    New firmware 2.0RC5 available
    Firmware installation
    23
    88
    12.7k
    • denkeundefined
      denke @dc42
      Yep, about 6-8 times across the duration of about 2 minutes. I opened the debugger on maybe the 4th time I tried it.
      • denkeundefined
        denke
        Also, another strange experience, Not all the gcode files were listed in dwc, and I could not fild any method to turn the page.
        -I selected the sorting method of mtime, newest first, but the most recent prints did not show up.
        -Then selected all entrys, right click, delete.
        -The selected entrys were deleted, and a new set of gcode files appeared containing those most recent I was looking for.
        As if not all the entries were in the list of gcode files, and the sort would only apply to those which were visible.
        • zerspaner_gerdundefined
          zerspaner_gerd @dc42
          @dc42 said in New firmware 2.0RC5 available:
          @zerspaner_gerd said in New firmware 2.0RC5 available:
          These are the last two entries in "Network" (debugging console)
          other problems are you having with 2.0RC5 and DWC 1.21.1 final?
          Thanks,
          Another problem is the DWC with this error (rr_status? Type = 1 in red, see picture above) stops responding.
          Comes between 7 and a maximum of about 30sec.
          There is no message, I only see it in the debugging console.
          I could confirm if I choose a folder, the gcode file is displayed.
          But is that the reason for the DWC problem?
          Should I again downgrade to DWC and RRF 1.21, move gcode, and then try again on 1.21.1 und RC5.
          @denke said in New firmware 2.0RC5 available:
          That sounds exactly like one of my problems!
          Did you try that:
          Wenn Sie also viele GCode-Dateien auf der SD-Karte haben und diese nicht in Verzeichnissen organisieren, werden Sie keine neuen Dateien sehen, die Sie in den DWC-Ordner / gcodes hochladen, obwohl sie vorhanden sind. Die Problemumgehung besteht darin, Unterverzeichnisse zu erstellen und einige der Dateien in sie zu verschieben.
          Board: Duet WiFi 1.03 | Firmware Version: 3.1.1 | WiFi Server Version: 1.23 | Web Interface Version: 3.1.1
          • Dr_Ju_Juundefined
            Dr_Ju_Ju
            Sitting on the 'G-code files' page, while aprint is in progress, I received this error message:
            G-Codes Directory
            Go Up
            Connect to your Duet to display G-Code files
            JavaScript Error
            A JavaScript error has occurred so the web interface has closed the connection to your board. It is recommended to reload the web interface now. If this happens again, please contact the author and share this error message:
            Version: 1.21.1
            Message: uncaught exception: out of memory
            URL:
            Line: 0:0
            Error object: "out of memory"
            Julian,
            Old goat, learning new things….
              dc42 administrators @denke
              See my earlier response, https://forum.duet3d.com/topic/5394/new-firmware-2-0rc5-available/30. There has always been a limit to how many files DWC will display in a single folder, but it's a little lower in release 2.0.
              denkeundefined 1 Reply Last reply Reply Quote 0
                dc42 administrators @Dr_Ju_Ju
                @dr_ju_ju said in New firmware 2.0RC5 available:
                G-Codes Directory
                Go Up
                JavaScript Error
                Version: 1.21.1
                URL:
                Line: 0:0
                That's one for chrishamm.
                • denkeundefined
                  denke @dc42
                  Thanks for the info!
                  A behaviour suggestion if i may:
                  -The sorting could be implemented in the duet fw, not dwc.
                  -The board could send down the first ~25 entries initially (the first 25 of the sorted list), then send the follow-up entries threw page turning or infinite scrolling
                  Or at least a warning that "there are too many files in this directory, not all files are shown".
                    Thanks, I am already in discussions with chrishamm about how to resolve this.
                    denkeundefined 1 Reply Last reply Reply Quote 1
                    • denkeundefined
                      denke @dc42
                      Nice, thanks @dc42 !
                      • 3DOesteundefined
                        3DOeste
                        Hi! I've been testing RC5 since the release date and everything works fine. I was previously on 1.21. I found no bug or anything strange to repport.
                          dc42 administrators @3DOeste
                          @3doeste said in New firmware 2.0RC5 available:
                          Thanks for the feedback!
                          ShadowXundefined 1 Reply Last reply Reply Quote 0
                          • ShadowXundefined
                            ShadowX @dc42
                            I don't know if anyone else have this issue, but with the 1.21.1 web interface, I seem to have a hard time controlling the fan speed in the "Machine Control" tab. If I pull on the slider, it would move over, but when I let go it would bounce back to the previous value. I repeat the same process on IE and Firefox and had the same issues. Sometimes if I double click slowly it would stay, but its a bit annoying.
