    It's out! RepRapFirmware 2.0 and 1.21.1 released
    Firmware installation
    25
    81
    15.6k
    • Knaudlerundefined
      Knaudler @T3P3Tony
      @t3p3tony
      hi
      using fan 1 for hotend cooling
      starting at 50 degrees - at 80% (have 15v input)
      sometimes - if I want higher temps - 250 degrees - I push the fan to 90-100%
      or if I need only 190 degrees - in the night, for extra silence - go down to 70% fan, thats ok
      the only sound of the cr10 now are the fans
      would be nice for me to controll all fans
      thanks
      dc42undefined deckingmanundefined 2 Replies Last reply Reply Quote 0
        dc42 administrators @Knaudler
        @knaudler said in It's out! RepRapFirmware 2.0 and 1.21.1 released:
        @t3p3tony
        hi
        thanks
        One workaround would be to create a few macros to set different speeds for the hot end fan.
          deckingman @Knaudler
          @t3p3tony
          hi
          thanks
          I don't know if you are aware of this but you can use thermostatic control to vary the fan speed over a range of temperatures which might achieve what you want automatically when you change the hot end temperature. This is what I do but in my case I just use zero speed below 60 deg C and full speed at 140 and above. In your case you could use for example M106 P1 S255 I0 F250 H1 T50:250 would give (if my maths is correct) zero speed at 50 degrees C and below, 70% speed at 190 deg C and 100% speed at 250 deg C. You might need to play around with those values and there is also an "L" parameter to set the minimum fan speed which you could use to give a non zero speed.
          • Knaudlerundefined
            Knaudler
            thats a good idea
            I will test.
            thanks
            • otaku521undefined
              otaku521
              is it just me... or if you have the web interface running on screen for a long time it is out of sync with the current status (I tell by looking at current z level location)
              I had my big print on for a while and it tells me that I am at Z@ 11.xx but when I refresh the screen it is now changed to Z@17.xx
              I never noticed that with the previous version
              Thanks
              Tony
              zerspaner_gerdundefined 1 Reply Last reply Reply Quote 0
              • SM3Dundefined
                SM3D
                @otaku521 I too face the same problem - web interface shows a different value and I have to refresh the tab to see the current value.
                In previous versions, it is either connected or disconnected. When it is connected, it is in sync with the actual print progress.
                Cheers,
                Vasan
                Good judgement comes from experience but experience comes from bad judgements
                  I have once seen the web interface think it is connected when the printer was not turned on. I think this was after I woke up the PC from sleep mode, but I am not sure. I was using FireFox browser.
                  • wilrikerundefined
                    wilriker @dc42
                    @dc42 said in It's out! RepRapFirmware 2.0 and 1.21.1 released:
                    I can see this more often then not when waking up my PC from sleep and not having manually disconnected DWC before sending the PC to sleep. I am using Vivaldi which basically is the same as Chrome.
                    Manuel
                    My Tool Collection
                    • zerspaner_gerdundefined
                      zerspaner_gerd @otaku521
                      @bmmal said in It's out! RepRapFirmware 2.0 and 1.21.1 released:
                      To expand further on my issue of not getting responses, it seems that DWC is somehow getting out of sync but not disconnecting ie ..........
                      @otaku521 @SM3D
                      I am glad that I am no longer the only one.
                      I have the same problem.
                      The debugging mode shows a difference:
                      DWC 1.21.1 stops after error:
                      DWC 1.21 continues to run after error:
                      https://forum.duet3d.com/topic/5470/firmware-2-0rc6-and-1-21-1rc6-released/13
                      Board: Duet WiFi 1.03 | Firmware Version: 3.1.1 | WiFi Server Version: 1.23 | Web Interface Version: 3.1.1
                      • kraegarundefined
                        kraegar
                        Using it on the Railcore since released, non stop printing while I'm awake, and zero issues.
                        • whosrdaddyundefined
                          whosrdaddy
                          I confirm the issue @zerspaner_gerd is seeing, have sometimes the same problem.
                          Reloading the page resolves the problem.
                          I suspect this is a DWC bug...
