    New Product Release - Precision Piezo Orion
    Third-party add-ons
    20
    79
    14.2k
    • c310undefined
      c310
      is there anything for chimera dual extruder?
      • DjDemonDundefined
        DjDemonD
        Not yet, underbed setup is still the most likely setup to work for more complex hotends.
        www.precisionpiezo.co.uk
        • Mikeundefined
          Mike
          Nice! Do you plan to release those for underbed setups? So far those look like single channel only.
          • Jackalundefined
            Jackal
            Great to see more innovation on the pizeo sensors.
            Just out of interest, do you plan to make a version compatible with the v6 threaded heatsink?
            • DjDemonDundefined
              DjDemonD
              @Mike - this type of PCB might be useful in an underbed setup, but it won't eliminate wires (which is the primary purpose of the Orion over the Piezo20) as invariably you'll need three units one for each bed support and they will need to be wired together. As such underbed is still best achieved using 3 piezos and one controller - the universal kit PCB.
              @Jackal - this is an interesting question, we could make the lower clamp part with just a thread in it, or an embedded M12 nut (I think its M12 fine thread isn't it?). However the threaded heatsink has its best application on the Smart Effector (where you do not need a piezo z -probe), but the Orion clamp for the groovemount is extremely secure, so if you want to use the Orion I'd buy ideally, a genuine V6 groovemount heatsink, but practically a clone v6 heatsink will do. You don't need bowden on the heatsink as the Orion has a straight through bowden coupler like a v6.
              • uk25undefined
                uk25
                Wow. Your Orion module is looking very interesting.
                I have several questions about it:
                1. Will this module be available without 3d printed parts?
                2. Can i use it upside down, to place the connector on top side?
                3. Where can i get its dimensions with holes?
                • DjDemonDundefined
                  DjDemonD
                  Hi thanks for taking an interest.
                  1. Eventually, production so far is being channelled into the complete units, demand is fairly high, but we would expect a PCB only offering at some point. Whether it will be significantly less expensive is doubtful as the PCB constitutes quite a chunk of the value in the system.
                  2. Yes you could repurpose the pcb to work in a variety of different orientations. Future designs will potentially allow use as a titan extruder mounting plate for example.
                  3. We have someone who is willing to make a 3d model of the unit, we just have to get one to him. I will get the dimensions or a drawing and link to it asap. Idris is running the company now as I have had to take time off due to family commitments.
                  • AlexLinundefined
                    AlexLin
                    Search thingiverse for piezo Orion and you'll find stl for the parts and the PCB is 1.6mm thick, I heard from Idris
                    • ShadowXundefined
                      ShadowX
                      How does the hot end mount to the underside of the Orion in each application?
                      • uk25undefined
                        uk25
                        @AlexLin:
                        Thanks. I found the model and leave its link here, may be it will be useful for somebody.
                        https://makerware.thingiverse.com/thing:2841681
                        @DjDemonD:
                        Thanks. Detailed 3d model will be very handy or at least an exact drawing.
                        • DjDemonDundefined
                          DjDemonD
                          @ShadowX:
                          It mounts via the clamp, which is attached to the upper part with 4 screws.
                          • nullenvoidundefined
                            nullenvoid
                            Thank you! I just installed an Orion on my main 3D printer and it's working great.
                            • Moriquendiundefined
                              Moriquendi
                              Looks really good, glad you're happy with it.
                              Idris
                              • DjDemonDundefined
                                DjDemonD
                                Well I guess this goes some way to answering the question of how much weight can you hang from it? Be keen to see how it does long term, they're fairly tough.
                                  Moriquendi
                                  I'm somewhat surprised that it's working well with so much additional weight hanging off the hotend, I'd want to mount anything I could from the carriage rather than the Orion.
                                  Idris
                                  • pogo1213undefined
                                    pogo1213
                                    Where do I find the stls for the groove mount setup. My groove mount broke last night so I need to reprint it. Thanks in advance for the help.
                                    burtoogleundefined 1 Reply Last reply Reply Quote 0
                                    • burtoogleundefined
                                      burtoogle @pogo1213
                                      Hello @pogo1213 . Is it the Orion groove mount STL you want? If so, I can provide that and also a modified version that I am currently using because the original did not fit well and was also too flexible.
                                      Orion groovemount original stl + my hacked version
                                      • hevilpundefined
                                        hevilp
                                        Hi, there are any news on the chimera mount?
                                        Moriquendiundefined 1 Reply Last reply Reply Quote 0
                                          Moriquendi @hevilp
                                          @hevilp Chimera mount is out with beta testers at the moment but I haven't heard back from them yet.
                                          keyz182undefined 1 Reply Last reply Reply Quote 0
                                          • keyz182undefined
                                            keyz182 @Moriquendi
                                            @moriquendi said in New Product Release - Precision Piezo Orion:
                                            Oooh, I've been looking for a better way to mount my Chimera, please keep us updated 🙂
