    Why don't you use Cura slicer?
    173
    32.6k
    • kraegarundefined
      kraegar
      I stick with s3d out of laziness. If a print doesn't require support, cura looks about equal. S3D just slices faster, and I'm used to using it.
      If cura was smart enough to detect, on a per island basis, if there are overhangs, and not do retracts on them when possible, I'd look at switching in a hearbeat. It's the #1 bit of logic I can't believe no slicer has yet.
      (Setting a seam location / direction doesn't help on prints with multiple islands, or overhangs that shift in direction across a print).
      Bonus point if it knew to prefer inside corners for retract point. Another bonus point for avoiding travel over islands. Two bonus points if it knew not to travel over overhangs (since that's the most likely spot for curling, and therefore a collision resulting in a layer shift)
      • garyd9undefined
        garyd9
        @bot:
        Though, now that you mention it, the customer support leaves a lot to be desired too.
        Customer support for S3D leaves everything to be desired. For a 150 USD product that competes with free products, I expected to get reasonable support and perhaps attentive updates for my money. I didn't. At least most of my issues had resolutions posted by USERS of the product on various forums.
        Don't get me wrong - S3D is a good program, but it does have problems and it feels as though the company doesn't mind it having those problems. My mistake was that I wasn't still in my 2 week "return period" when I asked for support.
        As for Cura - I used a version 15.something, and it was okay. When I moved to a dual extruder machine, I also changed slicers to one that many suggested as being good for dual extruder setups. Since then, I tried a newer version of Cura (I think I recently tried 3.something?) but it was, as others have mentioned, very… clunky. For the price, it's a great slicer. However, when I have S3D already paid for (and I've already learned most of it's quirks) it's hard to use a different product that has a different workflow and different quirks.
        Perhaps when I find something I need my slicer to do, and S3D doesn't do it (but Cura does), I'll take the time to properly re-evaluate the newest Cura version and give it a fair trial.
        • Rgconnerundefined
          Rgconner
          Slic3r has multiple extruder support and also you can set temp/layer height differently at different points in the model.
          So if you have something that is fairly detailed at the bottom, then simple in the middle, and complicated at the top (think of a greek or roman column) you can have it print .15 at the bottom, .3 in the middle, and .1 at the top.
          • BDubsundefined
            BDubs
            Regarding S3D customer support/software support; I don't expect anything other than web support for a measly $149. I've been upgraded for free a number of times, it's never crashed on me even with 300Mb STL slices and they don't ask me to pay maintenance fees, unlike my professional software suites do/have. They cost me $7k/yr for the privilege of getting support if you need it and free updates to fix bugs they are responsible for anyway. I'm grateful S3D comes at such a low price. Plus, I have to research and read every other blessed thing in life, what's one more thing to figure out?
            • schneik80undefined
              schneik80
              I would try cura again if there was a utility to import an FFF profile from S3D. I have a lot of time tweaking my profile and the time it takes to port these settings to another slicer is more time than its worth. S3D is printing just fine for me.
              • SuperJETTundefined
                SuperJETT
                I do a ton of multicolor prints - keychains, etc - that I design around changing filament at a certain layer. In Slic3r I can find that layer in preview and it tells me the Z height so I can search for that in the gcode and insert an M226 pause. Cura does not have that ability in the new version that I have found, just a layer number which is not nearly as easy to figure out. Yes it can, but…
                That's a big one for me, and seems like it would be an easy addition to show layer number/mm or at least configure that.
                Custom CoreXY at home with Duet Wifi, Hemera
                • Artyundefined
                  Arty
                  1. No slowdown when printing bridges.
                  2. Too much options.
                  • fmaundefined
                    fma
                    I drop Cura some moths ago because when printing perimeters, it prints one wall at a time, instead of printing all walls of the first perimeter, then move to the second perimeter and print all its walls, and so on…
                    It does not matter for any layers (except time lost), but on the first layer, it tends to tear off the wall when moving towards the second perimeter. If you have small perimeters, then you get a crappy first layer.
                    I asked on the forum to change that, and I was told it was not possible because of Bowden (don't remember exactly, but it was non sens to me).
                    At least, if it was able to slow down on small perimeters, it would no tear off the wall. But it does not... So, user has to slow down the entire first layer at a ridiculous speed, even non-printing speed.
                    Second think I don't like is the GUI: why spending so much time in re-writing a complete graphic lib? Why don't using Qt basic tools? It is ugly, not really handy (rotating the part!) and it takes hours to start. And it is a 100Mb executable!!!
                    That's why I switched back to Slic3r.
                    What Cura does well is support; Slic3r supports are crap.
