    Strange Moire like texture on prints [SOLVED]
    35
    8.1k
    • rbjam83undefined
      rbjam83 @timothyz
      @timothyz Just printed two more cubes, in one X and Y were set to x8 microstepping without interpolation, and on the other, I did the same with the extruder motor. Nothing. No change.
      But I'm reading other threads about more in depth settings of the stepper drivers. I'll try some of those later.
      timothyzundefined 1 Reply Last reply Reply Quote 0
      • rbjam83undefined
        rbjam83 @Phaedrux
        @phaedrux I bought the Titan just three weeks ago from Filastruder. I'ts already from the new batch and the bearings are fine.
        • timothyzundefined
          timothyz @rbjam83
          @rbjam83 Have you tried upping the current to 1.4 or even 1.7 as rated? If you don't drive with enough current, I think steppers tend to cog more, you really need current to microstep well. (Anyone correct me if I'm wrong)
            Phaedrux Moderator @timothyz
            @timothyz said in Strange Moire like texture on prints:
            I would agree. I get smoothest motion when driving ~85% of rated current as recommended by the setup guide.
            rbjam83undefined 1 Reply Last reply Reply Quote 0
            • rbjam83undefined
              rbjam83 @Phaedrux
              @phaedrux FINALLY!!
              It was the motor current that was too low. 0_1527890629019_20180601_185644.jpg
              I never would have guessed it, since I was operating on the "but I print slow" mind set.
              Thanks everybody! It really was quite the learning experience for me.
              Now I can go on with the rest of the tweaks...
              3DPMicroundefined 1 Reply Last reply Reply Quote 3
              • 3DPMicroundefined
                3DPMicro @rbjam83
                @rbjam83 that was the my first question
                Looks good now go have fun
                Duet controlled Jet Lathe, scratch built micro mill and 3d printer. 1992 Haas VF2 VMC retrofit
                rbjam83undefined 1 Reply Last reply Reply Quote 1
                  I'm glad you solved it. Microstepping is not accurate at low motor currents, because of the interaction between the detent torque and the torque resulting from current.
                  Can you tell us the rated current of the motors, the current you were using originally, and the current that resolved the problem?
                  • rbjam83undefined
                    rbjam83 @3DPMicro
                    @3dpmicro I know. And I did increase the current from 800mA to 1000mA and got no improvement. As I said, I had the wrong mind set about this. I was doing incremental changes when I should have gone bigger.
                    • rbjam83undefined
                      rbjam83 @dc42
                      @dc42 The full spec of the motors are as follows:
                      Steps / mm: 200
                      Rated Voltage: 3.4 V
                      Rated Current: 1700 mA
                      Phase Resistance: 2 ohms
                      Inductance: 3 mH
                      Holding Torque: 40 N
                      Initially I was using 800mA when the issue fist presented. I then increased it to 1000mA to no effect. It was only when I went to 1400mA that the texture disappeared.
                      dc42undefined pabomanundefined 2 Replies Last reply Reply Quote 0
                        dc42 administrators @rbjam83
                        @rbjam83 said in Strange Moire like texture on prints [SOLVED]:
                        Steps / mm: 200
                        Inductance: 3 mH
                        Thanks. Do you know whether it was the XY motor currents that made the difference, or the extruder motor current?
                        • pabomanundefined
                          paboman @rbjam83
                          @rbjam83
                          current was to low for extruder motor or XY Motors ?
                          thx
                          • rbjam83undefined
                            rbjam83 @dc42
                            @dc42 It was the X and Y motors. The extruder motor was ok, it is also a different motor (its the slim 0.9 deg sold by E3D).
                              What brand and model? Just for curiousity.
