    New firmware 2.0RC5 available
    Firmware installation
    23
    88
    12.7k
      dc42 administrators @3DOeste
      @3doeste said in New firmware 2.0RC5 available:
      Hi! I've been testing RC5 since the release date and everything works fine. I was previously on 1.21. I found no bug or anything strange to repport.
      Thanks for the feedback!
      ShadowXundefined 1 Reply Last reply Reply Quote 0
      • ShadowXundefined
        ShadowX @dc42
        I don't know if anyone else have this issue, but with the 1.21.1 web interface, I seem to have a hard time controlling the fan speed in the "Machine Control" tab. If I pull on the slider, it would move over, but when I let go it would bounce back to the previous value. I repeat the same process on IE and Firefox and had the same issues. Sometimes if I double click slowly it would stay, but its a bit annoying.
        When I move the fans, speed factor or extrusion factor in the "Print Status" tab, I have no problem moving the sliders. The slider in the fan control on the "Print Status" jumps slightly, but nowhere near as often as the "Machine Control" slider.
        I don't think its related to RC5, but it seems like a problem with the recent updates.
        Firmware Electronics: Duet WiFi 1.0 or 1.01
        Firmware Version: 2.0(RTOS)RC5 (2018-05-22b1)
        WiFi Server Version: 1.21
        Web Interface Version: 1.21.1
        Christoph13524undefined 1 Reply Last reply Reply Quote 0
        • Christoph13524undefined
          Christoph13524 @ShadowX
          @shadowx
          I have the same problems in Safari.
          It looks like for me this annoying bug got worse in the recent updates.
          Printing with an UMO+
          Duet 2 WiFi 1.04
          • zerspaner_gerdundefined
            zerspaner_gerd
            @dc42 With your advice, uploading the gcode files works without any problems.
            The connection problems with DWC are still present.
            The funny, on the Tablet (also with chrome and Windows10) comes for a long time no mistake.
            On desktop PC this comes more often.
            I do not understand that.
            It seems that the update suspends the web interface but the connection remains.
            With combination DWC 1.21.1 and RRF 1.21, the dropouts are not present.
            Board: Duet WiFi 1.03 | Firmware Version: 3.1.1 | WiFi Server Version: 1.23 | Web Interface Version: 3.1.1
            • sigxcpuundefined
              sigxcpu
              There are problems with this firmware (upgraded from 1.21, so I don't know if it is 2.0 specific or not).
              Uploading a file, creating a directory (through DWC or FTP) is not shown in web UI. I've dumped the traffic between the browser and the Duet and indeed the file list does not show the added entries. If using FTP, they are there. If using M32 directly to print they are there.
              Old files on the SD card are shown in DWC, but anything new since 2.0RC5 upgrade is not shown.
              sigxcpuundefined dc42undefined 2 Replies Last reply Reply Quote 0
              • sigxcpuundefined
                sigxcpu @sigxcpu
                @sigxcpu said in New firmware 2.0RC5 available:
                Example:
                Create a folder in gcodes/Raducu named ccc:
                T 2018/05/24 22:21:48.056786 192.168.27.125:54849 -> 192.168.27.7:80 [AP] #74
                GET /rr_mkdir?dir=0%3A%2Fgcodes%2FRaducu%2Fccc HTTP/1.1.
                Host: 192.168.27.7.
                Accept-Encoding: gzip, deflate.
                Connection: keep-alive.
                Accept: application/json, text/javascript, */*; q=0.01.
                User-Agent: Mozilla/5.0 (Macintosh; Intel Mac OS X 10_12_0) AppleWebKit/602.2.14 (KHTML, like Gecko) Version/10.0.1 Safari/602.2.14.
                Referer: http://192.168.27.7/.
                Accept-Language: en-us.
                X-Requested-With: XMLHttpRequest.
                T 2018/05/24 22:21:48.143654 192.168.27.7:80 -> 192.168.27.125:54849 [AP] #78
                HTTP/1.1 200 OK
                Cache-Control: no-cache, no-store, must-revalidate
                Pragma: no-cache
                Expires: 0
                Access-Control-Allow-Origin: *
                Content-Type: application/json
                Content-Length: 9
                Connection: close
                {"err":0}
                Reload shows no ccc entry.
                T 2018/05/24 22:21:48.151622 192.168.27.125:54850 -> 192.168.27.7:80 [AP] #87
                GET /rr_filelist?dir=0%3A%2Fgcodes%2FRaducu HTTP/1.1.