                    Frédéric
                    • tech-ratonundefined
                      tech-raton
                      I use CURA 15.4 for my older printer.
                      Everything is configured, it just works. It's nice and I don't have the courage to change slicer for it…
                      I used Cura 3.1 for my newer printer and I prefer Slic3r PE.
                      The main problems with Cura are:
                      • Relative extrusion that is not really explicit
                      • Bridging parameters that can't be modified
                      • No manual support
                        -No easy way to change the Jerk and Accel parameters to have a more precise Time Estimation
                      • No small perimeters parameters (that was the deal breaker of Slic3r for me).
                      But Slic3r is not really better, it's just different, with other quirks and good points.
                      I agree with FMA:
                      @fma:
                      One very positive point of Cura is the Ironing feature. It's a nice implementation…
                      Cura is free, as Slic3r and it's a very nice feature too. ^^
                      • burtoogleundefined
                        burtoogle
                        Thanks for all of the responses, keep them coming. Some valid points have been raised (and also some misunderstandings).
                        Cura comprises the GUI front end which is written in Python and the actual slicer itself which is a C++ program. The slicer
                        (CuraEngine) is quite fast, what causes most of the slowness in Cura is the Python GUI. Personally, I only work on the code for CuraEngine and having nothing to do with the GUI but I know they are putting great effort into improving it. However, it's probably never going to be able to handle huge models as well as other slicers that are written completely in C, C++, etc. BTW it is quite possible to use CuraEngine without the GUI front end and I know people drive it from scripts.
                        I am hoping to meet some of the GUI developers next month and so will pass on the points that are being raised in this thread. I know that some of these are being worked on already.
                        • DADIYundefined
                          DADIY
                          Mostly stopped using it because it didn't support Z offsets for the bed. Although I have S3D I much prefer to use Slic3r PE.
                            SuperJETT
                            @fma:
                            Which version are you using? I didn't use supports with Slic3r for a long time because they were junk, but have been using them again with Slic3r PE and they are working pretty well IMO.
                              deckingman
                              @SuperJETT:
                              @fma:
                              +1
                              • whosrdaddyundefined
                                whosrdaddy
                                I used the old cura, did not like the new interface and moved on to Slic3r PE.
                                Yes supports are not the best feature in Slic3r, whenever I need to add manual supports, I modify the STL in
                                meshmixer which works quite well:
                                https://www.youtube.com/watch?v=aFTyTV3wwsE
                                • botundefined
                                  bot
                                  @burtoogle:
                                  Good point. I have not tried the very large models through the cura engine without the python GUI.
                                  I do actually like the slicing engine of cura, though it's not perfect (like none of them are).
                                  Thanks for the interest here, and your contributions to open source software.
                                  *not actually a robot
                                  • Billhc83undefined
                                    Billhc83
                                    I used older versions (and still do) I do not like the new interface i find it confusing i guess. There are some settings i feel could use a better (more specific maybe) description of what they do. It will also do stupid things when slicing sometimes. For example small circles (3mm dia) it will revisit the perimeter of these circles 3 times (3 shell) when it really should do the whole 3 at once because these small circles sometimes have a problem adhering when you do multiple passes on the first layer.
                                    • BDubsundefined
                                      BDubs
                                      Developers should always include a 'Classic' interface for legacy users. Nothing like completely throwing your user base under the bus by forcing them into a new interface. Microsoft did this first with their development tools, then the OS with this metro nonsense. It takes VERY LITTLE effort to offer a classic style interface, or one that is dynamic enough to toggle views on and off. The latest version does do this to a limited point - but the interface is still not as elegant as earlier versions. It's just hard on the eyes.
                                      There's just too much going on in the versions after 15.06 - it's too busy and that breaks concentration and makes your eye wander. Maybe some testing should have been done before the entire interface was revamped, using a product similar to Morae: https://www.techsmith.com/morae.html
                                      Granted Cura is free…so I have no recourse or say in the interface (but I did buy a UM2 retail so maybe that counts for some pull).
                                      The major appeal of Cura over others was how simple and to the point the interface was in the earlier versions...which is why I installed v2...and v3...and have yet to print anything out with either. I go right back to v15.06.
                                        burtoogle
                                        This is not actually a limitation in Cura anymore as it has an option to optimize the order that walls are printed so that it will print all the walls around a single hole first before moving on to another hole.
                                          burtoogle
                                            T3P3Tony administrators
                                            One point to add is that you can really improve the usability of cura with big/lots of models if you turn off the auto slicing of models. that way you can sort out the build plate move things, rotate etc and then slice the model.
