    Firmware 2.0RC6 and 1.21.1RC6 released
    Firmware installation
    15
    49
    7.6k
    • whosrdaddyundefined
      whosrdaddy
      just finished a 2 hour print on my CoreXY on RC6, encountered no problems.
      • BMMalundefined
        BMMal @dc42
        Are you using firmware retraction in the slicer? If so, please run M207 without parameters and confirm that it says there is zero Z hop configured. Also please provide a sample of the GCode that demonstrates this.
        Do you have mesh bed compensation enabled, and if so, could the "Z hop" be the normal action of bed compensation?
        Yes I am using FW retract. I did confirm that it reported the Z parameter set to 0. I do not use bed compensation.
        I am going to do some more investigation. It looks like some of what I was seeing may have been some how related to the Z shrink compensation in KISSlicer. I need to run with that turned off. I'll report shortly.
        Duet Ethernet - Most likely the most recent Edge firmware
        Duet X5
        7" Panel Due V2
        Cartesian, 4 Nozzles with Flex3Drives, Heated Chamber, Simple Switch Filament Sensing
        • BMMalundefined
          BMMal @dc42
          Looks like the slicer was adding an extra z move due to the z shrink compensation feature in it and it happened to line up with the retraction timing. This isn't a firmware issue. Sorry for the confusion.
          Duet X5
          7" Panel Due V2
            dc42 administrators @SM3D
            @sm3d said in Firmware 2.0RC6 and 1.21.1RC6 released:
            @dc42, I was running 1.21 firmware, 1.21 DWC and 1.21 wifiserver before.
            I upgraded to 2.0RC6 firmware and 1.21.1 DWC and 1.21 wifiserver.
            OK, try clearing the browser cache and reloading DWC.
            • zerspaner_gerdundefined
              zerspaner_gerd
              Unfortunately, I still have an unstable DWC connection.
              It will show "pending" for a long time (about 2 seconds), then "failed" and from then on DWC will not be updated anymore.
              Can this be due to a bad Wi-Fi connection?
              But at 1.21 I had no such problems.
              Here are the diagnostics:
              RepRapFirmware for Duet 2 WiFi/Ethernet version 2.0(RTOS)RC6 running on Duet WiFi 1.02 or later
              Board ID: 08DDM-9FAM2-LW4S4-6J9D2-3S46T-K2T3X
              Used output buffers: 3 of 20 (13 max)
              Static ram: 28380
              Dynamic ram: 96148 of which 0 recycled
              Exception stack ram used: 324
              Never used ram: 6220
              Task NETWORK ready, free stack 404
              Task HEAT blocked, free stack 1200
              Task MAIN running, free stack 3624
              Last reset 00:06:32 ago, cause: software
              Last software reset at 2018-05-30 01:12, reason: User, spinning module GCodes, available RAM 6220 bytes (slot 1)
              Software reset code 0x0003 HFSR 0x00000000, CFSR 0x00000000, ICSR 0x0041f000, BFAR 0xe000ed38, SP 0xffffffff
              Error status: 0
              Free file entries: 10
              SD card longest block write time: 12.7ms
              MCU temperature: min 41.6, current 41.8, max 43.4
              Supply voltage: min 24.5, current 24.6, max 24.8, under voltage events: 0, over voltage events: 0
              Date/time: 2018-05-30 01:19:24
              Slowest loop: 15.74ms; fastest: 0.07ms
              Hiccups: 0, StepErrors: 0, LaErrors: 0, FreeDm: 240, MinFreeDm 240, MaxWait: 0ms, Underruns: 0, 0
              Bed compensation in use: none
              Segments left: 0
              Movement lock held by null
              http is idle in state(s) 0
              telnet is idle in state(s) 0
              file is idle in state(s) 0
              serial is idle in state(s) 0
              aux is idle in state(s) 0
              daemon is idle in state(s) 0
              queue is idle in state(s) 0
              Code queue is empty.
              === Network ===
              Slowest loop: 30.41ms; fastest: 0.01ms
              HTTP sessions: 1 of 8
              - WiFi -
              Network state is running
              WiFi firmware version 1.21
              WiFi MAC address 60:01:94:73:5e:04
              WiFi Vcc 3.38, reset reason Turned on by main processor
              WiFi flash size 4194304, free heap 15688
              WiFi IP address 192.168.188.40
              WiFi signal strength -63dBm, reconnections 0, sleep mode modem
              === Expansion ===
              Maybe this helps.
              What else can I do to debug the error?
              Board: Duet WiFi 1.03 | Firmware Version: 3.1.1 | WiFi Server Version: 1.23 | Web Interface Version: 3.1.1
              • Donpiundefined
                Donpi
                I think I found a little bug.
                (However I'm not sure it'is caused by the new release.)
                It start the load filament macro on Tool 0, and when i see that this was not the correct macro, I shuted down the Duet.
                When powered up again. I can no more right click on Tool 0 to use the filament macro.
                Tool 1 keep working right.
                Bye.
                • SM3Dundefined
                  SM3D
                  @dc42 - As I mentioned yesterday, I could not find my old files in DWC but all the files are present when I access the card via panel due. I am at work so I will clear the cache and reinstall the duet web control when I get back home today.
