    New firmware 2.0RC5 available
    Firmware installation
    23
    88
    12.7k
    • denkeundefined
      denke
      Also, another strange experience, Not all the gcode files were listed in dwc, and I could not fild any method to turn the page.
      -I selected the sorting method of mtime, newest first, but the most recent prints did not show up.
      -Then selected all entrys, right click, delete.
      -The selected entrys were deleted, and a new set of gcode files appeared containing those most recent I was looking for.
      As if not all the entries were in the list of gcode files, and the sort would only apply to those which were visible.
      • zerspaner_gerdundefined
        zerspaner_gerd @dc42
        @dc42 said in New firmware 2.0RC5 available:
        @zerspaner_gerd said in New firmware 2.0RC5 available:
        These are the last two entries in "Network" (debugging console)
        other problems are you having with 2.0RC5 and DWC 1.21.1 final?
        Thanks,
        Another problem is the DWC with this error (rr_status? Type = 1 in red, see picture above) stops responding.
        Comes between 7 and a maximum of about 30sec.
        There is no message, I only see it in the debugging console.
        I could confirm if I choose a folder, the gcode file is displayed.
        But is that the reason for the DWC problem?
        Should I again downgrade to DWC and RRF 1.21, move gcode, and then try again on 1.21.1 und RC5.
        @denke said in New firmware 2.0RC5 available:
        That sounds exactly like one of my problems!
        Did you try that:
        Wenn Sie also viele GCode-Dateien auf der SD-Karte haben und diese nicht in Verzeichnissen organisieren, werden Sie keine neuen Dateien sehen, die Sie in den DWC-Ordner / gcodes hochladen, obwohl sie vorhanden sind. Die Problemumgehung besteht darin, Unterverzeichnisse zu erstellen und einige der Dateien in sie zu verschieben.
        Board: Duet WiFi 1.03 | Firmware Version: 3.1.1 | WiFi Server Version: 1.23 | Web Interface Version: 3.1.1
        • Dr_Ju_Juundefined
          Dr_Ju_Ju
          Sitting on the 'G-code files' page, while aprint is in progress, I received this error message:
          G-Codes Directory
          Go Up
          Connect to your Duet to display G-Code files
          JavaScript Error
          A JavaScript error has occurred so the web interface has closed the connection to your board. It is recommended to reload the web interface now. If this happens again, please contact the author and share this error message:
          Version: 1.21.1
          Message: uncaught exception: out of memory
          URL:
          Line: 0:0
          Error object: "out of memory"
          Julian,
          Old goat, learning new things….
            dc42 administrators @denke
            See my earlier response, https://forum.duet3d.com/topic/5394/new-firmware-2-0rc5-available/30. There has always been a limit to how many files DWC will display in a single folder, but it's a little lower in release 2.0.
            denkeundefined 1 Reply Last reply Reply Quote 0
              dc42 administrators @Dr_Ju_Ju
              @dr_ju_ju said in New firmware 2.0RC5 available:
              G-Codes Directory
              Go Up
              JavaScript Error
              Version: 1.21.1
              URL:
              Line: 0:0
              That's one for chrishamm.
              • denkeundefined
                denke @dc42
                Thanks for the info!
                A behaviour suggestion if i may:
                -The sorting could be implemented in the duet fw, not dwc.
                -The board could send down the first ~25 entries initially (the first 25 of the sorted list), then send the follow-up entries threw page turning or infinite scrolling
                Or at least a warning that "there are too many files in this directory, not all files are shown".
                  Thanks, I am already in discussions with chrishamm about how to resolve this.
                  denkeundefined 1 Reply Last reply Reply Quote 1
                  • denkeundefined
                    denke @dc42
                    Nice, thanks @dc42 !
                    • 3DOesteundefined
                      3DOeste
                      Hi! I've been testing RC5 since the release date and everything works fine. I was previously on 1.21. I found no bug or anything strange to repport.
                        dc42 administrators @3DOeste
                        @3doeste said in New firmware 2.0RC5 available:
                        Thanks for the feedback!
                        ShadowXundefined 1 Reply Last reply Reply Quote 0
                        • ShadowXundefined
                          ShadowX @dc42
                          I don't know if anyone else have this issue, but with the 1.21.1 web interface, I seem to have a hard time controlling the fan speed in the "Machine Control" tab. If I pull on the slider, it would move over, but when I let go it would bounce back to the previous value. I repeat the same process on IE and Firefox and had the same issues. Sometimes if I double click slowly it would stay, but its a bit annoying.
