sides - but does seem a bit excessive to have 2 motors.
        Another option is to switch the 'lead bolt' from M4 0.7mm pitch to M3 0.5mm pitch - as that will increase the gearing.
        Size comparison with the larger NEMA11 motor - I'm still waiting for shorter ones to be delivered.
        Also had a nasty accident with my alignment camera - accidentally took the gantry down to 5mm nearly over the top of it.
        Luckily it still seems to work
        New 3.6.0.rc1+3 looks like it solves my motion system non release issue - so should hopefully be able to proceed with further testing now on that version. Will be good to turn on head avoidance, plus will probably switch the XY gantry into M596 P0 now that the UV no longer has the servo on it.
        • dwuk3dundefined
          dwuk3d
          Nema8 update - spent quite a lot of time yesterday (in between looking at Bambulab H2D videos) trying to get my improved Nema8 design to work.
          Either the motors are getting weaker or my design has introduced more resistance - as the motors no longer seem to be able to lift the extruders despite a few changes to the 3d printed components and oiling up the linear rail.
          Also managed to mess up firmware on Mini5+ and 6HC board again as I thought 3.6.0 Rc1+3 might be having some impact on Nema8 motor power -
          Accidentally downgraded to 3.4.0 instead of 3.5.4 - which the Mini5 board doesn't like moving up from.
          Had to manually update the Mini5+ again via SD card, and erase a reflash the firmware on the 6HC board too. Luckily I followed my own instructions on how to overcome the Mini5+ 3.4.0 upgrade issue earlier in this thread.
          Same Nema8 lifting power issue with 3.5.4 though - so will move back to 3.6.0rc1+3.
          I think I am probably wasting too much time on Z hoppers trying to keep the extruders as light as possible - will drop the Nema8's for now and try to over-engineer instead by trying some of the heavier more powerful motors and thicker support structures next.
          Probably best to get everything working functionally and with good print quality up to at least the double IDEX phase - then worry about optimising weight as part of later speed tuning phase.
          • o_lampeundefined
            o_lampe @dwuk3d
            @dwuk3d The NEMA8s can be pretty quick (eg. 3000RPM vs ~300RPM of a NEMA17)
            They also have a long leadscrew. You could place them vertically and use an 90° arm to translate speed into force (long leg /short leg ratio) The arms anchor point could be above the center of the package to reduce sideload to the linear rail.
            dwuk3dundefined 1 Reply Last reply Reply Quote 0
            • dwuk3dundefined
              dwuk3d @o_lampe
              @o_lampe thanks i hadn't spotted that nema8's are faster.
              I have been toying with the idea of doing some sort of lever based force amplification as you suggest - perhaps backed up by some sort of springs or counterbalance.
              Will probably be more efficient if I set up some sort of off gantry force testing mechanism to better investigate the options.
              One concern I do have with adding lever type mechanisms though is play in the extra linkages / pivot points.
              Could also be an idea for a fairly interesting video comparing different linear motion options - with different motor sizes / gearing . movement translation mechanisms - to show how they stack up in terms of speed, strength and weight.
              • dwuk3dundefined
                dwuk3d
                Created short slideshow about the Bondtech INDX vs my Parallel printer - whether it is the answer for going beyond 4 colours depends a lot on the price....
                https://youtu.be/PhH6jiCuCCA
                E66A58B1-CA04-43C2-9176-93A7990683F0.png 2254B50B-C2F5-4D7D-BEC7-53C168C9ACB7.png A17901C6-ED34-4A30-8DCC-497197C1CB9D_1_201_a.jpeg 21730704-0DC5-435A-9D0B-B6ADDBC76CCC_1_201_a.jpeg Screenshot 2025-03-24 at 17.04.18.jpeg
                droftartsundefined o_lampeundefined 2 Replies Last reply Reply Quote 0
                  droftarts administrators @dwuk3d
                  @dwuk3d said in Sovol SV08 Multiple Motion System Upgrade.:
                  Get enough views and they might send you one... or two!
                  • dwuk3dundefined
                    dwuk3d @droftarts
                    @droftarts Will be interesting to see if the video gets much pick up as it is certainly a very elegant design and could completely remove the need for me to add single nozzle multiplexing on top of tool changing - plus also remove the need for lots of electronics and motors etc. for the extra tools and multiplexer
                    Might do a better version of the video with a few animations of the different options next.
                    droftartsundefined dwuk3dundefined 2 Replies Last reply Reply Quote 0
                      @dwuk3d Yes, I really like the look of it, would be great on my Sovol SV08! Though I'm expecting it to be pricey.