                            When I move the fans, speed factor or extrusion factor in the "Print Status" tab, I have no problem moving the sliders. The slider in the fan control on the "Print Status" jumps slightly, but nowhere near as often as the "Machine Control" slider.
                            I don't think its related to RC5, but it seems like a problem with the recent updates.
                            Firmware Electronics: Duet WiFi 1.0 or 1.01
                            Firmware Version: 2.0(RTOS)RC5 (2018-05-22b1)
                            WiFi Server Version: 1.21
                            Web Interface Version: 1.21.1
                            Christoph13524undefined 1 Reply Last reply Reply Quote 0
                            • Christoph13524undefined
                              Christoph13524 @ShadowX
                              @shadowx
                              I have the same problems in Safari.
                              It looks like for me this annoying bug got worse in the recent updates.
                              Printing with an UMO+
                              Duet 2 WiFi 1.04
                                zerspaner_gerd
                                @dc42 With your advice, uploading the gcode files works without any problems.
                                The connection problems with DWC are still present.
                                The funny, on the Tablet (also with chrome and Windows10) comes for a long time no mistake.
                                On desktop PC this comes more often.
                                I do not understand that.
                                It seems that the update suspends the web interface but the connection remains.
                                With combination DWC 1.21.1 and RRF 1.21, the dropouts are not present.
                                • sigxcpuundefined
                                  sigxcpu
                                  There are problems with this firmware (upgraded from 1.21, so I don't know if it is 2.0 specific or not).
                                  Uploading a file, creating a directory (through DWC or FTP) is not shown in web UI. I've dumped the traffic between the browser and the Duet and indeed the file list does not show the added entries. If using FTP, they are there. If using M32 directly to print they are there.
                                  Old files on the SD card are shown in DWC, but anything new since 2.0RC5 upgrade is not shown.
                                  sigxcpuundefined dc42undefined 2 Replies Last reply Reply Quote 0
                                  • sigxcpuundefined
                                    sigxcpu @sigxcpu
                                    @sigxcpu said in New firmware 2.0RC5 available:
                                    Example:
                                    Create a folder in gcodes/Raducu named ccc:
                                    T 2018/05/24 22:21:48.056786 192.168.27.125:54849 -> 192.168.27.7:80 [AP] #74
                                    GET /rr_mkdir?dir=0%3A%2Fgcodes%2FRaducu%2Fccc HTTP/1.1.
                                    Host: 192.168.27.7.
                                    Accept-Encoding: gzip, deflate.
                                    Connection: keep-alive.
                                    Accept: application/json, text/javascript, */*; q=0.01.
                                    User-Agent: Mozilla/5.0 (Macintosh; Intel Mac OS X 10_12_0) AppleWebKit/602.2.14 (KHTML, like Gecko) Version/10.0.1 Safari/602.2.14.
                                    Referer: http://192.168.27.7/.
                                    Accept-Language: en-us.
                                    X-Requested-With: XMLHttpRequest.
                                    T 2018/05/24 22:21:48.143654 192.168.27.7:80 -> 192.168.27.125:54849 [AP] #78
                                    HTTP/1.1 200 OK
                                    Cache-Control: no-cache, no-store, must-revalidate
                                    Pragma: no-cache
                                    Expires: 0
                                    Access-Control-Allow-Origin: *
                                    Content-Type: application/json
                                    Content-Length: 9
                                    Connection: close
                                    {"err":0}
                                    Reload shows no ccc entry.
                                    T 2018/05/24 22:21:48.151622 192.168.27.125:54850 -> 192.168.27.7:80 [AP] #87
                                    GET /rr_filelist?dir=0%3A%2Fgcodes%2FRaducu HTTP/1.1.
                                    Host: 192.168.27.7.
