    Firmware wishlist and priorities for Duet WiFi and Duet Ethernet
    Firmware wishlist
    113
    236
    50.8k
    • DADIYundefined
      DADIY @dc42
      @dc42 This is already possible, I have the following in my end gcode -
      ;Play beep beep beep to show print ended.
      M300 P500 S5000
      G4 P400
      M300 P500 S5000
      G4 P400
      M300 P500 S5000
      G4 P400
      M300 P500 S5000
        Phaedrux Moderator @MitchD
        @mitchd If you're looking for a little jingle when a print is finished and not just a beep, try this one:
        ; Play a triumphant tune to celebrate a successful print.
        M400			; Clear queue before jingle
        G4 S1
        M300 P250 S750
        G4 P251
        M300 P200 S1250
        G4 P201
        M300 P250 S750
        G4 P251
        M300 P200 S1250
        G4 P201
        M300 P250 S2500
        G4 P251
        M300 P150 S2000
        G4 P151
        M300 P150 S2500
        G4 P151
        M300 P350 S3700
        G4 P351
        M400
        jnolan72undefined 1 Reply Last reply Reply Quote 0
        • jnolan72undefined
          jnolan72 @Phaedrux
          That is too cool
          @phaedrux said in Firmware wishlist and priorities for Duet WiFi and Duet Ethernet:
          G4 S1
          M300 P250 S750
          G4 P251
          M300 P200 S1250
          G4 P201
          M300 P250 S750
          G4 P251
          M300 P200 S1250
          G4 P201
          M300 P250 S2500
          G4 P251
          M300 P150 S2000
          G4 P151
          M300 P150 S2500
          G4 P151
          M300 P350 S3700
          G4 P351
          M400
            Phaedrux Moderator @jnolan72
            @jnolan72 If you like that one I have another one for printer start up and another for right before the print starts.
            I've tried to program more complex tunes but the more commands you send the more likely the system is to miss a tone or stutter. The buffer can only handle so much I guess. Hence having to issue an M400 before and after. This is more noticeable at printer startup than it is say before or after a print.
            ; Startup Tune. Placed at the end of config.g
            M400
            G4 S2
            M300 P200 S2000
            G4 P201
            M300 P200 S2250
            G4 P201
            M300 P200 S2000
            G4 P201
            M300 P200 S2855
            G4 P201
            M300 P200 S2500
            G4 P201
            M300 P200 S2200
            G4 P201
            M300 P200 S2500
            G4 P201
            M300 P200 S2900
            G4 P201
            M300 P300 S3500
            G4 S1
            M400
            ; Lucky tune to start print off on the right foot. Placed in slicer start g-code.
            M300 P200 S1000
            G4 P201
            M300 P200 S1250
            G4 P201
            M300 P200 S1100
            G4 P201
            M300 P200 S2000
            G4 P201
            M300 P200 S1500
            G4 P201
            M300 P200 S1000
            G4 P201
            M300 P200 S1300
            G4 P201
            M300 P200 S1000
            G4 P201
            M300 P300 S1500
            G4 S1
            M400
            • mgrimes1907undefined
              mgrimes1907
              • Coffeeundefined
                Coffee
                Thanks guys for the beeps and tunes! My old Creatbot beeps and I was missing that on this new build.
                  Phaedrux Moderator @Coffee
                  @coffee Last one... Inspired by my Roomba
                  ; Charge.g
                  ; Duh nuh nun nah nah naah Charge!
                  M400
                  G4 S1
                  M300 P295 S520
                  G4 P295
                  M300 P250 S650
                  G4 P250
                  M300 P250 S750
                  G4 P250
                  M300 P285 S850
                  G4 P450
                  M300 P285 S850
                  G4 P285
                  M300 P625 S1100
                  G4 S1
                  M400
                  Coffeeundefined 1 Reply Last reply Reply Quote 0
                  • SnowCrashundefined
                    SnowCrash
                    If this is still relevant, these are my picks:
                    1
                    20
                    Thanks!
                    • Coffeeundefined
                      Coffee @Phaedrux
                      @phaedrux THANKS !!!
                      • resamundefined
                        resam
                        @SnowCrash did you follow all the recent Firmware releases?
                        As far as I can tall, all the picks you listed are already implemented to some degree.
                        @dc42 as this threads continues to grow and grow, I would recommend closing it, and opening a fresh one after 2.0 and 1.21.1 is released.
                        SnowCrashundefined 1 Reply Last reply Reply Quote 1
                          SnowCrash @resam
                          @resam said in Firmware wishlist and priorities for Duet WiFi and Duet Ethernet:
                          Thanks @resam! That's great news 🙂
                          To your question, I haven't been following the recent firmware releases for the simple reason that I only got my DuetWifi a short while ago and it already had the latest firmware already installed.
                          However, I'm definitely planning on doing so in the future.
                          • kenblu24undefined
                            kenblu24
                            1 & 2, 6, 8, 3
                            resamundefined 1 Reply Last reply Reply Quote 0
                            • resamundefined
                              resam @kenblu24
                              @kenblu24 1, 6, 8, and 3 are already done. Please read the release notes of recent firmware updates.
                              2 will probably never make it due to memory & cpu restrictions.
                              kenblu24undefined 1 Reply Last reply Reply Quote 0
                              • kenblu24undefined
                                kenblu24 @resam
                                @resam darn 😞 #2 would have been awesome to have. Sorry, haven't been keeping up with the updates.
                                • denkeundefined
                                  denke
                                  Can we please add to the wishlist?
                                  -Improved motion planning as of:
                                  https://forum.duet3d.com/topic/4802/6th-order-jerk-controlled-motion-planning
                                  I really hope it will be available for deltas too...
                                  -Print resume from a given layer (Maybe the user could set the printhead to the appropriate layer and hit resume) ... From that point the head would go up, heat, (prime?) and continue the print.
                                  I know it's possible threw editing the resume file, but this would make it so much easier...
                                  Thanks!
                                  • BenDieselundefined
                                    BenDiesel
                                    It would be nice if the wifi would create it's own network if one isn't detected when booted up. And have the name of the network be the name of the machine.
                                      Phaedrux Moderator @BenDiesel
                                      @bendiesel said in Firmware wishlist and priorities for Duet WiFi and Duet Ethernet:
                                      Something like that could be used for initial configuration as well much like other wifi devices. It creates its own access point which you connect to, you enter the wifi network information and reboot. Then continue with configuration afterwards. No need to connect to a PC first via usb or edit files on an SD card.
                                      And having it fall back to the same access point mode if the configured network is no longer present would be helpful.
                                      • denkeundefined
                                        denke
                                        Some home automation devices use the same logic, some of them even have a dedicated button which puts them into ap mode, where you can configure the network.
                                          It's mostly a security issue. If for some reason the initial connection fails and the Duet goes into AP mode, do you really want anybody to be able to access your Duet?
                                          A possible mitigation would be to use a password based on the chip unique ID and to put that password on a sticker attached to the Duet. It could still be inconvenient if your Duet was buried below the bed of a delta printer so you couldn't see the sticker.
                                          • denkeundefined
                                            denke
                                            You could use a part of the serial, which could exist on a sticker, and coud be queried threw M122, so it's accessable directly and could be red threw usb in case the panel is buried.
                                            A problem would still exist, if there is a power outage, the duet would boot up much quicker than a WIFI router, so if this functionality is automatic, then it would go to AP mode...
                                            As a workarould for the duet 3, you could add a button on the panel to put it into AP mode
                                            mickey30mundefined 1 Reply Last reply Reply Quote 0
