    Very slight systematic waves every about 2mm on the prints
    1.2k
    • lucundefined
      luc
      Hi all,
      I am trying to eliminate what you see in the photo against the light.. I have done several trials but can't find the cause. The curious thing is that it would appear to have the 2mm pitch of the belt but actually the pitch of the artifact is about 1.7mm. It is an XY core and the movement without the belt is very smooth, the pulleys run smooth and have no play. I had the X linear guide with some play but I changed it.
      I print tests at 60mm/sec the outer perimeters.
      M566 X900.00 Y900.00 Z60.00 E3000.00
      M203 X15000.00 Y15000.00 Z600.00 E6000.00
      M201 X1000.00 Y1000.00 Z100.00 E6000.00
      I would like to hear your opinion?
      Don't look at the angles in the picture it was a PA test.
      Thank you
      o_lampeundefined Notepadundefined 2 Replies Last reply Reply Quote 0
      • o_lampeundefined
        o_lampe @luc
        @luc It could be the infamous dual drive extruder pattern. Do you have a dual drive extruder?
        Maybe the filament tensioner is too tight then?
        Does the same pattern appear on all sides? If it's only on the opposite side, you might have a mechanical issue with this axis. ( damaged idler bearing or wobbling idler?)
        lucundefined 1 Reply Last reply Reply Quote 0
        • lucundefined
          luc @o_lampe
          @o_lampe
          Yes, on all sides it is the same.
          Yes, it is a dual drive extruder. What can I try in this case? Change it? Change it to which one? (I will have to redesign the whole stand).
          I don't see that the spring load tension of the dual drive makes any difference. I tried varying it during printing.
          • lucundefined
            luc
            Tried loosening the whole spring of the dual drive extruder without getting any change.
            Checked all rollers and pulleys and.....incredible!!! 😬
            I have never seen such a thing!!! Belt rubber or maybe dust stuck in the tooth recesses!!!
            I can clean it but with the occasion I put two new pulleys.
            • Notepadundefined
              Notepad @luc
              @luc This could be many things, and is generally referred to as VFAs (Vertical Fine Artifacts)
              Whilst there is not much you can do about it as it could be a variety of issues, I have a few tips that might be able to help find out where the problem lies.
              1. Belt tension, If the belts are too tight the tooth patten may show up in the printed surface
              2. Motor accuracy. Motors have predefined "steps" which the microcontroller smoothes out. Try printing the part faster or slower, and see if that changes the surface regularity. If it does, then it means you might have a printing speed close to the motors resonant frequency
              3. If speed doesn't fix it, then it might be a bearing, either the motion system or the extruder.
              In general on a 20T belt pulley, I find printers have 2 resonant speed frequencies, 60-80mm/s or 100-130mm/s. Try to find out which one your motor doesn't like, and avoid those speeds.
              You also want to loosen your belts as much as possible without compromising your accuracy or risk belt slippage. its VERY easy to overtighten your belts if you don't have measurement equipment.
              The real bamboo printer manufacturer
              o_lampeundefined 1 Reply Last reply Reply Quote 1
              • o_lampeundefined
                o_lampe @Notepad
                @Notepad said in Very slight systematic waves every about 2mm on the prints:
                Interesting stuff! In car gearboxes they often use gears with a prime number toothcount to avoid such stuff. There it's torque-curve related, which is similar to the stepper motor.
                I wonder if the resonance frequencies would be an issue with 17 or 19 tooth pulleys?
                I may resin-print some pulleys to test this theory.
                lucundefined Notepadundefined 2 Replies Last reply Reply Quote 1
                • lucundefined
                  luc
                  Cleaning the pulleys slightly improved that effect but did not solve it.
                  I am waiting for new pulleys that I will install along with a new belt but I don't think I am getting any improvement.
                  I tried printing with a higher speed without getting any change.
                  I have tried printing at 45° with no change.
                  I tried printing with a 0.3 layer instead of 0.2 and got no change.
                  I tried redoing the PID of the bed and found no change.
                  By now it has become a war....me against her!
                  Translated with DeepL.com (free version)
                  • lucundefined
                    luc @o_lampe
                    @o_lampe
                    The engines I use on X and Y are these:
                    https://www.omc-stepperonline.com/it/nema-17-bipolare-0-9deg-46ncm-65-1oz-in-2a-2-8v-42x42x48mm-4-fili-lunghezza-d-cut-completa-17hm19-2004s1
                    • o_lampeundefined
                      o_lampe @luc
                      @luc said in Very slight systematic waves every about 2mm on the prints:
                      This should at least change the distance between the lines?
                      Your motors are perfectly fine. What we discussed about resonance is a common thing among steppers.
                      • lucundefined
                        luc @o_lampe
                        @o_lampe said in Very slight systematic waves every about 2mm on the prints:
                        No, almost nothing changes. Maybe very little for the better but the imprint of those vertical waves remains.
                        • lucundefined
                          luc @luc
                          @luc
                          To assess whether the motors are the cause, I might try setting a different current.
                          They are currently set at M906 1700.
                          Are you thinking of trying a print at 1800 or 1600 or less?
                          Notepadundefined 1 Reply Last reply Reply Quote 1
                          • Notepadundefined
                            Notepad @o_lampe
                            @o_lampe OO very interesting, I never considered the difference between 19 20 and 21 tooth. Id say start with 21 tooth as bigger pulley = more grip
                            • Notepadundefined
                              Notepad @luc
                              @luc Less current normally means less vibration force. If it works, Try 1200 or 1400
                              • lucundefined
                                luc
                                Hello everyone,
                                I put on the new pulleys (even though the old ones were just to be cleaned) and with the occasion also the new belt and I can't get rid of those vertical marks that seem to be spaced just under 2mm apart.
                                Does anyone have any ideas?
                                Thanks
                                3DPMicroundefined 1 Reply Last reply Reply Quote 0
                                • 3DPMicroundefined
                                  3DPMicro @luc
                                  @luc since the 2mm spacing suggests its related to tooth pitch flip the belt so the teeth aren't engaged, tension to provide enough grip to execute a test print.
                                  Duet controlled Lathe, micro mill, 3d printer and 1992 Haas VF2 VMC
                                  • o_lampeundefined
                                    o_lampe @Notepad
                                    @Notepad In my theory, 20 teeth is the worst, since if syncs "perfectly" with the 200 steps/turn torque curve.
                                    21 isn't a prime number, so I'd go for 19 or 23
                                    • lucundefined
                                      luc
                                      I was able to find a way to turn the belt temporarily just to make a print.
                                      The cause is not the belt or even the pulleys.
                                      I'm beginning to think it may be the motors:
                                      What are your thoughts on these motors?
                                        droftarts administrators @luc
                                        @luc The motors seem fine, but it might be an imbalance in how the coils have been wound. What hardware and firmware version are you running? Send M122 and post the response. Also please post your full config.g.
                                        • lucundefined
                                          luc @droftarts
                                          @droftarts said in Very slight systematic waves every about 2mm on the prints:
                                          Here is what is required
                                          Thank you
                                          config.g
                                          M122.txt
                                            @luc I can't see anything obvious in your config or M122 that would be causing the issue. You could try using the latest 3.6.0-rc.2 firmware to see if it makes any difference, but I'd think the issue is either the motors as already discussed, or mechanical, ie a bad bearing on the belt run (if it affects all axes, look at the bearings not on the X carriage, as those don't move with Y axis movement). Overtightened belts can also cause issues. Finally, check that you haven't mixed up the belt and pulley types, ie running Gates GT2-2mm belts with 2GT pulleys, as the tooth profile is very slightly different.