                          whosrdaddyundefined 1 Reply Last reply Reply Quote 0
                            whosrdaddy @whosrdaddy
                            @zerspaner_gerd : what is the value of the Ajax retries in your DWC settings?
                              zerspaner_gerd @whosrdaddy
                              @whosrdaddy
                              I tested at times until 4.
                              For a long time I stayed at 2, without change.
                              Am current back to 3 high, and this seems to show an improvement currently.
                              Did you observe the same?
                              • Adamfilipundefined
                                Adamfilip
                                confused which files i need to use to upgrade to V2.0 for my duetwifi
                                lots of files listed
                                Duet2CombinedFirmware.bin
                                5.6 KB DuetDriverFiles.zip
                                356 KB DuetMaestroFirmware.bin
                                552 KB DuetWebControl-1.21.1.zip
                                290 KB DuetWiFiServer.bin
                                57.9 KB iap.bin
                                57.8 KB iap4e.bin
                                58 KB iap4s.bin
                                370 KB RepRapFirmware-Alligator.bin
                                292 KB RepRapFirmware-RADDS.bin
                                373 KB RepRapFirmware.bin
                                335 KB Symbols-CoreNG-SAM3X8E.zip
                                322 KB Symbols-CoreNG-SAM4E8E_RTOS.zip
                                305 KB Symbols-CoreNG-SAM4S_RTOS.zip
                                110 KB Symbols-FreeRTOS-SAM4E.zip
                                81.7 KB Symbols-FreeRTOS-SAM4S.zip
                                1.67 MB Symbols-RepRapFirmware-Duet085.zip
                                1.5 MB Symbols-RepRapFirmware-Duet2_RTOS.zip
                                1.48 MB Symbols-RepRapFirmware-DuetM_RTOS.zip
                                Source code (zip)
                                Source code (tar.gz)
                                Phaedruxundefined dc42undefined 2 Replies Last reply Reply Quote 0
                                  Phaedrux Moderator @Adamfilip
                                  @adamfilip What firmware version are you upgrading from?
                                  Duet2CombinedFirmware.bin should work. If you haven't upgraded in a while you may need to rename it. Check the firmware release notes for the interceding firmware.
                                    dc42 administrators @Adamfilip
                                    @adamfilip said in It's out! RepRapFirmware 2.0 and 1.21.1 released:
                                    Which firmware version are you using at present?
                                      Adamfilip
                                      I tried the current Duet2CombinedFirmware.bin file and installed it. but this is what it says currently
                                      Firmware Electronics: Duet WiFi 1.0 or 1.01
                                      Firmware Version: 1.21RC3 (2018-02-28 build 4)
                                      WiFi Server Version: 1.21
                                      Web Interface Version: 1.21.1
                                        @adamfilip Perhaps this will help? https://forum.duet3d.com/topic/5646/duet-wifi-not-updating-firmware-when-installing-2-0/2
                                        Adamfilipundefined 1 Reply Last reply Reply Quote 0
                                        • FrankNPrinterundefined
                                          FrankNPrinter
                                          Hi Dave been a while.. I see things have really progressed since i pestered you last. LOL I am getting ready to upgrade so i can get wifi working again. Great to see the evolution and addition of ssid and pw btw! I see i have some firmware updates to do as well but it is all a little confusing. i was wondering if someone can give me a cliff notes version of what to do 1st.
                                          Duet wifi running ver 1.18.1 with panel due v 1.15c PC and printer are in opposite ends of house so ideally do this via sd card? What do i do 1st? Also confused about which are the latest versions and where to get them. I am hoping to get my ducks in a row for this weekend . BTW, loved the tidbit from E3D on how great the duet is. I have another printer now, running mks 1.4 board and wow, it is a real dinosaur by comparison. I had no idea how lucky i was with my 1st system. I am currently building a system with 1540 mm X, and 1500 mm Y \ Z so looking forward to the Duet2 as well 🙂
                                            Phaedrux Moderator @FrankNPrinter
                                            @franknprinter Take a good look through this document.
                                            https://duet3d.dozuki.com/Wiki/Installing_and_Updating_Firmware
                                            You'll need to follow the special steps for updating to 1.19 as things changed slightly at that point.
