Fly-SHT36 Max V3 RP2040 Based CAN-FD Toolboard
@jay_s_uk
So ... Now i have the first Question; TestFan - Zum testen des FAN Port's am Fly-SHT36 Max V3 M950 F10 C"124.out13" Q500 ; create fan 10 on pin gpio13 on Fly-SHT36 Max V3 Board and set its frequency M106 P10 C"TEST-Fan" H-1 ; set fan 10 value. Thermostatic control is turned OFF
I wrote this in my config.g, but without success.
The FAN is connected to the GPIO13 FAN0
Is a 24V Fan and the jumper is setting on the VCC -
@CrazyCreator thats incorrect naming
the correct names to use can be found in this table here
https://teamgloomy.github.io/fly_sht36_max_v3_pins.html#fly-sht36-max-v3-other-pins-in-firmware -
@jay_s_uk Why didn't I see the button? Thank you.
@jay_s_uk
So the entry for my test fan now looks like this:M950 F10 C"124.out1" Q500 M106 P10 S255
It also appears in the frontend, but when I increase it with the slider, nothing happens.
but on SHT a blue LED lights up synchronously to control the slider
I think I need to test my cables and plugs -
@jay_s_uk
I've now checked all the cables and crimped a new one.But the fan remains silent.
I've attached a picture with the perhaps silly question: Did I set the jumper for 24V correctly?
There's 24V at the connector above, I measured it, and the fan is a 24V fan. -
@CrazyCreator did you install the fan mosfet?
@CrazyCreator looks like you didn't
https://teamgloomy.github.io/fly_sht36_max_v3_general.html#fan-mosfets -
@jay_s_uk
Oh dear... How could I have forgotten that? I put the MOSFET in a small bowl so I wouldn't forget it!!!Now the fan works too
@CrazyCreator that looks fine.
You'll need the bypass jumpers in place as these are being treated as stubs.
https://docs.duet3d.com/en/User_manual/Machine_configuration/CAN_connection#stubs -
@jay_s_uk Currently, all 8 jumpers are plugged in. I think that's correct, right?
@CrazyCreator yes, that's right
Today I finally got back to my printer
and have a little bit of work ahead of me for tomorrow.
I would like to connect a GL-8FN1 sensor as an X-Endstop to the SHT36.
Unfortunately, I've only found these two options:
And now I'm not sure if the "HVIN" input corresponds to my sensor.I'm already using the same sensor as a Y-Endstop. It's connected to the MB6HC, of ​​course:
M574 Y1 S1 P"!io2.in" ; configure switch-type (e.g., microswitch) endstop for low end on Y via pin io2.in
Unfortunately, I'm currently a bit unsure about which pins I should use on the SHT36.
@CrazyCreator looks like it runs on 12-24v so same has the HVIN
@jay_s_uk
It's this sensor: https://s.click.aliexpress.com/e/_oo1zqJ5 -
@CrazyCreator then just a normal end stop then
@jay_s_uk Hello ... Ready now
MicroProbe and Proximity Sensor connected and working (in Testconfig).
Only if you interested, there the part from config.g
; Endstops M574 X1 S1 P"!124.io1.in" ; configure switch-type (e.g. microswitch) endstop for low end on X via pin 124.io1.in on Fly-SHT36 Max V3 M574 Y1 S1 P"!io2.in" ; configure switch-type (e.g. microswitch) endstop for low end on Y via pin io2.in on MB6HC M574 Z1 S2 ; configure Z-probe endstop for low end on Z on Fly-SHT36 Max V3 ; Z-Probes ; Configuration for Z-Probe - BTT BiQu MicroProbe V1 M558 P9 H6 F250:30 T8000 C"^124.io0.in" ; set Z probe type to microprobe and the dive height + speeds M950 P0 C"124.io0.out" ; Setup 124.io0.out as on/off port on Fly-SHT36 Max V3 G31 P500 X0 Y0 Z0.7 ; set Z probe trigger value, offset and trigger height ; Configuration for Scanning Probe from SHT36 M558 K1 P11 C"124.i2c.ldc1612" H5 F120 T6000 ; configure scanning probe via slot #1 G31 P500 X0 Y0 Z0.7 ; set Z probe trigger value, offset and trigger height ; Define Mesh Grid and Probing Points distance M557 X30:360 Y15:330 P5 ; define mesh grid
I think this is normal, because the Scanning Probe is not connected?
