    My custom D-Bot
    My Duet controlled machine
    19
    59
    17.6k
      Phaedrux Moderator @Coffee
      @coffee Thanks. AMZ3D Red PLA and SpoolWorks Phonebox Red EDGE (PETG). It looks a lot redder in person.
      • jackatom74undefined
        jackatom74
        AWESOME!!!!
        • Dr_Ju_Juundefined
          Dr_Ju_Ju
          Well done✌ , similar to my DBot, but i've gone for the dual z motors. I like your print carriage \ cooling fan parts, have you published them anywhere ?
          I tried a Titan Aero, but just couldn't get it to print nicely, so I've reverted to a normal Titan, combined with a Precision Piezo, which gives great prints.
          Julian,
          Old goat, learning new things….
            Phaedrux Moderator @Dr_Ju_Ju
            @dr_ju_ju Here you go, https://www.thingiverse.com/thing:2849355
            It's not my design but I've made a few variants of it to fit more stepper sizes.
            • Dr_Ju_Juundefined
              Dr_Ju_Ju
              Thank You
              Julian,
              • AS-3D Druckundefined
                AS-3D Druck
                You're D-Bot looks way cleaner than my. 🦆
                Is the 3 Leadscrew System woth it?
                I got 2 with a BLTouch as a probe and i'am not shure if the 2 Leadscrews are not good enough or the Z Probe is crap. 😅
                Best regards
                AS-3D Druck / Andre
                Dougal1957undefined Phaedruxundefined 2 Replies Last reply Reply Quote 1
                  T3P3Tony administrators
                  great looking printer, I like the cable management!
                  • Dougal1957undefined
                    Dougal1957 @AS-3D Druck
                    @as-3d-druck said in My custom D-Bot:
                    the advantage with 3 is that then defines a plane so when setup correctly the bed must always be level when you have just 2 then that is a pivot point.
                    Doug
                      A Former User
                      Phaedrux,
                      Are you planning on releasing any of those custom files for the z carriage?
                      Paul
                        Phaedrux Moderator @AS-3D Druck
                        @as-3d-druck I would say that using 3 lead screws is worth it. It's far easier to get them leveled and lined up. I just lower the bed as far as I can, loosen off the bolts for the mounts of on the frame and the bed and let everything relax and align, then retighten and raise the bed. I run the z motor at 80% of rated current (~1500) and I get no binding or skipped steps top to bottom.
                        I've seen people use 2 screws belted together to keep them in sync, but then you still have to find the balance spot. At the very least adding the front cross bar and wheels keep the bed from bouncing and should help make the sweet spot for balancing the bed a little more forgiving.
                        You could also go another step further and use 3 or 4 independent motors and do auto leveling. But the extra cost and complexity didn't make sense to me.
                        @t3p3tony Thanks, it wasn't always so tidy. A few of the pictures in the gallery show the work in progress wiring and there were times when it looks more like a pile of wires than a printer.
                        @hozza I updated the first post with a list of mods used with links.
                          Phaedrux Moderator @T3P3Tony
                          This post is deleted!
                            Phaedrux Moderator @A Former User
                              A Former User @Phaedrux
                              Brilliant thank you...
                              • Saltypetzundefined
                                Saltypetz
                                https://forum.duet3d.com/topic/5280/need-help-with-x-stop-and-bltouch
                                You were great help and you almost have me there.
                                Thank you so much for your help
                                • Ak Ericundefined
                                  Ak Eric
                                  Looks great. I have a heavily modified C-Bot (D-Bot wasn't around when I made it) and I really dig your z-axis leadscrew setup. Nicely done!
                                    Phaedrux Moderator @Ak Eric
                                    @ak-eric Thanks a lot. I read through your build logs while I was planning out the build. Definitely learned a lot.
                                    • Stealthy_TTundefined
                                      Stealthy_TT
                                      Love the build. This is my next build, But I wont be ordering the kit, I cant seem to find a D-bot thing on Thingiverse, I did see your Thing on there and will be using it. Is there a thing with all the files that need to be printed? My plan is something like a 22x22x24 build index, don't need it but why not haha.
                                        Phaedrux Moderator @Stealthy_TT
                                        @stealthy_tt here's the stock DBot thing https://www.thingiverse.com/thing:1001065
                                        And here is the thing with all the mod files for the z-axis setup I used. https://www.thingiverse.com/thing:2651649
                                        Stealthy_TTundefined 1 Reply Last reply Reply Quote 0
                                          Stealthy_TT @Phaedrux
                                          @phaedrux Thank you, I couldn’t find it to save my life.
                                          • uncreative1undefined
                                            uncreative1
                                            Thanks for posting this. I am in the process of ordering parts for a new D-Bot build pretty much identical to yours. I have a quick noob question; On the 3-lead screw mod, what GT2 pulleys do I need to achieve the 1:1 ratio for screws and motor? I've ordered these 8/2 lead screws: https://www.amazon.com/gp/product/B017AR5QBS/ref=od_aui_detailpages01?ie=UTF8&psc=1 and these stepper motors: https://www.amazon.com/gp/product/B06ZY9SPWL/ref=od_aui_detailpages01?ie=UTF8&psc=1. Im just new at this and am unsure about the pulleys as there are so many choices.
