    Fly-SHT36 Max V3 RP2040 Based CAN-FD Toolboard
    RepRapFirmware on other controllers
    5.7k
      jay_s_uk @CrazyCreator
      @CrazyCreator ah, you use SBC mode. You'll have to manually upload the binary each time you want to update
      CrazyCreatorundefined 2 Replies Last reply Reply Quote 0
      • CrazyCreatorundefined
        CrazyCreator @jay_s_uk
        @jay_s_uk
        This means, whenever there is a RRF update I have to update manually with your Duet3Firmware_SHT36MAX3.uf2 downloaded from github and uploaded then via the DWC?
        http://www.crazycreatorcube.com
          @CrazyCreator correct
            @jay_s_uk
            Many thanks for your support ... i think i write the next days for config the new z-probe-scanner 😄
              @jay_s_uk
              So ... Now i have the first Question 😉
              ; TestFan - Zum testen des FAN Port's am Fly-SHT36 Max V3
              M950 F10 C"124.out13" Q500	; create fan 10 on pin gpio13 on Fly-SHT36 Max V3 Board and set its frequency
              M106 P10 C"TEST-Fan" H-1	; set fan 10 value. Thermostatic control is turned OFF
              I wrote this in my config.g, but without success.
              The FAN is connected to the GPIO13 FAN0
              Is a 24V Fan and the jumper is setting on the VCC
                @CrazyCreator thats incorrect naming
                the correct names to use can be found in this table here
                https://teamgloomy.github.io/fly_sht36_max_v3_pins.html#fly-sht36-max-v3-other-pins-in-firmware
                CrazyCreatorundefined 3 Replies Last reply Reply Quote 0
                  @jay_s_uk Why didn't I see the button? Thank you.
                    @jay_s_uk
                    So the entry for my test fan now looks like this:
                    M950 F10 C"124.out1" Q500
                    M106 P10 S255
                    It also appears in the frontend, but when I increase it with the slider, nothing happens.
                    but on SHT a blue LED lights up synchronously to control the slider
                    I think I need to test my cables and plugs
                      @jay_s_uk
                      I've now checked all the cables and crimped a new one.
                      But the fan remains silent.
                      I've attached a picture with the perhaps silly question: Did I set the jumper for 24V correctly?
                      There's 24V at the connector above, I measured it, and the fan is a 24V fan.
                        @CrazyCreator did you install the fan mosfet?
                          @CrazyCreator looks like you didn't
                          https://teamgloomy.github.io/fly_sht36_max_v3_general.html#fan-mosfets
                          CrazyCreatorundefined 1 Reply Last reply Reply Quote 0
                            @jay_s_uk
                            Oh dear... How could I have forgotten that? I put the MOSFET in a small bowl so I wouldn't forget it!!!
                            Now the fan works too 🙂
                              CrazyCreator
                              So... Let's move on 🙂
                              Since the SHT36 is working so well, I got a toolboard yesterday and now want to connect 4 SHT36s to it.
                              Is the CAN wiring in my ugly drawing correct?
                                @CrazyCreator that looks fine.
                                You'll need the bypass jumpers in place as these are being treated as stubs.
                                https://docs.duet3d.com/en/User_manual/Machine_configuration/CAN_connection#stubs
                                https://docs.duet3d.com/en/Duet3D_hardware/Duet_3_family/Duet_3_Tool_Distribution_Board#h-2-wire-connection
                                  @jay_s_uk Currently, all 8 jumpers are plugged in. I think that's correct, right?
                                    @CrazyCreator yes, that's right
                                      CrazyCreator
                                      Today I finally got back to my printer 🙂 and have a little bit of work ahead of me for tomorrow.
                                      I would like to connect a GL-8FN1 sensor as an X-Endstop to the SHT36.
                                      Unfortunately, I've only found these two options:
                                      And now I'm not sure if the "HVIN" input corresponds to my sensor.
                                      I'm already using the same sensor as a Y-Endstop. It's connected to the MB6HC, of ​​course:
                                      M574 Y1 S1 P"!io2.in" ; configure switch-type (e.g., microswitch) endstop for low end on Y via pin io2.in
                                      Unfortunately, I'm currently a bit unsure about which pins I should use on the SHT36.
                                        @CrazyCreator looks like it runs on 12-24v so same has the HVIN
                                          @jay_s_uk
                                          It's this sensor: https://s.click.aliexpress.com/e/_oo1zqJ5
                                          And it's connected like this:
                                            @CrazyCreator then just a normal end stop then
