    Spirograph emulator with Duet2
    CNC
    1.9k
    • o_lampeundefined
      o_lampe @mrehorstdmd
      @mrehorstdmd A SCARA arm in the center would be nice, but I don't know if RRF supports the 360° working area? @dc42 @JoergS5 ?
      The design is 7 years old, I wonder if there are improved designs available, a counterweight would be nice IMHO.
      • mrehorstdmdundefined
        mrehorstdmd @dc42
        @dc42 I'm having some trouble figuring out how to randomly select a file from the /gcodes/ folder. Do I have to put the files names in that folder in an array, or is there a way to declare the contents of the /gcodes/ folder as an array? I currently have about 200 gcode files stored in the /gcodes/ folder, and I add more files to it as I generate them.
        I typically run a macro at the end of the config.g file, like this:
        M98 P"/macros/macro01"
        And that macro file looks like this (though much longer):
        ; file name: macro01
        M98 P"/gcodes/wipe_03.gcode"
        M98 P"/gcodes/file_04.gcode"
        G04 S60
        M98 P"/gcodes/wipe_01.gcode"
        M98 P"/gcodes/file_02.gcode"
        G04 S60
        M98 P"/gcodes/wipe_02.gcode"
        M98 P"/gcodes/file_06.gcode"
        Should macro01 file look like this:
        var myfile = {"file_01", "file_02", "file_03", "file_04", "file_05", "file_06"}
        M98 P"/gcodes/^myfile[random 6]^.gcode"
        G04 S60
        It seems like I'll quickly run out of line length if I try to put all 200 file names in the variable declaration.
        Another idea- rename all the files in the gcodes folder with simple numeric names:
        1.gcode, 2.gcode.... 212.gcode
        Then in the macro file, select a random pattern file like this:
        M98 P"/gcodes/^{random(212)}^.gcode"
        Sorry if this stuff is too basic. I've been away from programming for a looooong time.
        • o_lampeundefined
          @mrehorstdmd said in Spirograph emulator with Duet2:
          Basically, that's what I'd try too.
          But I'd check, if the file (still) exists before I call M98. Unless you only put files in the gcode directory after you tested it. It would be a PITA to e.g. rename files 123-212 , just because file 122 turned out to be problematic or ugly or boring.
          Alternatively you could edit the unwanted file and only leave the end code. The worst that can happen is running two wipe-file in a row.
            mrehorstdmd @o_lampe
            @o_lampe Thanks. All the files are tested, so not an issue. I'll be able to access the machine this afternoon and will try out the random selection. I'm not too sure about the syntax. I've been testing the syntax via the console on my 3D printer and it doesn't look promising. If I enter M98 p"{random(55)}^.gcode" it returns {random(55)}^.gcode not found. It isn't converting the expression to a random number, or even treating it as an expression, just a string of characters. I've tried a few variations on the syntax and none have worked so far.
            When I run echo random(416) on the console, it returns a random number (sometimes 3 digits), so I know random is working the way it should. Maybe I need to set a variable to a random value, and use that variable in the M98 command.
            Renaming the files is pretty easy- I used Bulk Rename Utility. It takes just a couple seconds to set it up.
            ironhydroxideundefined 1 Reply Last reply Reply Quote 0
            • ironhydroxideundefined
              ironhydroxide @mrehorstdmd
              you need to complete the quotation, then append the value, then continue the quotation.
              M98 P""" <-gives you M98 "
              ^{random(55)} appends the result of the random 55
              ^".gcode""" appends the string .gcode"
              Leaves you with
              M98 P"randomnumber.gcode"
              I was wrong,
              After some testing it seems here's the syntax.
              M98 P{random(55)}^".gcode"
                dc42 administrators @ironhydroxide
                @ironhydroxide the correct syntax is:
                M98 P{random(55)^".gcode"}
                ironhydroxideundefined mrehorstdmdundefined 2 Replies Last reply Reply Quote 1
                  ironhydroxide @dc42
                  @dc42 Thanks for that correction.
