    Laser filament monitor
    Filament Monitor
    73
    179
    41.5k
    • Qdeathstarundefined
      Qdeathstar
      The prussa monitor has mixed reviews….
        @Qdeathstar:
        Have you a link?
        I looked at the code that Prusa uses. It checks that when forward extrusion is commanded, forward filament movement is detected. It doesn't attempt to correlate the amount of movement with the amount of extrusion commanded.
          Qdeathstar
          https://shop.prusa3d.com/forum/original-prusa-i3-mk3-f30/filament-sensor-n-a-t12653.html
          https://shop.prusa3d.com/forum/original-prusa-i3-mk3-f30/running-out-of-filament-t13536.html
          https://shop.prusa3d.com/forum/original-prusa-i3-mk3-f30/filament-sensor-initiate-auto-load-while-printing-t12460.html
          https://shop.prusa3d.com/forum/original-prusa-i3-mk3-f30/mk3-asking-me-to-unload-filament-multiple-times-du-t12786.html
          • fmaundefined
            fma
            David, to help detect the tricky filaments, what about using a little lens to magnify the image of the filament?
            Frédéric
            • Markdndundefined
              Markdnd
              Yet another idea (sorry)
              From the sound of things the magnetic sensor is based on a magnet and hall effect sensor arrangement which suffers from alignment issues.
              Have you considered / tried a resolver solution where you have a magnet rotating inside a coil. Alignment is far less critical and you could create a simple movement detector by smply using a voltage sensor to drive a limit input.
              If you want something more complex that could be used to measure speed and extrusion distance there are off the shelf chips to interface with them.
              E.g. http://www.analog.com/en/products/analog-to-digital-converters/integrated-special-purpose-converters/synchroresolver-to-digital-converters.html
              • robmundefined
                robm
                @resam:
                Detecting under-extrusion or skipped steps would be nice, but I there is no real benefit anyway.
                Just to highlight another opinion, I want to accurately detect motion so I can write a macro that works through a series of speeds and temperatures to profile a new roll of filament to determine volumetric extrusion limits. Also seems like if you are looking for automatic monitoring to save a 50 hour print, you need a manual solution for out of filament or nozzle jam so why require an automatic response for under extrusion?
                @Markdnd:
                Not clear to me that the alignment issues could not be solved by a better housing for the rotating magnet system?
                Also seems like Duet3D could just design and sell different option circuit boards with the firmware to hook them up? Another design would be a rotating encoder with LED sensor (like the old computer mice), using a mechanical linkage to the filament like the rotating magnet sensor. There will be pros and cons for all the designs, just depends on what the user is after as to which works best.
                • DjDemonDundefined
                  DjDemonD
                  The magnet sensor version worked great until the assembly shifted a small amount and the I got a false trigger. However an injection moulded or machined assembly or a more optimised printed design would solve this problem.
                  www.precisionpiezo.co.uk
                    Qdeathstar
                    what about sls nylon to print the enclosure for the magnetic sensor? I know forms for injection molding add a significant cost/risk to the project, and machining is probably even more expensive.
                    • DjDemonDundefined
                      DjDemonD
                      • carlossprundefined
                        carlosspr
                        I am appealed by the idea of the use of the filament monitor as contactless displacement sensor and the implementation of a Kalman filter to increase accuracy. My Idea is to mount the sensor on the X and Y belts.
                        My reasoning is that the optical sensor counts could be used as a tachometer to measure velocity. Both the velocity and position information already present on the system can be combined in a Kalman filter to compute the position with higher accuracy. It will be particularly accurate because the sources of noise are unrelated (little noise cross correlations), i.e. the error biasing any one estimate due to position errors will be mitigated by velocity and vice versa. With this technique we could beat the 1.8 or 0.9 degrees per step resolution.
                        • EasyTargetundefined
                          EasyTarget
                          @carlosspr:
                          Isn't this what microstepping is for?
                          Unless your rotation sensor is geared etc so it can beat 1/16 or more of that step resolution (a direct magnetic rotation sensor isn't nearly that accurate) you won't have any more info than you can already derive from the controller by simply asking for it's current position. You can detect missed steps, but the controller already does that for you because the controller already does some of the feedback sensing you are looking for.
                          • I'd be more interested in an acceleration sensor in the printhead and feeding back max/min readings from that, then adjusting speeds to keep within boundaries and limits based on this direct observation. Eg Closing the loop with real data, monitoring the belt wont help detect loose belts or sliders snatching/stiction, but an accelerometer would.
                          Disaster? The original Printeye is dying with RRF 3.5 (M208 depreciated).
                          PrintPy2024 to the rescue!
                          MicroPython based; with simple wiring and and no custom PCB.
                            Development of the laser filament monitor has stalled because we are too busy with other things at present. We might be willing to supply one of our prototypes to a user who meets the following conditions, to try to speed up finishing it:
                            • Must have a functioning 3D printer and a supply of black PLA to print small parts with;
                            • Must have enough experience of OpenSCAD to modify an existing design and preferably do new designs;
                            • Preferably either be located in the UK or have experience of programming an attiny microcontroller e.g. with an AVRISP Mk2 or an Arduino running ArduinoISP + 6-pin programing connector.
                            nopheadundefined keyz182undefined 2 Replies Last reply Reply Quote 0
                            • jbarrosundefined
                              jbarros
                              @dc42:
                              Having lost yet another piece, this one a 19h print because of a "knot" on the filament roll, I'm highly motivated to get a laser filament monitor.
                              Is this opportunity still on the table?
                              Have almost 2 printers (finishing up a HEVO), Duet Wifis and just got an IR probe.
                              Not an OpenSCAD expert but hey if it's programmable… 😉
                              Lots of Arduinos and other microcontrollers and programmers.
                              Portugal based but willing to pay for all expenses.
                              • Mystaundefined
                                Mysta
                                Are these still available? to US?
                                  We are making a batch of prototype laser filament monitors later this month.
                                  • fmaundefined
                                    fma
                                    I'm interested to test one of these, with a few folks of our hackerspace, in France (https://www.logre.eu/wiki)... we have all asked skills.
                                    Frédéric
                                    • THPundefined
                                      THP
                                      I would be very interested in working on this, I PM'ed you a couple of weeks ago regarding assisting with the laser filament monitor. I am located in the USA with the needed tools to program the attiny. I can even do smd board assembly if needed.
                                      Custom IDEX with Duet Ethernet & x5, IR probe, Titan Aero w/ PT100s, Heated Bed, and Chamber with Thermocouples.
                                        T3P3Tony administrators
                                        I am compiling a list big people who have volunteered, thanks! It will be at least 4 weeks before we get the components and I intend to test a large batch to looks for consistency first. Updates to follow.
                                        adam2070undefined 1 Reply Last reply Reply Quote 0
                                        • pjr3Dundefined
                                          pjr3D
                                          Please add me to the beta test list also. I am happy to test and report and plan to buy several for my machines on release.
                                          • briangilbertundefined
                                            briangilbert
                                            @T3P3Tony please count me in if there is still room for more testers
                                            Co-creator of the Zesty Nimble direct drive extruder