                Host: 192.168.27.7.
                T 2018/05/24 22:21:48.168250 192.168.27.7:80 -> 192.168.27.125:54850 [A] #88
                HTTP/1.1 200 OK
                Pragma: no-cache
                Expires: 0
                Content-Length: 1992
                Connection: close
                {"dir":"0:/gcodes/Raducu","files":[{"type":"f","name":"loubie_aria_dragon_PLA.gcode","size":6043030,"date":"2017-04-03T19:10:15"},{"type":"f","name":"spaceShuttle1_PLA.gcode","size":1735511,"date":"2017-04-03T22:55:18"},{"type":"f","name":"2part_-_A_head_ABS.gcode","size":4456480,"date":"2017-04-23T22:04:29"},{"type":"f","name":"nema17_support_PLA.gcode","size":1277492,"date":"2017-04-07T13:03:07"},{"type":"f","name":"belt_support_PLA.gcode","size":911789,"date":"2017-04-07T15:22:11"},{"type":"f","name":"plate_and_pillars_PLA 220 (Sacele).gcode","size":2990130,"date":"2017-04-08T00:29:20"},{"type":"f","name":"robot_pillar_PLA 220 (Sacele).gcode","size":1621129,"date":"2017-04-08T14:13:06"},{"type":"f","name":"2part_-_B_body_ABS.gcode","size":6222247,"date":"2017-04-23T23:01:19"},{"type":"f","name":"Variable_Speed_Gears_-_Main_Gear-1_ABS.gcode","size":9204723,"date":"2017-05-01T10:16:23"},{"type":"f","name":"metal_detector_coil_PLA.gcode","size":1589034,"date":"2017-05-06T20:54:17"},{"type":"d","name":"Spinner","size":0,"date":"2017-05-22T02:26:25"},{"type":"f","name":"Hull_Mk6_ABS.gcode","size":3329265,"date":"2017-05-31T15:23:21"},{"type":"f","name":"Finger_Pad_V2_Twisted_Pins_ABS.gcode","size":958387,"date":"2017-05-15T22:36:15"},{"type":"d"
                T 2018/05/24 22:21:48.271859 192.168.27.7:80 -> 192.168.27.125:54850 [AP] #90
                ,"name":"Microscop","size":0,"date":"2017-05-19T01:31:00"},{"type":"f","name":"SphericalIrisBox_PLA.gcode","size":11446362,"date":"2017-05-20T21:24:09"},{"type":"f","name":"Jumping_Turtle_PLA.gcode","size":7794056,"date":"2017-08-10T23:55:16"},{"type":"f","name":"Jumping_Turtle_PLA_0.3.gcode","size":4326095,"date":"2017-08-10T23:59:10"},{"type":"f","name":"Spikey_Top_PLA.gcode","size":2177682,"date":"2017-08-22T20:17:24"},{"type":"f","name":"Rocket_Launcher_PLA.gcode","size":5816173,"date":"2017-08-28T17:56:01"},{"type":"f","name":"Rocket_Launcher_10mm.gcode","size":3424444,"date":"2017-08-29T14:46:10"},{"type":"f","name":"2LiterThreads_1fourth_npt_FINS_righted_PET-G.gcode","size":2229123,"date":"2017-08-30T19:36:09"}]}
                  dc42 administrators @sigxcpu
                  Please see this response https://forum.duet3d.com/topic/5394/new-firmware-2-0rc5-available/30.
                  • sigxcpuundefined
                    sigxcpu
                    Thank you for the answer.
                    I've scanned this thread, but missed that.
                    Is this a permanent issue or we can expect it to be fixed in the future? I don't know the internals, but I assume that the serialization buffer is small. If it is that, can't you simply generate the JSON on the fly (i.e. streaming)?
                    Another option is to shrink the JSON. On a machine to machine transfer there is no need to repeat type, name, size, date all the time. They can be abbreviated to t n s d, for example.
                    LE: now that this started me, I dug in the source code.
                    I see that the big M122 reply is sent at this size:
                    Content-Length: 2539
                    My example reply is:
                    My example with shorted field names is 1739 bytes in size, around 250 bytes smaller.
                    So there are ~550 bytes that could've taken more files to be displayed.
                    Also the modified times can be encoded as UNIX timestamps instead of formatted, which will reduce that even further, from 21 bytes to 9 bytes per entry.