                  Tested with my system and it seemed to work the other way (though likely can cause problems when getting more complex)
                    mrehorstdmd @dc42
                    @dc42 I have drawing files in /gcodes/draw/ and wipe files in /gcodes/wipe/ folders. All files are renamed with numeric names and gcode extension, like "16.gcode".
                    I have tried about 50 variations on:
                    M98 P{/gcodes/draw/random(214)^".gcode"}
                    and get various error messages, mostly about expecting a string at one column or another.
                    How do I specify the folder to find the target files? Is this syntax documented somewhere?
                    Thanks!
                    m98 P"/gcodes/draw/^{random(22)}^.gcode"
                    Warning: Macro file /gcodes/draw/^{random(22)}^.gcode not found
                    ok
                    M98 P"/gcodes/draw/{random(55)^".gcode"}
                    Warning: Macro file /gcodes/draw/{random(55)^ not found
                    Error: Bad command: gcode"}
                    ok
                    M98 P{/gcodes/draw/{andom(55)^".gcode"}
                    Error:  at column 7: M98: expected an expression
                    ok
                    M98 P{/gcodes/draw/{random(55)^".gcode"}
                    ok
                    M98 P{/gcodes/draw/random(55)^".gcode"}
                    ok
                    M98 P "/gcodes/draw/{random(55)^".gcode"}
                    Error:  at column 6: M98: expected a string expression
                    ok
                    M98 P "/gcodes/draw/{random(55)^.gcode"}
                    ok
                    M98 P {/gcodes/draw/random(55)^.gcode"}
                    ok
                    Warning: Macro file 39.gcode not found
                    ok
                    M98 P /gcodes/draw/{random(55)^".gcode"}
                    Error: Bad command: gcodes/draw/{random(55)^".gcode"}
                    ok
                    M98 P "/gcodes/draw/{random(55)^".gcode"}"
                    Error: Bad command: gcode"}"
                    ok
                    ok
                    ok
                    ok
                    ok
                    M98 P "/gcodes/draw/"^{random(55)^".gcode"}"
                    ok
                    M98 P /gcodes/draw/^{random(55)^".gcode"}
                    Error: Bad command: gcodes/draw/^{random(55)^".gcode"}
                    ok
                    M98 P {/gcodes/draw/random(55)^".gcode"}
                    ok
                    M98 P {0:/gcodes/draw/random(55)^".gcode"}
                    ok
                    M98 P "0:/gcodes/draw/"^{random(55)^".gcode"}
                    ok
                    M98 P "0:/gcodes/draw/"{random(55)^".gcode"}
                    ok
                    M98 P"0:/gcodes/draw/"{random(55)^".gcode"}
                    Warning: Macro file 0:/gcodes/draw/ not found
                    ok
                    M98 P{0:/gcodes/draw/random(55)^".gcode"}
                    Error:  at column 8: M98: expected '}'
                    ok
                    M98 P"{0:/gcodes/draw/random(55)"^".gcode"}
                    Warning: Macro file {0:/gcodes/draw/random(55) not found
                    ok
                    M98 P"0:/gcodes/draw/{random(55)"^".gcode"}
                    Warning: Macro file 0:/gcodes/draw/{random(55) not found
                    ok
                    M98 P"0:/gcodes/draw/{random(55)}"^".gcode"}
                    Warning: Macro file 0:/gcodes/draw/{random(55)} not found
                    ok
                    ok
                    M98 P"0:/gcodes/draw/"{random(55)}"^".gcode"
                    ok
                    M98 P"0:/gcodes/draw/"^{random(55)}"^".gcode"
                    ok
                    M98 P"0:/gcodes/draw/"^{random(55)}^".gcode"
                    ok
                    M98 P"0:/gcodes/draw/"^{random(55)^".gcode"}
                    ok
                    M98 P"0:/gcodes/draw/"^"{random(55)^".gcode"}
                    ok
                    M98 P"0:/gcodes/draw/^"{random(55)^".gcode"}
                    Warning: Macro file 0:/gcodes/draw/^ not found
                    ok
                      dc42 administrators @mrehorstdmd
                      @mrehorstdmd try this:
                      M98 P{"/gcodes/draw/"^random(214)^".gcode"}
                      mrehorstdmdundefined 1 Reply Last reply Reply Quote 1
                        mrehorstdmd @dc42
                        @dc42 That's it! Thanks!
