    Firmware wishlist and priorities for Duet WiFi and Duet Ethernet
    Firmware wishlist
    113
    236
    50.8k
    • Quadcellsundefined
      Quadcells
      17
      1
      Thanks
      /quadcells
        dc42 administrators @MitchD
        @mitchd said in Firmware wishlist and priorities for Duet WiFi and Duet Ethernet:
        Would it be possible to make the Paneldue play a tune when the print finishes? This just makes the whole experience a bit more friendly, especially when we show off the printers at maker faires etc.
        I think it should already be possible, using a combination of M300 and G4.
        DADIYundefined 1 Reply Last reply Reply Quote 0
        • audryhomeundefined
          audryhome @dc42
          @dc42 Implement G29 T1 tag to list the height table, this makes it possible to communicate with Bed Level Visualizer
          see https://plugins.octoprint.org/plugins/bedlevelvisualizer/ for info.
          All Octoprint users will love this I guess.
          Low priority since this exists in the DUET GUI as a workaround.
          • rhkleinundefined
            rhklein
            Didn't I read somewhere that it is already implemented or was it a wishlist too? (firmware not Deckingmans script)
            • DADIYundefined
              DADIY @dc42
              @dc42 This is already possible, I have the following in my end gcode -
              ;Play beep beep beep to show print ended.
              M300 P500 S5000
              G4 P400
              M300 P500 S5000
              G4 P400
              M300 P500 S5000
              G4 P400
              M300 P500 S5000
                Phaedrux Moderator @MitchD
                @mitchd If you're looking for a little jingle when a print is finished and not just a beep, try this one:
                ; Play a triumphant tune to celebrate a successful print.
                M400			; Clear queue before jingle
                G4 S1
                M300 P250 S750
                G4 P251
                M300 P200 S1250
                G4 P201
                M300 P250 S750
                G4 P251
                M300 P200 S1250
                G4 P201
                M300 P250 S2500
                G4 P251
                M300 P150 S2000
                G4 P151
                M300 P150 S2500
                G4 P151
                M300 P350 S3700
                G4 P351
                M400
                jnolan72undefined 1 Reply Last reply Reply Quote 0
                • jnolan72undefined
                  jnolan72 @Phaedrux
                  That is too cool
                  @phaedrux said in Firmware wishlist and priorities for Duet WiFi and Duet Ethernet:
                  G4 S1
                  M300 P250 S750
                  G4 P251
                  M300 P200 S1250
                  G4 P201
                  M300 P250 S750
                  G4 P251
                  M300 P200 S1250
                  G4 P201
                  M300 P250 S2500
                  G4 P251
                  M300 P150 S2000
                  G4 P151
                  M300 P150 S2500
                  G4 P151
                  M300 P350 S3700
                  G4 P351
                  M400
                    Phaedrux Moderator @jnolan72
                    @jnolan72 If you like that one I have another one for printer start up and another for right before the print starts.
                    I've tried to program more complex tunes but the more commands you send the more likely the system is to miss a tone or stutter. The buffer can only handle so much I guess. Hence having to issue an M400 before and after. This is more noticeable at printer startup than it is say before or after a print.
                    ; Startup Tune. Placed at the end of config.g
                    M400
                    G4 S2
                    M300 P200 S2000
                    G4 P201
                    M300 P200 S2250
                    G4 P201
                    M300 P200 S2000
                    G4 P201
                    M300 P200 S2855
                    G4 P201
                    M300 P200 S2500
                    G4 P201
                    M300 P200 S2200
                    G4 P201
                    M300 P200 S2500
                    G4 P201
                    M300 P200 S2900
                    G4 P201
                    M300 P300 S3500
                    G4 S1
                    M400
                    ; Lucky tune to start print off on the right foot. Placed in slicer start g-code.
                    M300 P200 S1000
                    G4 P201
                    M300 P200 S1250
                    G4 P201
                    M300 P200 S1100
                    G4 P201
                    M300 P200 S2000
                    G4 P201
                    M300 P200 S1500
                    G4 P201
                    M300 P200 S1000
                    G4 P201
                    M300 P200 S1300
                    G4 P201
                    M300 P200 S1000
                    G4 P201
                    M300 P300 S1500
                    G4 S1
                    M400
                    • mgrimes1907undefined
                      mgrimes1907
                      • Coffeeundefined
                        Coffee
                        Thanks guys for the beeps and tunes! My old Creatbot beeps and I was missing that on this new build.
                          Phaedrux Moderator @Coffee
                          @coffee Last one... Inspired by my Roomba
                          ; Charge.g
                          ; Duh nuh nun nah nah naah Charge!
                          M400
                          G4 S1
                          M300 P295 S520
                          G4 P295
                          M300 P250 S650
                          G4 P250
                          M300 P250 S750
                          G4 P250
                          M300 P285 S850
                          G4 P450
                          M300 P285 S850
                          G4 P285
                          M300 P625 S1100
                          G4 S1
                          M400
                          Coffeeundefined 1 Reply Last reply Reply Quote 0
                          • SnowCrashundefined
                            SnowCrash
                            If this is still relevant, these are my picks:
                            1
                            20
                            Thanks!
                            • Coffeeundefined
                              Coffee @Phaedrux
                              @phaedrux THANKS !!!
                              • resamundefined
                                resam
                                @SnowCrash did you follow all the recent Firmware releases?
                                As far as I can tall, all the picks you listed are already implemented to some degree.
                                @dc42 as this threads continues to grow and grow, I would recommend closing it, and opening a fresh one after 2.0 and 1.21.1 is released.
                                SnowCrashundefined 1 Reply Last reply Reply Quote 1
                                  SnowCrash @resam
                                  @resam said in Firmware wishlist and priorities for Duet WiFi and Duet Ethernet:
                                  Thanks @resam! That's great news 🙂
                                  To your question, I haven't been following the recent firmware releases for the simple reason that I only got my DuetWifi a short while ago and it already had the latest firmware already installed.
                                  However, I'm definitely planning on doing so in the future.
                                  • kenblu24undefined
                                    kenblu24
                                    1 & 2, 6, 8, 3
                                    resamundefined 1 Reply Last reply Reply Quote 0
                                    • resamundefined
                                      resam @kenblu24
                                      @kenblu24 1, 6, 8, and 3 are already done. Please read the release notes of recent firmware updates.
                                      2 will probably never make it due to memory & cpu restrictions.
                                      kenblu24undefined 1 Reply Last reply Reply Quote 0
                                      • kenblu24undefined
                                        kenblu24 @resam
                                        @resam darn 😞 #2 would have been awesome to have. Sorry, haven't been keeping up with the updates.
                                        • denkeundefined
                                          denke
                                          Can we please add to the wishlist?
                                          -Improved motion planning as of:
                                          https://forum.duet3d.com/topic/4802/6th-order-jerk-controlled-motion-planning
                                          I really hope it will be available for deltas too...
                                          -Print resume from a given layer (Maybe the user could set the printhead to the appropriate layer and hit resume) ... From that point the head would go up, heat, (prime?) and continue the print.
                                          I know it's possible threw editing the resume file, but this would make it so much easier...
                                          Thanks!
                                          • BenDieselundefined
                                            BenDiesel
                                            It would be nice if the wifi would create it's own network if one isn't detected when booted up. And have the name of the network be the name of the machine.
