    New Product Release - Precision Piezo Orion
    Third-party add-ons
    20
    79
    13.9k
    • Jackalundefined
      Jackal
      Great to see more innovation on the pizeo sensors.
      Just out of interest, do you plan to make a version compatible with the v6 threaded heatsink?
      • DjDemonDundefined
        DjDemonD
        @Mike - this type of PCB might be useful in an underbed setup, but it won't eliminate wires (which is the primary purpose of the Orion over the Piezo20) as invariably you'll need three units one for each bed support and they will need to be wired together. As such underbed is still best achieved using 3 piezos and one controller - the universal kit PCB.
        @Jackal - this is an interesting question, we could make the lower clamp part with just a thread in it, or an embedded M12 nut (I think its M12 fine thread isn't it?). However the threaded heatsink has its best application on the Smart Effector (where you do not need a piezo z -probe), but the Orion clamp for the groovemount is extremely secure, so if you want to use the Orion I'd buy ideally, a genuine V6 groovemount heatsink, but practically a clone v6 heatsink will do. You don't need bowden on the heatsink as the Orion has a straight through bowden coupler like a v6.
        www.precisionpiezo.co.uk
        • uk25undefined
          uk25
          Wow. Your Orion module is looking very interesting.
          I have several questions about it:
          1. Will this module be available without 3d printed parts?
          2. Can i use it upside down, to place the connector on top side?
          3. Where can i get its dimensions with holes?
          • DjDemonDundefined
            DjDemonD
            Hi thanks for taking an interest.
            1. Eventually, production so far is being channelled into the complete units, demand is fairly high, but we would expect a PCB only offering at some point. Whether it will be significantly less expensive is doubtful as the PCB constitutes quite a chunk of the value in the system.
            2. Yes you could repurpose the pcb to work in a variety of different orientations. Future designs will potentially allow use as a titan extruder mounting plate for example.
            3. We have someone who is willing to make a 3d model of the unit, we just have to get one to him. I will get the dimensions or a drawing and link to it asap. Idris is running the company now as I have had to take time off due to family commitments.
            • AlexLinundefined
              AlexLin
              Search thingiverse for piezo Orion and you'll find stl for the parts and the PCB is 1.6mm thick, I heard from Idris
              • ShadowXundefined
                ShadowX
                How does the hot end mount to the underside of the Orion in each application?
                • uk25undefined
                  uk25
                  @AlexLin:
                  Thanks. I found the model and leave its link here, may be it will be useful for somebody.
                  https://makerware.thingiverse.com/thing:2841681
                  @DjDemonD:
                  Thanks. Detailed 3d model will be very handy or at least an exact drawing.
                  • DjDemonDundefined
                    DjDemonD
                    @ShadowX:
                    It mounts via the clamp, which is attached to the upper part with 4 screws.
                    • nullenvoidundefined
                      nullenvoid
                      Thank you! I just installed an Orion on my main 3D printer and it's working great.
                      • Moriquendiundefined
                        Moriquendi
                        Looks really good, glad you're happy with it.
                        Idris
                        • DjDemonDundefined
                          DjDemonD
                          Well I guess this goes some way to answering the question of how much weight can you hang from it? Be keen to see how it does long term, they're fairly tough.
                            Moriquendi
                            I'm somewhat surprised that it's working well with so much additional weight hanging off the hotend, I'd want to mount anything I could from the carriage rather than the Orion.
                            Idris
                            • pogo1213undefined
                              pogo1213
                              Where do I find the stls for the groove mount setup. My groove mount broke last night so I need to reprint it. Thanks in advance for the help.
                              burtoogleundefined 1 Reply Last reply Reply Quote 0
                              • burtoogleundefined
                                burtoogle @pogo1213
                                Hello @pogo1213 . Is it the Orion groove mount STL you want? If so, I can provide that and also a modified version that I am currently using because the original did not fit well and was also too flexible.
                                Orion groovemount original stl + my hacked version
                                • hevilpundefined
                                  hevilp
                                  Hi, there are any news on the chimera mount?
                                  Moriquendiundefined 1 Reply Last reply Reply Quote 0
                                    Moriquendi @hevilp
                                    @hevilp Chimera mount is out with beta testers at the moment but I haven't heard back from them yet.
                                    keyz182undefined 1 Reply Last reply Reply Quote 0
                                    • keyz182undefined
                                      keyz182 @Moriquendi
                                      @moriquendi said in New Product Release - Precision Piezo Orion:
                                      Oooh, I've been looking for a better way to mount my Chimera, please keep us updated 🙂
                                        Moriquendi
                                        I've just uploaded the prototype Chimera/Cyclops+ mount, I'd welcome your feedback if you try it out.
                                        Idris
                                        • keyz182undefined
                                          keyz182 @Moriquendi
                                          @moriquendi I'll have to wait for the couplings to arrive in the week (just ordered), so will let you know how it goes, thanks!
                                          • hevilpundefined
                                            hevilp
                                            How do I mount it? Which X-carriage is neccessary? Can you show a picture?
                                            I have a HEVO and there are a lot of hotend carriages...
                                            Which is compatible with the chimera orion mount?
                                            keyz182undefined 2 Replies Last reply Reply Quote 0
