    Robotic kinematics
    MultiAxis Printing
    22
    389
    46.8k
    • Toaster0042undefined
      Toaster0042 @JoergS5
      @JoergS5 ah ok, I tought it would fall under the 4 axis robot with an aditional rotating joint, I am fine with testing it I simply need to finish printing it as I have not finished it yet and was trying to get the firmware set before but I will be happy to test the code
      • JoergS5undefined
        JoergS5
        I have time in May and June now to proceed developing robot kinematics. The order is
        • 4 axis parallel (the black robot arm), probably as a quick-and-dirty approach first for @YuriConfessor
        • DWC plugin to design and analyse a given model
        • CoreXY/Prusa/Cartesian 5 axis AC and BC
        • 6 axis robot
        • testing whether Qt is a possibility for a designer/slicer
        • elaborate tool design. My personal priority is using robot for CNC, so I'll work on support for different tools (tool shape etc).
        I'll use 3.5.1 as basis.
        Mummedundefined Toaster0042undefined 2 Replies Last reply Reply Quote 5
        • Mummedundefined
          Mummed @JoergS5
          @JoergS5 Dear Joerg, thank you for sharing all of your hard work. I have this post and RepRap configuration regarding robot 3D printing. Since I am new to this topic, I may as you s question about configuring. Can we use the same procedure if we have a 6DOF robotic arm with its own controller and need to add an extruder to it?
          from my understanding, most of the discussions in the forum and documentation focused on developing a robotic arm and its configuration however I couldn't figure it out how to synchronize robot motion and extruder commands for printing.
          Thank you,
          Mohamad
          • o_lampeundefined
            o_lampe @Mummed
            @Mummed You can define fans, heater and a tool same as any other 3D printer. But to make it work with a 6DOF arm, you'd need a matching slicer.
              @JoergS5 Hey! I just wanted to check back on this and see if you had made progress on this and if you had made the implementation of the new kinematics
              • JoergS5undefined
                JoergS5 @Toaster0042
                @Toaster0042 you're right, I should inform, I will prepare an update.
                • droftartsundefined droftarts referenced this topic
                • JoergS5undefined
                  JoergS5
                  I'm back with robotics. My partner passed away, I had to mourn, I have a new partner now since a few months, she will be on vacancy alone mid to end may. So this will be the time frame when I will work on robot kinematics again, based on RRF 3.6.
                  I will implement an idea I had last year and started implementing some time ago. Robotics solutions are be very different for forward and inverse kinematics. So I thought about a generic approach:
                  • a forward chain to combine different drive movements into one movement chain, with one or multiple solutions
                  • a backward (inverse) chain with the result of none to multiple solutions
                  • forward and backward chains are stored in arrays which can be set by parameters with M669. Kinematic code will simply process the chains
                  • to find the chain solutions, the user can think it through mathematically and set the parameters or he can use the to-be-programmed Qt based program to set solutions or simulate them and compare to measurements of the prototype
                  • the chain elements are code fragements to implement mathematical solutions. The mathematicsal solutions can be augmented in future releases when necessary
                  That's my plan.
                  droftartsundefined T3P3Tonyundefined 2 Replies Last reply Reply Quote 3
                    droftarts administrators @JoergS5
                    @JoergS5 I'm sorry for your loss. I'm glad that you have been able to move forward and find a new relationship, and I look forward to more robotics development. I really must rebuild my robot arm...
                    jay_s_ukundefined 1 Reply Last reply Reply Quote 1
                      jay_s_uk @droftarts
                      @droftarts Looking forward to seeing pictures of you with your robot arm fitted... 😜
                      • o_lampeundefined
                        o_lampe @jay_s_uk
                        @jay_s_uk Hmmm,
                        like Winter soldier?
                          T3P3Tony administrators @JoergS5
                          @JoergS5 very sorry for your loss.
                          Thanks for the update on what you are planning.
                            droftarts administrators @o_lampe
                            @o_lampe said in Robotic kinematics:
                            @jay_s_uk Hmmm,
                            My Bucky cosplay is at 1%.
                            1 Reply Last reply Reply Quote 4