                          When I move the fans, speed factor or extrusion factor in the "Print Status" tab, I have no problem moving the sliders. The slider in the fan control on the "Print Status" jumps slightly, but nowhere near as often as the "Machine Control" slider.
                          I don't think its related to RC5, but it seems like a problem with the recent updates.
                          Firmware Electronics: Duet WiFi 1.0 or 1.01
                          Firmware Version: 2.0(RTOS)RC5 (2018-05-22b1)
                          WiFi Server Version: 1.21
                          Web Interface Version: 1.21.1
                          Christoph13524undefined 1 Reply Last reply Reply Quote 0
                          • Christoph13524undefined
                            Christoph13524 @ShadowX
                            @shadowx
                            I have the same problems in Safari.
                            It looks like for me this annoying bug got worse in the recent updates.
                            Printing with an UMO+
                            Duet 2 WiFi 1.04
                              zerspaner_gerd
                              @dc42 With your advice, uploading the gcode files works without any problems.
                              The connection problems with DWC are still present.
                              The funny, on the Tablet (also with chrome and Windows10) comes for a long time no mistake.
                              On desktop PC this comes more often.
                              I do not understand that.
                              It seems that the update suspends the web interface but the connection remains.
                              With combination DWC 1.21.1 and RRF 1.21, the dropouts are not present.
                              • sigxcpuundefined
                                sigxcpu
                                There are problems with this firmware (upgraded from 1.21, so I don't know if it is 2.0 specific or not).
                                Uploading a file, creating a directory (through DWC or FTP) is not shown in web UI. I've dumped the traffic between the browser and the Duet and indeed the file list does not show the added entries. If using FTP, they are there. If using M32 directly to print they are there.
                                Old files on the SD card are shown in DWC, but anything new since 2.0RC5 upgrade is not shown.
                                sigxcpuundefined dc42undefined 2 Replies Last reply Reply Quote 0
                                • sigxcpuundefined
                                  sigxcpu @sigxcpu
                                  @sigxcpu said in New firmware 2.0RC5 available:
                                  Example:
                                  Create a folder in gcodes/Raducu named ccc:
                                  T 2018/05/24 22:21:48.056786 192.168.27.125:54849 -> 192.168.27.7:80 [AP] #74
                                  GET /rr_mkdir?dir=0%3A%2Fgcodes%2FRaducu%2Fccc HTTP/1.1.
                                  Host: 192.168.27.7.
                                  Accept-Encoding: gzip, deflate.
                                  Connection: keep-alive.
                                  Accept: application/json, text/javascript, */*; q=0.01.
                                  User-Agent: Mozilla/5.0 (Macintosh; Intel Mac OS X 10_12_0) AppleWebKit/602.2.14 (KHTML, like Gecko) Version/10.0.1 Safari/602.2.14.
                                  Referer: http://192.168.27.7/.
                                  Accept-Language: en-us.
                                  X-Requested-With: XMLHttpRequest.
                                  T 2018/05/24 22:21:48.143654 192.168.27.7:80 -> 192.168.27.125:54849 [AP] #78
                                  HTTP/1.1 200 OK
                                  Cache-Control: no-cache, no-store, must-revalidate
                                  Pragma: no-cache
                                  Expires: 0
                                  Access-Control-Allow-Origin: *
                                  Content-Type: application/json
                                  Content-Length: 9
                                  Connection: close
                                  {"err":0}
                                  Reload shows no ccc entry.
                                  T 2018/05/24 22:21:48.151622 192.168.27.125:54850 -> 192.168.27.7:80 [AP] #87
                                  GET /rr_filelist?dir=0%3A%2Fgcodes%2FRaducu HTTP/1.1.
                                  Host: 192.168.27.7.