                  I think somebody mentioned in other thread about fan sliders. I also have the same problem - I am able to slide the fan control by holding the left mouse button but when I leave the button the slider bounces back to previous value. If I start clicking step by step in small increments 5% each time, it works.
                  Cheers,
                  Vasan
                  Good judgement comes from experience but experience comes from bad judgements
                    dc42 administrators @zerspaner_gerd
                    @zerspaner_gerd said in Firmware 2.0RC6 and 1.21.1RC6 released:
                    The WiFi code hasn't changed between 1.21 and 2.0. As your WiFi signal strength is quite low, I suspect there may have been a change in your WiFi environment - in which case, reverting to firmware 1.21 will show the same problem (if the change in the environment is still present).
                    Are you able to reconnect DWC after the error? Have you increased the AJAX retry count in DWC from the default of 1?
                    • boldnutsundefined
                      boldnuts
                      Just ran a 10 hour print with 2.0RC6 with no issue's to report on my Duet Ethernet P3 Steel.
                        @dc42 I updated my firmware just now to 2.0RC6 and it wiped many of my .gcode files. Moreover, I could upload .gcode files without any error but I could not find them in the interface. I also cannot create a folder. Any suggestions?
                        Cheers,
                        Vasan
                        The number of GCode files in a single folder that can be displayed by DWC is lower than before. This was required to fix other issues. So I suspect that the files are all there, just not being displayed. Likewise the new folder you created. The workaround is to move some files into subfolders. If you can't see any subfolders in DWC, you may have to move the SD card to a PC to do this. Alternatively, use the backup facility in DWC to backup the files that you can see, then delete them; then you should be able to see the other files.
                        I'll add this to the upgrade notes.
                        resamundefined 1 Reply Last reply Reply Quote 0
                          dc42 administrators @Donpi
                          @donpi said in Firmware 2.0RC6 and 1.21.1RC6 released:
                          Bye.
                          Does reloading DWC fix this?
                          Donpiundefined 1 Reply Last reply Reply Quote 0
                          • Donpiundefined
                            Donpi @dc42
                            Sorry but what is DWC ?
                              Duet Web Control.
                              • resamundefined
                                resam @dc42
                                @dc42 regarding the number of gcode files per folder and moving them into subfolders:
                                I think there is no g-code to move or rename a file on the SD card.
                                M30 deletes a file - but thats about it...
                                DWC has rr_move and rr_mkdir and rr_delete.
                                Would be nice to add this to the Firmware wishlist.
                                Looking through https://reprap.org/wiki/G-code, it seems no other firmware supports this either...
                                All the "good" numbers around M20-M30 that do things with the SD card are already taken.
                                • Donpiundefined
                                  Donpi @dc42
                                  @dc42 Haha ok
                                  Totaly powering of the Duet does nothing.
                                  But maybe i have a cache problem.
                                  I'll try tonight.
                                  • wilrikerundefined
                                    wilriker
                                    Just finished a 3:45h print successfully with no issues apart from warping - but that is clearly not a problem of the Duet. 😉 👍
                                    Manuel
                                    My Tool Collection
                                      zerspaner_gerd
                                      @dc42 said in Firmware 2.0RC6 and 1.21.1RC6 released:
                                      Yes, I can immediately press on Disconnect Connect.
                                      I have played with this attitude something (up to 2) without change.
                                      It's enough if I downgrade to DWC 1.21
                                      Current combination:
                                      Firmware Version: 2.0 (RTOS) RC6 (2018-05-29b4)
                                      WiFi server version: 1.21
                                      Web Interface Version: 1.21
                                      No noticeable delays. (over an hour) With 1.21.1 it was between 10 seconds and a maximum of 5 minutes.
                                      The debug mode shows the same error, only the difference is, it just continues after the error.
                                      So it seems to me that the cause of DWC is not RFF, right?
                                      I can confirm that, that's exactly the case with me. I already wrote it at RC5.
                                      https://forum.duet3d.com/topic/5394/new-firmware-2-0rc5-available/74
                                      • 3dmntbighkerundefined
                                        3dmntbighker
                                        Installed rc6 in my coreXY and so far so good. I don't have many extra goodies yet to trip it up of course.
                                        Scratch built CoreXY with Maestro
                                        Heavily modified Ender 3 with Maestro
                                        MPCNC work in progress with Duet WiFi
                                        • Danalundefined
                                          Danal
                                          Installed on BFD (Big Fast Delta).
                                          Firmware Name:	RepRapFirmware for Duet 2 WiFi/Ethernet
                                          Firmware Electronics:	Duet WiFi 1.02 or later
                                          Firmware Version:	2.0(RTOS)RC6 (2018-05-29b4)
                                          WiFi Server Version:	1.21
                                          Web Interface Version:	1.21.1
                                          Collected Data
                                          Warm-Up Time	Current Layer Time	Last Layer Time		Print Duration
                                          01m 36s		09s			58s			8h 44m 53s
                                          Estimations
                                          Based on	Filament Usage	File Progress	Layer Time
                                          Time Left	16h 37m 49s	22h 27m 39s	24h 54m 39s
                                          No issues.
                                          • SM3Dundefined
                                            SM3D
                                            @dc42 you are right. I took the SD card and made subfolders to make sure there are less than 25 files in each folder. Now I see all the files in DWC.
                                            I did a small 1 hour print and no issues so far.
                                            Cheers,
                                            Vasan
