    Firmware wishlist and priorities for Duet WiFi and Duet Ethernet
    Firmware wishlist
    113
    236
    50.8k
    • Coffeeundefined
      Coffee
      Thanks guys for the beeps and tunes! My old Creatbot beeps and I was missing that on this new build.
        Phaedrux Moderator @Coffee
        @coffee Last one... Inspired by my Roomba
        ; Charge.g
        ; Duh nuh nun nah nah naah Charge!
        M400
        G4 S1
        M300 P295 S520
        G4 P295
        M300 P250 S650
        G4 P250
        M300 P250 S750
        G4 P250
        M300 P285 S850
        G4 P450
        M300 P285 S850
        G4 P285
        M300 P625 S1100
        G4 S1
        M400
        Coffeeundefined 1 Reply Last reply Reply Quote 0
        • SnowCrashundefined
          SnowCrash
          If this is still relevant, these are my picks:
          1
          20
          Thanks!
          • Coffeeundefined
            Coffee @Phaedrux
            @phaedrux THANKS !!!
            • resamundefined
              resam
              @SnowCrash did you follow all the recent Firmware releases?
              As far as I can tall, all the picks you listed are already implemented to some degree.
              @dc42 as this threads continues to grow and grow, I would recommend closing it, and opening a fresh one after 2.0 and 1.21.1 is released.
              SnowCrashundefined 1 Reply Last reply Reply Quote 1
                SnowCrash @resam
                @resam said in Firmware wishlist and priorities for Duet WiFi and Duet Ethernet:
                Thanks @resam! That's great news 🙂
                To your question, I haven't been following the recent firmware releases for the simple reason that I only got my DuetWifi a short while ago and it already had the latest firmware already installed.
                However, I'm definitely planning on doing so in the future.
                • kenblu24undefined
                  kenblu24
                  1 & 2, 6, 8, 3
                  resamundefined 1 Reply Last reply Reply Quote 0
                  • resamundefined
                    resam @kenblu24
                    @kenblu24 1, 6, 8, and 3 are already done. Please read the release notes of recent firmware updates.
                    2 will probably never make it due to memory & cpu restrictions.
                    kenblu24undefined 1 Reply Last reply Reply Quote 0
                    • kenblu24undefined
                      kenblu24 @resam
                      @resam darn 😞 #2 would have been awesome to have. Sorry, haven't been keeping up with the updates.
                      • denkeundefined
                        denke
                        Can we please add to the wishlist?
                        -Improved motion planning as of:
                        https://forum.duet3d.com/topic/4802/6th-order-jerk-controlled-motion-planning
                        I really hope it will be available for deltas too...
                        -Print resume from a given layer (Maybe the user could set the printhead to the appropriate layer and hit resume) ... From that point the head would go up, heat, (prime?) and continue the print.
                        I know it's possible threw editing the resume file, but this would make it so much easier...
                        Thanks!
                        • BenDieselundefined
                          BenDiesel
                          It would be nice if the wifi would create it's own network if one isn't detected when booted up. And have the name of the network be the name of the machine.
                            Phaedrux Moderator @BenDiesel
                            @bendiesel said in Firmware wishlist and priorities for Duet WiFi and Duet Ethernet:
                            Something like that could be used for initial configuration as well much like other wifi devices. It creates its own access point which you connect to, you enter the wifi network information and reboot. Then continue with configuration afterwards. No need to connect to a PC first via usb or edit files on an SD card.
                            And having it fall back to the same access point mode if the configured network is no longer present would be helpful.
                            • denkeundefined
                              denke
                              Some home automation devices use the same logic, some of them even have a dedicated button which puts them into ap mode, where you can configure the network.
                                It's mostly a security issue. If for some reason the initial connection fails and the Duet goes into AP mode, do you really want anybody to be able to access your Duet?
                                A possible mitigation would be to use a password based on the chip unique ID and to put that password on a sticker attached to the Duet. It could still be inconvenient if your Duet was buried below the bed of a delta printer so you couldn't see the sticker.
                                • denkeundefined
                                  denke
                                  You could use a part of the serial, which could exist on a sticker, and coud be queried threw M122, so it's accessable directly and could be red threw usb in case the panel is buried.
                                  A problem would still exist, if there is a power outage, the duet would boot up much quicker than a WIFI router, so if this functionality is automatic, then it would go to AP mode...
                                  As a workarould for the duet 3, you could add a button on the panel to put it into AP mode
                                  mickey30mundefined 1 Reply Last reply Reply Quote 0
                                  • mickey30mundefined
                                    mickey30m @denke
                                    @denke why? Because you need to set the network one time. Then you can edit it when you want. If there is a security bug someones van take over your machine and do some crazy stuff
                                    I think that something like that puts a lot of effort tot maintain in the firmware. With all the security issues Everyday we have.
                                    Just my 2 cents
                                    • denkeundefined
                                      denke
                                      @mickey30m I don't need this functionality, I just think it would be quite easy to implement, would add value to the product, and would solve all the threads complaining about "cannot setup wifi" just because prontenface switched both essid and psk to uppercase.
                                      As to the security side, almost all wifi routers supplied by ISPs today have a sticker on the side containing the wifi and admin password, and it's not much of a security threat, I suggested the exact same functionality
                                        mickey30m
                                        it is very handy, but i dont know if it is good for the users that are not that technic.
                                        on the other hand, when someone take over you're router the also can control the printer. so why not 😉
                                          BenDiesel
                                          Another way of doing it would be have it on by default. And gave it as a parameter to turn it on or off during set up. Also could put in a delay to have it turn on if network not detected after x number of seconds/minute. And it could have a parameter to check for network every x minuts.
                                          Dose the duet store multiple networks and passwords? I will be taking my printer back and forth between home and school and am lazy enough not to want to set the wifi up each time.
                                            T3P3Tony administrators @BenDiesel
                                            yes it does, multiple SSIDs and passwords can be configured, the Duet connects to the strongest one.
                                            BenDieselundefined 1 Reply Last reply Reply Quote 0