                    We can have a parameter in rr_filelist sent by DWC to request short format and implement a list with all the above mentioned optimizations, so things are backward compatible.
                    I can take a stab at this, without the buffer size part (M122 is big, filelist is small) because I don't know why you've chosen it to be that way.
                    This will be for a 2.1 release maybe.
                      I agree that the protocol is too verbose (I didn't design it) and we are discussing how to fix the issue. Unfortunately it won't be fixed in time for the 2.0 release because the master files are needed tomorrow for SD card duplication.
                      • sigxcpuundefined
                        sigxcpu
                        How do you think this should be integrated?
                        • create a new command like rr_compactfilelist?dir=xxx
                        • add a parameter to existing rr_filelist like rr_filelist?dir=xxx&compact=true
                        • Synlorundefined
                          Synlor
                          I ran into an issue I have never seen before in the 1 series of firmware. I almost always run prints via Octoprint over the usb serial connection. About 3.5 hours into a print the connection died.
                          I am running firmware 2.0(RTOS)RC5 (2018-05-22b1).
                          Here was the error on the Octoprint terminal:
                          Unexpected error while reading serial port, please consult octoprint.log for details: SerialException: 'device reports readiness to read but returned no data (device disconnected or multiple access on port?)' @ comm.py:_readline:2417
                          In the DWC console it had this:
                          g-code buffer 'serial' length overflow
                          I ran an M122 in the DWC console interface:
                          M122
                          RepRapFirmware for Duet 2 WiFi/Ethernet version 2.0(RTOS)RC5 running on Duet WiFi 1.0 or 1.01 + DueX5
                          Board ID: 08DAM-999TL-MQ4S8-6J9D8-3SJ6N-15B3W
                          Used output buffers: 1 of 20 (10 max)
                          Static ram: 28452
                          Dynamic ram: 96644 of which 16 recycled
                          Exception stack ram used: 380
                          Never used ram: 5580
                          Task NETWORK ready, free stack 420
                          Task DHTSENSOR blocked, free stack 36
                          Task HEAT blocked, free stack 1256
                          Task MAIN running, free stack 3620
                          Last reset 00:04:46 ago, cause: software
                          Last software reset at 2018-05-24 21:58, reason: Assertion failed, spinning module Platform, available RAM 5284 bytes (slot 1)
                          Software reset code 0x0090 HFSR 0x00000000, CFSR 0x00000000, ICSR 0x0041f80e, BFAR 0xe000ed38, SP 0x2001ffb4
                          Stack: 2001e6a0 2001e6d4 00445509 00000000 00000000 00000001 20006c68 20006bf4 00444885 2001e6ec 20006bf4 00000000 00f00000 e000ef34 c0000018 00000003 004449c7 00444738 61000000 b082b430 b33b9d04 b2c96804 41b4f041 3480f444
                          Error status: 0
                          Free file entries: 10
                          SD card 0 detected, interface speed: 12.0MBytes/sec
                          SD card longest block write time: 0.0ms
                          MCU temperature: min 46.6, current 46.7, max 49.5
                          Supply voltage: min 24.0, current 24.2, max 24.4, under voltage events: 0, over voltage events: 0
                          Driver 5: standstill, SG min/max not available
                          Driver 6: standstill, SG min/max not available
                          Driver 7: standstill, SG min/max not available
                          Expansion motor(s) stall indication: yes
                          Date/time: 2018-05-24 22:03:05
                          Slowest main loop (seconds): 0.372014; fastest: 0.000069
                          Hiccups: 0, StepErrors: 0, LaErrors: 0, FreeDm: 240, MinFreeDm 240, MaxWait: 0ms, Underruns: 0, 0
                          Bed compensation in use: none
                          Heater 3 is on, I-accum = 0.0
                          Segments left: 0
                          Movement lock held by null
                          http is idle in state(s) 0
                          telnet is idle in state(s) 0
                          file is idle in state(s) 0
                          serial is idle in state(s) 0
                          aux is idle in state(s) 0
                          daemon is idle in state(s) 0
                          queue is idle in state(s) 0
                          Code queue is empty.