                      • o_lampeundefined
                        o_lampe @dwuk3d
                        @dwuk3d The way you mounted the rear INDX tool bar will not work, because it blocks Y-motion of both IDEX arms. You'll need overlapping motion to have full access to the center of the bed.
                        You could turn around the rear IDEX arm and put the INDX tool bar to the very rear of the frame....
                        There would also be a problem with the number of filament-holders you've places on each tool bar unless you want 4 filament holders for each extruder + the center one available for both.
                        Should Bondtech be aware of your virtual design, they might be convinced by an animated simulaton. If not, try to start a kickstarter campaign...
                        Edit: as a sidenote, if you had a moving bed (in Z) instead of a flying gantry you could even print while you change tools. That would be a huge timesafer
                        • dwuk3dundefined
                          dwuk3d @o_lampe
                          @o_lampe thanks for the comments - you are correct about the Y axis issue.
                          My initial plan to overcome this is for both of my INDX gantries to have their own independent Z movement (a bit like the MissChanger). I was already planning to do this with the normal toolchanger option.
                          I could as you said reverse the 2nd gantry too - but I would like to try first having a tool gantry in a place where both Y gantries could occasionally reach. This would allow individual tools to be loaded onto any of the 4 print heads- which firstly think would look interesting in a video, but more importantly would mean the full build plate area is accessible for every filament colour.
                          In terms of the number of tools - I am aiming for 12 colours - so a minimum of 12 in total.
                          But I also want a few extra to allow some colours to be duplicated to allow them to be parallel printed.
                          Ultimately where I think I am aiming to get to is being able to demonstrate doing up to 12 colour prints of models faster than a single colour print of the same model on most other printers. Plus also have no waste other than a few prime towers. With the prime towers being shaped so that they can be stacked and joined to make useful objects.
                          The Bondtech INDX would help me particularly in keeping waste down - as before this I was expecting to have to do some single nozzle multiplexing for a few of the colours.
                          I've posted some stuff on the INDX discord - but Bondtech understandably seem much more interested in simpler, single head designs - Even if their prices are quite high I think I will purchase two of their extruders heads and a few Nozzles for my project in a few months,
                          Fitting a Duet 1lc toolboard into one of their print heads, plus a Z Lift motor outside is probably going to mess up the aesthetics of the INDX extruder toolheads quite a lot though.
                          I am planning to design some covers for my existing toolheads soon to make them look a bit neater - I think I might make them look a bit like the INDX!
                            @dwuk3d Where did you find the CAD files for the INDX? Annoyingly, the Discord link on https://www.bondtech.se/indx-by-bondtech/ is not valid.
                            • dwuk3dundefined
                              dwuk3d @droftarts
                              @droftarts I have posted about the problem on the Discord and they say they will update the link with a permanent one - so hopefully it will be fixed soon.
                              Re the CAD - it's not to scale - I just knocked up a rough presentation of the components from a few screenshots from the video an the 3D Musketeers Podcast - so that I could play with different configurations.
                              dwuk3dundefined 1 Reply Last reply Reply Quote 1
                              • dwuk3dundefined
                                dwuk3d @dwuk3d
                                @dwuk3d Bondtech INDX Projected costs now out - $35 per tool head. Really happy with that.
                                $250 for the toolhead/extruder - a bit pricey - but worth it I think for the reduced complexity the solution brings.
                                Availability Nov25 - which is quite a while off unfortunately.
                                Tool change time 12 secs, with heat up only 4 secs.
                                Overall looks very promising.
                                I don't think I could justify adding 4 toolheads at that price to my system - but two I think would work quite well - one on each gantry - with the IDEX extruders on the gantries being single colour, or maybe with an MMU/Box Turtle type add-on (which wouldn't have to wait until November).
                                • dwuk3dundefined
                                  dwuk3d
                                  Might have solved the problem with my Nema8's - which seemed to work before but then stopped working.
                                  I first thought it might be my new improved design and secondly maybe the firmware.
                                  With the help of Physics Teacher Anthony - who reminded me that I need to lubricate the bolt - that helped a fair bit and the lifting improved - but the motor still kept stalling.
