Strange Moire like texture on prints [SOLVED]
35
8.1k
    How recently did you get the Titan Aero? Older batches had issues with bearings failing and causing all sorts of intermittent problems. Do you see any rust like residue around the bearings? Does it ever make any clicking or squeaking sounds?
    E3D will send you replacement bearings free of charge if you request them. Made a world of difference for me.
    I would also try increasing your motor currents for X and Y to 85% of their rated max.
    undefined 1 Reply Last reply 1 Jun 2018, 19:20 Reply Quote 0
      rbjam83 @timothyz
      @timothyz Just printed two more cubes, in one X and Y were set to x8 microstepping without interpolation, and on the other, I did the same with the extruder motor. Nothing. No change.
      But I'm reading other threads about more in depth settings of the stepper drivers. I'll try some of those later.
      undefined 1 Reply Last reply 1 Jun 2018, 19:36 Reply Quote 0
        rbjam83 @Phaedrux
        @phaedrux I bought the Titan just three weeks ago from Filastruder. I'ts already from the new batch and the bearings are fine.
          timothyz @rbjam83
          @rbjam83 Have you tried upping the current to 1.4 or even 1.7 as rated? If you don't drive with enough current, I think steppers tend to cog more, you really need current to microstep well. (Anyone correct me if I'm wrong)
          undefined 1 Reply Last reply 1 Jun 2018, 19:41 Reply Quote 0
            Phaedrux Moderator @timothyz
            @timothyz said in Strange Moire like texture on prints:
            I would agree. I get smoothest motion when driving ~85% of rated current as recommended by the setup guide.
            undefined 1 Reply Last reply 1 Jun 2018, 22:08 Reply Quote 0
              rbjam83 @Phaedrux
              @phaedrux FINALLY!!
              It was the motor current that was too low. 0_1527890629019_20180601_185644.jpg
              I never would have guessed it, since I was operating on the "but I print slow" mind set.
              Thanks everybody! It really was quite the learning experience for me.
              Now I can go on with the rest of the tweaks...
              undefined 1 Reply Last reply 2 Jun 2018, 00:18 Reply Quote 3
                3DPMicro @rbjam83
                @rbjam83 that was the my first question
                Looks good now go have fun
                Duet controlled Lathe, micro mill, 3d printer and 1992 Haas VF2 VMC
                undefined 1 Reply Last reply 2 Jun 2018, 19:35 Reply Quote 1
                  I'm glad you solved it. Microstepping is not accurate at low motor currents, because of the interaction between the detent torque and the torque resulting from current.
                  Can you tell us the rated current of the motors, the current you were using originally, and the current that resolved the problem?
                  undefined 1 Reply Last reply 2 Jun 2018, 19:46 Reply Quote 0
                    rbjam83 @3DPMicro
                    @3dpmicro I know. And I did increase the current from 800mA to 1000mA and got no improvement. As I said, I had the wrong mind set about this. I was doing incremental changes when I should have gone bigger.
                      rbjam83 @dc42
                      @dc42 The full spec of the motors are as follows:
                      Steps / mm: 200
                      Rated Voltage: 3.4 V
                      Rated Current: 1700 mA
                      Phase Resistance: 2 ohms
                      Inductance: 3 mH
                      Holding Torque: 40 N
                      Initially I was using 800mA when the issue fist presented. I then increased it to 1000mA to no effect. It was only when I went to 1400mA that the texture disappeared.
                      undefined undefined 2 Replies Last reply 3 Jun 2018, 08:59 Reply Quote 0
                        dc42 administrators @rbjam83
                        @rbjam83 said in Strange Moire like texture on prints [SOLVED]:
                        Steps / mm: 200
                        Inductance: 3 mH
                        Thanks. Do you know whether it was the XY motor currents that made the difference, or the extruder motor current?
                        undefined 1 Reply Last reply 3 Jun 2018, 21:30 Reply Quote 0
                          paboman @rbjam83
                          @rbjam83
                          current was to low for extruder motor or XY Motors ?
                          thx
                            rbjam83 @dc42
                            @dc42 It was the X and Y motors. The extruder motor was ok, it is also a different motor (its the slim 0.9 deg sold by E3D).
                              What brand and model? Just for curiousity.
                              31 out of 35