                                  T 2018/05/24 22:21:48.168250 192.168.27.7:80 -> 192.168.27.125:54850 [A] #88
                                  HTTP/1.1 200 OK
                                  Pragma: no-cache
                                  Expires: 0
                                  Content-Length: 1992
                                  Connection: close
                                  {"dir":"0:/gcodes/Raducu","files":[{"type":"f","name":"loubie_aria_dragon_PLA.gcode","size":6043030,"date":"2017-04-03T19:10:15"},{"type":"f","name":"spaceShuttle1_PLA.gcode","size":1735511,"date":"2017-04-03T22:55:18"},{"type":"f","name":"2part_-_A_head_ABS.gcode","size":4456480,"date":"2017-04-23T22:04:29"},{"type":"f","name":"nema17_support_PLA.gcode","size":1277492,"date":"2017-04-07T13:03:07"},{"type":"f","name":"belt_support_PLA.gcode","size":911789,"date":"2017-04-07T15:22:11"},{"type":"f","name":"plate_and_pillars_PLA 220 (Sacele).gcode","size":2990130,"date":"2017-04-08T00:29:20"},{"type":"f","name":"robot_pillar_PLA 220 (Sacele).gcode","size":1621129,"date":"2017-04-08T14:13:06"},{"type":"f","name":"2part_-_B_body_ABS.gcode","size":6222247,"date":"2017-04-23T23:01:19"},{"type":"f","name":"Variable_Speed_Gears_-_Main_Gear-1_ABS.gcode","size":9204723,"date":"2017-05-01T10:16:23"},{"type":"f","name":"metal_detector_coil_PLA.gcode","size":1589034,"date":"2017-05-06T20:54:17"},{"type":"d","name":"Spinner","size":0,"date":"2017-05-22T02:26:25"},{"type":"f","name":"Hull_Mk6_ABS.gcode","size":3329265,"date":"2017-05-31T15:23:21"},{"type":"f","name":"Finger_Pad_V2_Twisted_Pins_ABS.gcode","size":958387,"date":"2017-05-15T22:36:15"},{"type":"d"
                                  T 2018/05/24 22:21:48.271859 192.168.27.7:80 -> 192.168.27.125:54850 [AP] #90
                                  ,"name":"Microscop","size":0,"date":"2017-05-19T01:31:00"},{"type":"f","name":"SphericalIrisBox_PLA.gcode","size":11446362,"date":"2017-05-20T21:24:09"},{"type":"f","name":"Jumping_Turtle_PLA.gcode","size":7794056,"date":"2017-08-10T23:55:16"},{"type":"f","name":"Jumping_Turtle_PLA_0.3.gcode","size":4326095,"date":"2017-08-10T23:59:10"},{"type":"f","name":"Spikey_Top_PLA.gcode","size":2177682,"date":"2017-08-22T20:17:24"},{"type":"f","name":"Rocket_Launcher_PLA.gcode","size":5816173,"date":"2017-08-28T17:56:01"},{"type":"f","name":"Rocket_Launcher_10mm.gcode","size":3424444,"date":"2017-08-29T14:46:10"},{"type":"f","name":"2LiterThreads_1fourth_npt_FINS_righted_PET-G.gcode","size":2229123,"date":"2017-08-30T19:36:09"}]}
                                    dc42 administrators @sigxcpu
                                    Please see this response https://forum.duet3d.com/topic/5394/new-firmware-2-0rc5-available/30.
                                    • sigxcpuundefined
                                      sigxcpu
                                      Thank you for the answer.
                                      I've scanned this thread, but missed that.
                                      Is this a permanent issue or we can expect it to be fixed in the future? I don't know the internals, but I assume that the serialization buffer is small. If it is that, can't you simply generate the JSON on the fly (i.e. streaming)?
                                      Another option is to shrink the JSON. On a machine to machine transfer there is no need to repeat type, name, size, date all the time. They can be abbreviated to t n s d, for example.
                                      LE: now that this started me, I dug in the source code.
                                      I see that the big M122 reply is sent at this size:
                                      Content-Length: 2539
                                      My example reply is:
                                      My example with shorted field names is 1739 bytes in size, around 250 bytes smaller.
                                      So there are ~550 bytes that could've taken more files to be displayed.
                                      Also the modified times can be encoded as UNIX timestamps instead of formatted, which will reduce that even further, from 21 bytes to 9 bytes per entry.
                                      We can have a parameter in rr_filelist sent by DWC to request short format and implement a list with all the above mentioned optimizations, so things are backward compatible.
                                      I can take a stab at this, without the buffer size part (M122 is big, filelist is small) because I don't know why you've chosen it to be that way.
                                      This will be for a 2.1 release maybe.
                                        I agree that the protocol is too verbose (I didn't design it) and we are discussing how to fix the issue. Unfortunately it won't be fixed in time for the 2.0 release because the master files are needed tomorrow for SD card duplication.
                                        • sigxcpuundefined
                                          sigxcpu
                                          How do you think this should be integrated?