                          === Network ===
                          Responder states: HTTP(4) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0) Telnet(0)
                          HTTP sessions: 1 of 8
                          - WiFi -
                          Network state is running
                          WiFi firmware version 1.21
                          WiFi MAC address 5c:cf:7f:2c:27:2d
                          WiFi Vcc 3.38, reset reason Turned on by main processor
                          WiFi flash size 4194304, free heap 15000
                          WiFi IP address 192.168.2.143
                          WiFi signal strength -65dBm, reconnections 0, sleep mode modem
                          Socket states: 0 5 0 0 0 0 0 0
                          === Expansion ===
                          DueX I2C errors 0
                          I know I am weird to still use Octoprint with a Duet Wifi, but I like the various plugins and record keeping that it provides over the DWC interface. Thanks!
                          • marekzehraundefined
                            marekzehra
                            Running FW: 2.0(RTOS)RC5 (2018-05-22b1), DWC: 1.21.1
                            Tested on small print and no issue occured.
                            Just one glitch on first print (macro with delta calibration, heat and cooldown) when reloading DWC in browser caused "Emergency STOP". But can't reproduce.
                            • Adrian52undefined
                              Adrian52
                              Running 2.0rc5 and dwc121. 1, I have noticed odd behaviour of M122 included in slicer end script. At the end of the print, the M122 report does not appear. The gcode console accepts an M122, but no report. YAT connection accepts M122, and provides a report, but this does not relate to the print, so I guess the original M122 cleared. The DWC console accepts other commands when in the M122 blocked state, and M122 works fine after reset. The effect is seen with S3D and kislicer end scripts.
                              • wilrikerundefined
                                wilriker
                                I just finished a print with a strange message:
                                Error: G1/G2/G3: intermediate position outside machine limits
                                Finished printing file Upgrades/Spool_Holder.gcode, print time was 4h 9m
                                X is now reported as being -253.69
                                My end code is the following
                                G10 P0 R-273.15 S-273.15 ;extruder heater off
                                M140 S-273.15            ;bed heater off
                                G91                      ;relative positioning
                                G1 Z+4 X-20 Y+20 F9000   ;move nozzle away from object
                                G0 S1 X-250              ;move X to the left, so the head is completely out of the way
                                G90                      ;absolute positioning
                                G0 Y190 F5000            ;move bed to the front
                                M84                      ;steppers off
                                Could it be that the G0 S1 X-250 in contrast to a G1 S1 X-250 F3600 that is used in my homex.g is the problem here? AFAIK G0 and G1 are aliases on a cartesian setup.
                                This might not be directly related to RC5 but I never had this message before and I have not modified my end code since updating to RC5.
                                Manuel
                                My Tool Collection
                                  The solutions we are looking at are:
                                  1. DWC to revert to using rr_files instead of rr_filelist.
                                  2. Extend rr_filelist to take a "skip the first N files" parameter, and in the response to return the value of N that should be used to get the next chunk of the file list, with N=0 meaning the list is complete.
                                  Most likely we will implement #2.
                                  sigxcpuundefined 1 Reply Last reply Reply Quote 0
                                    dc42 administrators @wilriker
                                    @wilriker said in New firmware 2.0RC5 available:
                                    M84                      ;steppers off
                                    What printer geometry do you have?
                                    That message is new in RC5 but I don't think it should ever be reported except for G1 moves on SCARA printers and G2 or G3 moves on any type of printer. Maybe it was the G1 Z+4 X-20 Y+20 F9000 command that provoked it? What was the head position prior to executing that command?
                                    A G0 S1 move should behave the same as a G0 S1 move, but I haven't actually tested it.
                                    • wilrikerundefined
                                      wilriker @dc42
                                      @dc42 said in New firmware 2.0RC5 available:
                                      Cartesian
                                      Last movement command in gcode file was
                                      G1 F2250 X16.307 Y159.991 E0.02498 (only followed by a G10 before executing end code)
                                      and Z was at 7.1 at this point.
                                      EDIT:
                                      My limits are
                                      • X: -35..220
                                      • Y: -7..216
                                      • Z: 0..234
                                      Manuel
                                      My Tool Collection
                                      • BMMalundefined
                                        BMMal
                                        I had canceled a print and then started another using the "Upload and Print" button. As the machine started the print, the controller reset. I can repeat this reliably. This does not appear to be an issue if I manually select a file to print though.