                                  The biggest issue though was an oversight on my part re motor speed. I was just using the Dashboard controls - and I'm not sure how to control the speed.
                                  But when I do a G1 H2 A1 F100 for example it seems to works ok - so I think I was just running the motor too fast from the dashboard in my initial tests.
                                  If I had just connected up the end stop, and ran the proper homea.g with lower feed rates- It probably would have worked ok.
                                  Will still investigate over engineering the lift motors a bit - but a good step forward.
                                    You can change the feedrate in Settings > Machine-specific > Feedrate for move buttons (mm/min). However, it applies to all axis buttons, except extruder axes.
                                    • dwuk3dundefined
                                      dwuk3d @droftarts
                                      @droftarts Thanks will try that.
                                      I guess I should set the maximum feedrate for the motors in the stepper configs too - however the problem with that is gravity - i.e. They can go quite a lot faster downwards than up - and for Z hopping I should use the fully available speed in both directions.
                                      • dwuk3dundefined
                                        dwuk3d
                                        SV08 Double Gantry INDX option - with middle tool rack having independent Z
                                        Tools can be moved between front and rear gantry.
                                        Parallel Printing and Parallel tool changes
                                        A bit messy - but probably what I might end up with -
                                        INDX on 2 heads on both gantries - with IDEX too - using existing SOVOL heads, with option to offload both IDEX heads when not needed.
                                        So this is making me think I will probably still do a tool changer upgrade on my printer if I complete the 4 head stage before INDX becomes available.
                                        Some estimates of tool change/colour change times
                                        INDX tool change is about 17 seconds in total including reheat and priming.
                                        XL based on PrusaSlicer about 14 seconds (3 secs quicker).
                                        Doing the same thing with Bambu Studio and an H2D - Intra Nozzle total change times seem to be estimated at 11.7 seconds (about 5.3 secs quicker). IDEX times likely to be similar
                                        If you move all swaps to the same Nozzle then Bambu Studio estimates 76secs for a normal Multiplexing filament change.
                                        Doing the same thing for an X1C comes out as 95 seconds per change -
                                        An MK4 with MMU3 using the same method is estimating at 67 seconds per change.
                                        Dual Gantry parallel INDX or Stealtchanger tool changes could be as quick as sub-second - and faster than Ratrig toolshift..
                                        Parallel printing could then reduce single colour printing by appx 40% on dual gantry for some larger models, and by over 70% for symmetrical models on quad head printer.
                                        • dwuk3dundefined
                                          dwuk3d
                                          Don't really understand what is happening with my NEMA8 motor.
                                          It started working pretty well with the slower speeds, and I created a sort of test bed - and it lifted 500g quite happily.
                                          Then it stopped working - it might be electronic, the motor, or my mechanical design - I might be over constraining the bolt
                                          Lead Screw Nema11 now arrived - the lead screw is a bit long - 50mm - but will try that - with the coupler for the lead screw not too constrained if I get any trouble.
                                          This motor is rated at 1.0A - will be interesting to see how more powerful it is.
                                          Nema 11 installed - sticks up more than it really needs to - might chop off the lead screw, or try and source one with shorter screw - but managing to lift 500g and the extruder so far
                                          F93E6250-4A40-4BCA-AD5C-B23C2B821331.jpeg Screenshot 2025-03-29 at 22.44.30.png
                                          • dwuk3dundefined
                                            dwuk3d
                                            Simplified Dual IDEX belt routing.
                                            Decided it will be easier to put one 'Ratrig Hybrid' Y Axis motor above (for rear gantry) and below (for front gantry).
                                            It will mean that the bed needs to be raised up a bit - due to the height of the bottom motor - but this will be needed eventually anyway when I move
                                            to an occasionally moving bed.
                                            Will have to redesign the extruder carriage belt couplings so that there is room one of the belts to fit through.
                                            583EBB6F-833B-4DB7-8D5A-D5D0EA364865.png 7EE20091-82B1-4C7D-8760-483BBC791185.png
                                            I think this should work well for the front gantry in particular as the belt fix point will be very near the Y axis rail carriage.
                                            For the rear gantry they are further away - as the fix point is at the top - so there might be a slight pendulum effect.
                                            Setup will be mirrored on the other side - could I suppose swap the top and bottom couplings - but I guess it will be better to keep both sides of each gantry the same.