                                          • create a new command like rr_compactfilelist?dir=xxx
                                          • add a parameter to existing rr_filelist like rr_filelist?dir=xxx&compact=true
                                          • Synlorundefined
                                            Synlor
                                            I ran into an issue I have never seen before in the 1 series of firmware. I almost always run prints via Octoprint over the usb serial connection. About 3.5 hours into a print the connection died.
                                            I am running firmware 2.0(RTOS)RC5 (2018-05-22b1).
                                            Here was the error on the Octoprint terminal:
                                            Unexpected error while reading serial port, please consult octoprint.log for details: SerialException: 'device reports readiness to read but returned no data (device disconnected or multiple access on port?)' @ comm.py:_readline:2417
                                            In the DWC console it had this:
                                            g-code buffer 'serial' length overflow
                                            I ran an M122 in the DWC console interface:
                                            M122
                                            RepRapFirmware for Duet 2 WiFi/Ethernet version 2.0(RTOS)RC5 running on Duet WiFi 1.0 or 1.01 + DueX5
                                            Board ID: 08DAM-999TL-MQ4S8-6J9D8-3SJ6N-15B3W
                                            Used output buffers: 1 of 20 (10 max)
                                            Static ram: 28452
                                            Dynamic ram: 96644 of which 16 recycled
                                            Exception stack ram used: 380
                                            Never used ram: 5580
                                            Task NETWORK ready, free stack 420
                                            Task DHTSENSOR blocked, free stack 36
                                            Task HEAT blocked, free stack 1256
                                            Task MAIN running, free stack 3620
                                            Last reset 00:04:46 ago, cause: software
                                            Last software reset at 2018-05-24 21:58, reason: Assertion failed, spinning module Platform, available RAM 5284 bytes (slot 1)
                                            Software reset code 0x0090 HFSR 0x00000000, CFSR 0x00000000, ICSR 0x0041f80e, BFAR 0xe000ed38, SP 0x2001ffb4
                                            Stack: 2001e6a0 2001e6d4 00445509 00000000 00000000 00000001 20006c68 20006bf4 00444885 2001e6ec 20006bf4 00000000 00f00000 e000ef34 c0000018 00000003 004449c7 00444738 61000000 b082b430 b33b9d04 b2c96804 41b4f041 3480f444
                                            Error status: 0
                                            Free file entries: 10
                                            SD card 0 detected, interface speed: 12.0MBytes/sec
                                            SD card longest block write time: 0.0ms
                                            MCU temperature: min 46.6, current 46.7, max 49.5
                                            Supply voltage: min 24.0, current 24.2, max 24.4, under voltage events: 0, over voltage events: 0
                                            Driver 5: standstill, SG min/max not available
                                            Driver 6: standstill, SG min/max not available
                                            Driver 7: standstill, SG min/max not available
                                            Expansion motor(s) stall indication: yes
                                            Date/time: 2018-05-24 22:03:05
                                            Slowest main loop (seconds): 0.372014; fastest: 0.000069
                                            Hiccups: 0, StepErrors: 0, LaErrors: 0, FreeDm: 240, MinFreeDm 240, MaxWait: 0ms, Underruns: 0, 0
                                            Bed compensation in use: none
                                            Heater 3 is on, I-accum = 0.0
                                            Segments left: 0
                                            Movement lock held by null
                                            http is idle in state(s) 0
                                            telnet is idle in state(s) 0
                                            file is idle in state(s) 0
                                            serial is idle in state(s) 0
                                            aux is idle in state(s) 0
                                            daemon is idle in state(s) 0
                                            queue is idle in state(s) 0
                                            Code queue is empty.
                                            === Network ===
                                            Responder states: HTTP(4) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0) Telnet(0)
                                            HTTP sessions: 1 of 8
                                            - WiFi -
                                            Network state is running
                                            WiFi firmware version 1.21
                                            WiFi MAC address 5c:cf:7f:2c:27:2d
                                            WiFi Vcc 3.38, reset reason Turned on by main processor
                                            WiFi flash size 4194304, free heap 15000
                                            WiFi IP address 192.168.2.143
                                            WiFi signal strength -65dBm, reconnections 0, sleep mode modem
                                            Socket states: 0 5 0 0 0 0 0 0
                                            === Expansion ===
                                            DueX I2C errors 0
                                            I know I am weird to still use Octoprint with a Duet Wifi, but I like the various plugins and record keeping that it provides over the DWC interface. Thanks!