                        • o_lampeundefined
                          o_lampe
                          The Slim Delta is alive and I could reach areas outside of the triangle.
                          The problem is, how do I tell RRF that it mustn't foul the towers?
                          I know there are people using that for their leadscrew area and such, but I couldn't find it in the Wiki.
                          • o_lampeundefined
                            o_lampe @o_lampe
                            Just found out that M599 can define keep out zones. But searching for "keep out" in the Wiki gave no result...
                            Bad news is, it only works on Duet3 boards due to RAM restrictions.
                            Guess I can build a few sandify patterns, that match such an odd working area, but wipe-patterns usually apply to rectangular or polar areas only
                              droftarts administrators @o_lampe
                              @o_lampe said in Spirograph emulator with Duet2:
                              As far as I'm aware there's no way for the firmware to do that. I guess you need to control that when slicing. I'd say it was rare to design a machine with the axes inside the build area.
                              Currently only one keep out zone is supported, and the job will be aborted with an error message if the toolhead tries to move inside that zone.
                              • o_lampeundefined
                                o_lampe @droftarts
                                @droftarts said in Spirograph emulator with Duet2:
                                You're right, but I wanted the footprint of the table aka delta tower-triangle to be small.
                                I got a nice 38cm dia glasstable with a predrilled footprint of 320mm. I'll have to place the towers accordingly.
                                Guess, I have to write a postprocessor which takes care of three keepout zones and doesn't quit the job.
                                  @o_lampe What do you plan to use to generate the drawing and erase pattern files? Maybe the keepout areas can be defined there.
                                  You can do all sorts of stuff with post processors. I use a PERL post processor to set the speed of moves on my table. It steps through the pattern file and determines whether each line of gcode draws on the table or moves the ball along the edges. If it's edge motion, it executes it at high speed (usually 1000 mm/sec), and if it's drawing on the table it executes at a lower speed (to preserve detail in the drawing).
                                  • o_lampeundefined
                                    @mrehorstdmd Currently I'm using Sandify, but I can also produce gcode from .dxf files. With inkscape I could theoreticaly use any bitmap to generate patterns and I could manually drag every knot of a path out of the zones.
                                    I used it frequently, when my K40 laser was new.
                                    I haven't thought to look elsewhere, but if others (CNC or laser scene? ) have the same problem with keep out zones, I'd be happy to know.
                                    Is the PERL post processor open source? I'm looking for a good starting point to write my own.(open file, modify gcode lines, write new file)
                                      @o_lampe Here's my PERL script for dual speed operation. I used a LOT of notes to make it easy for me to modify or fix because I don't do a lot of programming and have to relearn it for each project.
                                      This is how it is invoked:
                                      E:\Downloads>perl -w dual_speedify_v2.pl
                                      Warning- there's no error trapping, so be careful when you answer
                                      the questions that will follow. Use at your own risk!
                                      Type the name of the sandify pattern file:
                                      250519_01.gcode
                                      Enter the drawing speed in mm/sec
                                      150
                                      Enter the edge speed in mm/sec
                                      1000
                                      Enter the minimum X value of the pattern.
                                      0
                                      Enter the maximum X value of the pattern.
                                      590
                                      Enter the minimum Y value of the pattern.
                                      0
                                      Enter the maximum Y value of the pattern.
                                      980
                                      Enter the home position X ordinate.
                                      590
                                      Enter the home position Y ordinate.
                                      0
                                      Processing is complete.
                                      The dual speed output file is called 250519_01_9000_60000.gcode
                                      Check the output file to make sure it does what you think it will.
                                      And the attached file is the result. 250519_01_9000_60000.gcode ]