                                        Here are the diagnostics after:
                                        RepRapFirmware for Duet 2 WiFi/Ethernet version 2.0(RTOS)RC5 running on Duet Ethernet 1.02 or later + DueX5
                                        Board ID: 08DDM-9FAM2-LW4SD-6JTDL-3S86R-KJW3X
                                        Used output buffers: 1 of 20 (16 max)
                                        Static ram: 28452
                                        Dynamic ram: 96508 of which 0 recycled
                                        Exception stack ram used: 420
                                        Never used ram: 5692
                                        Task NETWORK ready, free stack 332
                                        Task HEAT blocked, free stack 1200
                                        Task MAIN running, free stack 3556
                                        Last reset 00:04:22 ago, cause: software
                                        Last software reset time unknown, reason: User, spinning module GCodes, available RAM 5764 bytes (slot 0)
                                        Software reset code 0x0003 HFSR 0x00000000, CFSR 0x00000000, ICSR 0x0441f000, BFAR 0xe000ed38, SP 0xffffffff
                                        Error status: 0
                                        Free file entries: 8
                                        SD card longest block write time: 0.6ms
                                        MCU temperature: min 25.4, current 26.9, max 27.1
                                        Supply voltage: min 24.0, current 24.2, max 24.5, under voltage events: 0, over voltage events: 0
                                        Driver 0: ok, SG min/max 0/1023
                                        Driver 1: ok, SG min/max 0/1023
                                        Driver 2: standstill, SG min/max 0/642
                                        Driver 3: ok, SG min/max 0/1023
                                        Date/time: 2018-05-25 13:12:03
                                        Slowest main loop (seconds): 0.082818; fastest: 0.000076
                                        Hiccups: 0, StepErrors: 0, LaErrors: 0, FreeDm: 161, MinFreeDm 161, MaxWait: 4294887172ms, Underruns: 0, 0
                                        Scheduled moves: 636, completed moves: 606
                                        Heater 0 is on, I-accum = 0.0
                                        Heater 1 is on, I-accum = 0.2
                                        Segments left: 1
                                        Stack records: 4 allocated, 0 in use
                                        file is doing "G1 X250.665 Y48.861 E0.00098" in state(s) 0
                                        === Network ===
                                        Interface state: 5
                                        === Filament sensors ===
                                        Extruder 0 sensor: ok
                                        === Expansion ===
                                        DueX I2C errors 0
                                        Duet Ethernet - Most likely the most recent Edge firmware
                                        Duet X5
                                        7" Panel Due V2
                                        Cartesian, 4 Nozzles with Flex3Drives, Heated Chamber, Simple Switch Filament Sensing
                                        • Dr_Ju_Juundefined
                                          Dr_Ju_Ju
                                          Not sure what is going on, but I started a print earlier today, the print vcompleted ok, but the web interface disconnected & 'died' in that I could not connect. This happened a few hours after the print had started:
                                          19:55:55
                                          M122
                                          Board ID: 08DGM-95BNL-MGPSJ-6J1F2-3SD6L-9JZHX
                                          Used output buffers: 3 of 20 (8 max)
                                          Static ram: 28452
                                          Dynamic ram: 95460 of which 16 recycled
                                          Exception stack ram used: 332
                                          Never used ram: 6812
                                          Task NETWORK ready, free stack 468
                                          Task MAIN running, free stack 3564
                                          Last reset 00:01:06 ago, cause: reset button or watchdog
                                          Last software reset at 2018-05-24 05:50, reason: User, spinning module GCodes, available RAM 6616 bytes (slot 0)
                                          Error status: 0
                                          MCU temperature: min 45.4, current 46.3, max 46.5
                                          Supply voltage: min 24.1, current 24.3, max 24.4, under voltage events: 0, over voltage events: 0
                                          Date/time: 2018-05-25 19:55:55
                                          Slowest main loop (seconds): 0.008304; fastest: 0.000065
                                          Bed compensation in use: mesh
                                          Heater 1 is on, I-accum = 0.0
                                          Segments left: 0
                                          === Network ===
                                          Interface state: 5
                                          === Expansion ===
                                          19:54:58
                                          Connection established!
                                          09:04:54
                                          Disconnected.
                                          06:55:39
                                          M32 "Panobot/panobot-pan-Top and Bottom-PLA.gcode"
                                          File Panobot/panobot-pan-Top and Bottom-PLA.gcode selected for printing
                                          Julian,
                                          Old goat, learning new things….
                                          • sigxcpuundefined
                                            sigxcpu @dc42
                                            @dc42 OK, I will not take this then 🙂 I've already did it, but I couldn't manage to configure IDE for RTOS branch. Compiled 1.21 without issues, but 2.0 is not compilable yet (used v2-dev branch in both ReprapFirmware & CoreNG, imported DuetWifiSocketServer & FreeRTOS projects in workspace).