                                    T 2018/05/24 22:21:48.168250 192.168.27.7:80 -> 192.168.27.125:54850 [A] #88
                                    HTTP/1.1 200 OK
                                    Pragma: no-cache
                                    Expires: 0
                                    Content-Length: 1992
                                    Connection: close
                                    {"dir":"0:/gcodes/Raducu","files":[{"type":"f","name":"loubie_aria_dragon_PLA.gcode","size":6043030,"date":"2017-04-03T19:10:15"},{"type":"f","name":"spaceShuttle1_PLA.gcode","size":1735511,"date":"2017-04-03T22:55:18"},{"type":"f","name":"2part_-_A_head_ABS.gcode","size":4456480,"date":"2017-04-23T22:04:29"},{"type":"f","name":"nema17_support_PLA.gcode","size":1277492,"date":"2017-04-07T13:03:07"},{"type":"f","name":"belt_support_PLA.gcode","size":911789,"date":"2017-04-07T15:22:11"},{"type":"f","name":"plate_and_pillars_PLA 220 (Sacele).gcode","size":2990130,"date":"2017-04-08T00:29:20"},{"type":"f","name":"robot_pillar_PLA 220 (Sacele).gcode","size":1621129,"date":"2017-04-08T14:13:06"},{"type":"f","name":"2part_-_B_body_ABS.gcode","size":6222247,"date":"2017-04-23T23:01:19"},{"type":"f","name":"Variable_Speed_Gears_-_Main_Gear-1_ABS.gcode","size":9204723,"date":"2017-05-01T10:16:23"},{"type":"f","name":"metal_detector_coil_PLA.gcode","size":1589034,"date":"2017-05-06T20:54:17"},{"type":"d","name":"Spinner","size":0,"date":"2017-05-22T02:26:25"},{"type":"f","name":"Hull_Mk6_ABS.gcode","size":3329265,"date":"2017-05-31T15:23:21"},{"type":"f","name":"Finger_Pad_V2_Twisted_Pins_ABS.gcode","size":958387,"date":"2017-05-15T22:36:15"},{"type":"d"
                                    T 2018/05/24 22:21:48.271859 192.168.27.7:80 -> 192.168.27.125:54850 [AP] #90
                                    ,"name":"Microscop","size":0,"date":"2017-05-19T01:31:00"},{"type":"f","name":"SphericalIrisBox_PLA.gcode","size":11446362,"date":"2017-05-20T21:24:09"},{"type":"f","name":"Jumping_Turtle_PLA.gcode","size":7794056,"date":"2017-08-10T23:55:16"},{"type":"f","name":"Jumping_Turtle_PLA_0.3.gcode","size":4326095,"date":"2017-08-10T23:59:10"},{"type":"f","name":"Spikey_Top_PLA.gcode","size":2177682,"date":"2017-08-22T20:17:24"},{"type":"f","name":"Rocket_Launcher_PLA.gcode","size":5816173,"date":"2017-08-28T17:56:01"},{"type":"f","name":"Rocket_Launcher_10mm.gcode","size":3424444,"date":"2017-08-29T14:46:10"},{"type":"f","name":"2LiterThreads_1fourth_npt_FINS_righted_PET-G.gcode","size":2229123,"date":"2017-08-30T19:36:09"}]}
                                      dc42 administrators @sigxcpu
                                      Please see this response https://forum.duet3d.com/topic/5394/new-firmware-2-0rc5-available/30.
                                      • sigxcpuundefined
                                        sigxcpu
                                        Thank you for the answer.
                                        I've scanned this thread, but missed that.
                                        Is this a permanent issue or we can expect it to be fixed in the future? I don't know the internals, but I assume that the serialization buffer is small. If it is that, can't you simply generate the JSON on the fly (i.e. streaming)?
                                        Another option is to shrink the JSON. On a machine to machine transfer there is no need to repeat type, name, size, date all the time. They can be abbreviated to t n s d, for example.
                                        LE: now that this started me, I dug in the source code.
                                        I see that the big M122 reply is sent at this size:
                                        Content-Length: 2539
                                        My example reply is:
                                        My example with shorted field names is 1739 bytes in size, around 250 bytes smaller.
                                        So there are ~550 bytes that could've taken more files to be displayed.
                                        Also the modified times can be encoded as UNIX timestamps instead of formatted, which will reduce that even further, from 21 bytes to 9 bytes per entry.
                                        We can have a parameter in rr_filelist sent by DWC to request short format and implement a list with all the above mentioned optimizations, so things are backward compatible.
                                        I can take a stab at this, without the buffer size part (M122 is big, filelist is small) because I don't know why you've chosen it to be that way.
                                        This will be for a 2.1 release maybe.
                                          I agree that the protocol is too verbose (I didn't design it) and we are discussing how to fix the issue. Unfortunately it won't be fixed in time for the 2.0 release because the master files are needed tomorrow for SD card duplication.
                                          • sigxcpuundefined
                                            sigxcpu
                                            How do you think this should be integrated?
                                            • create a new command like rr_compactfilelist?dir=xxx
                                            • add a parameter to existing rr_filelist like rr_filelist?dir=xxx&compact=true