@CrazyCreator yes, if it's not connected it'll read like that. It'll also read like that if it's not calibrated
@jay_s_uk
That will be the next project. Calibrating the scanner... Yeaaaaah -
@jay_s_uk
Can you help me again?When I send the MicroProbe to probe the bed, it moves to the planned point and the pin pops out briefly but then goes back in immediately
and the bed stops.
The DWC Show: Z-Probe 0
Then the error message appears:
The config.g for this:; Endstops M574 X1 S1 P"!124.io1.in" ; configure switch-type (e.g. microswitch) endstop for low end on X via pin 124.io1.in on Fly-SHT36 Max V3 M574 Y1 S1 P"!io2.in" ; configure switch-type (e.g. microswitch) endstop for low end on Y via pin io2.in on MB6HC M574 Z1 S2 ; configure Z-probe endstop for low end on Z on Fly-SHT36 Max V3 ; Z-Probes ; Configuration for Z-Probe - BTT BiQu MicroProbe V2 M558 P9 H6 F250:30 T8000 C"^124.io0.in" ; set Z probe type to microprobe and the dive height + speeds M950 P0 C"124.io0.out" ; Setup io0.out as on/off port on Fly-SHT36 Max V3 G31 P500 X30.01 Y48.6 Z0.7 ; set Z probe trigger value, offset and trigger height ; Configuration for Scanning Probe from SHT36 ;M558 K1 P11 C"124.i2c.ldc1612" H5 F120 T6000 ; configure scanning probe via slot #1 ;G31 P500 X0 Y0 Z0.7 ; set Z probe trigger value, offset and trigger height ; Define Mesh Grid and Probing Points distance M557 X30:300 Y15:250 P5 ; define mesh grid
When i try the other way in config.g with !
; Endstops M574 X1 S1 P"!124.io1.in" ; configure switch-type (e.g. microswitch) endstop for low end on X via pin 124.io1.in on Fly-SHT36 Max V3 M574 Y1 S1 P"!io2.in" ; configure switch-type (e.g. microswitch) endstop for low end on Y via pin io2.in on MB6HC M574 Z1 S2 ; configure Z-probe endstop for low end on Z on Fly-SHT36 Max V3 ; Z-Probes ; Configuration for Z-Probe - BTT BiQu MicroProbe V2 M558 P9 H6 F250:30 T8000 C"^!124.io0.in" ; set Z probe type to microprobe and the dive height + speeds M950 P0 C"124.io0.out" ; Setup io0.out as on/off port on Fly-SHT36 Max V3 G31 P500 X30.01 Y48.6 Z0.7 ; set Z probe trigger value, offset and trigger height ; Configuration for Scanning Probe from SHT36 ;M558 K1 P11 C"124.i2c.ldc1612" H5 F120 T6000 ; configure scanning probe via slot #1 ;G31 P500 X0 Y0 Z0.7 ; set Z probe trigger value, offset and trigger height ; Define Mesh Grid and Probing Points distance M557 X30:300 Y15:250 P5 ; define mesh grid
If I connect it like this, the MicroProbe works. The pin pops out and is triggered by the bed, and the bed stops.
BUT then I see a red 1000 on the display.
But the homing works perfectly fine, even though it says 1000 in red. That's kind of surprising, because that's not how it's supposed to be, is it?
Maybe you can take a look at my configuration?
Attached are config.g and the homing files:
config.g
homeall.g
homex.g
homey.g
homez.gMaybe
