    Core XY movement issues
    103
    14.2k
      deckingman
      @fxxtoo
      I've just read through all your other posts and all those that you linked to. It does seem to me that it might be the same issue as the other guy, which seemed to be fixed by a replacement board. When you run the tests for each individual motor, it'll tell you that it's turning and in the right direction but not necessary at the right speed. On a CoreXY, for pure X movement both motors turn in the same direction and for pure Y, both motors turn but in opposite directions (or it might be the other way round). Therefore it follows that if one motor turns at a different speed to the other, then there will be some movement in Y when doing pure X, and/or some movement in X when doing pure Y, which is what you are seeing. It seems that you have eliminated any mechanical build inaccuracies. So the cause could be wiring (a bad crimp as one user found in one of those threads), or maybe a faulty board that is causing one motor to skip steps , or a faulty motor (have you tried swapping each A and B motor with say the Z motor?)
      TBH, I don't know how you go about proving to your supplier that it's a faulty board rather than on of the other possible causes. Maybe DC or Tony will step in here. I guess you could email your supplier and point them to this thread. Maybe they'll let you have another board on a sale or return basis?
      FxxTooundefined 2 Replies Last reply Reply Quote 0
      • FxxTooundefined
        FxxToo @deckingman
        @deckingman
        Thanks Ian, I really appreciate you taking the time to help me out. I have been playing with for over a month now. I will contact Filastruder about getting a replacement. again many thanks for helping. I was hoping that DC42 would chime in about this..
        RJ
        • FxxTooundefined
          FxxToo @JoergS5
          @joergs5
          I think you are talking about measuring the length that each belt travels? I could do that. I have done motion control stuff before, mostly with ball screws and Nothing like a coreXY for sure. I am not sure what you mean with the G92, is that not for setting a position, like an offset?
          My problem has been that all of the tests on the docs show that I have everything hooked up. When I give the command G90 X100, the Y position would change about 3 mm. I took everything apart and started over and checked and rechecked the Y and X to be to the best of my skillset, correct. It wasn't until changed (knowing that it was not correct) the M92 settings, did the head move as it should. I think there is an issue in the board, but I am going to post my config.g file as maybe someone can show me if I have goofed up. Thanks for your time in trying to help, I do appreciate it! and the food for thought on the belts.
          rj
          • FxxTooundefined
            FxxToo
            Here is my config.g file (or most of what I have left...I started over)
            ; Configuration file for Duet WiFi
            ; (firmware version 1.20 or newer)
            ; generated by RepRapFirmware Configuration Tool on MODDED 7.12.18
            M111 S0 ;DEBUGGING OFF
            M555 P2 ; Set firmware compatibility to look like MARLIN
            M667 S1 ; Select CoreXY mode
            M550 PRJPRINT ; Set machine name
            ;M552 S1 ; Enable network
            M552 S1 P192.168.1.99 ;SET IP ADDRESS
            M553 P255.255.255.0 ;SET SUBNET MASK
            M586 P0 S1 ; Enable HTTP
            M586 P1 S0 ; Disable FTP
            M586 P2 S0 ; Disable Telnet
            M208 X325 Y415 Z0 S0 ; Set axis maxima
            M208 X0 Y0 Z-600 S1 ; Set axis minima
            ; Drives M569: Set motor driver direction, enable polarity and step pulse timing Parameters
            M569 P0 S1 ; Drive 0 goes FORWARDS Rnnn Driver enable polarity: 0 = active low, 1 = active high (default 0)
            M569 P2 S0 ; Drive 2 goes forwards
            ;M569 P3 S1 ; Drive 3 goes forwards
            M350 X64 Y64 Z128 E16 I1 ; Configure microstepping with interpolation
            ;M92 X80 Y80 Z175 E420 ; Set steps per mm
            ;M92 Y320 Y320 Z1400 E420 ;mod to test 64 micro stepping
            M92 X320 Y319 z1400 E420 ; to test to see if it corrects the speed of both motors
            M566 X600 Y600 Z100 E120 ; Set maximum instantaneous speed changes (mm/min)
            M203 X6000 Y6000 Z4000 E1200 ; Set maximum speeds (mm/min) CHANGED FROM 6000 TO 600 Z NO CHG
            M201 X500 Y500 Z250 E250 ; Set accelerations (mm/s^2)
            M906 X1500 Y1500 Z1500 E800 I40 ; Set motor currents (mA) and motor idle factor in per cent
            M84 S30 ; Set idle timeout
            M574 Z1 S0 ; Set active low endstops
            M574 X1 Y1 Z2 S0
            ;M574 X1 Y1 S3 ; Set endstops controlled by motor load detection
            ;M558 P0 H5 F120 T6000 ; Set Z probe type to switch and the dive height + speeds
            ;G31 P600 X0 Y0 Z2.5 ; Set Z probe trigger value, offset and trigger height
            M557 X15:327.9 Y15:391 S20 ; Define mesh grid
            M140 H1 ; Remap heated bed to heater 1
            M301 H1 P-1 ; Set heater 1 to bang-bang mode
            M305 P0 X200 ; Configure thermocouple for heater 0
            M305 P1 X201 ; Configure thermocouple for heater 1
            M106 P0 S1 I0 F500 H1 T45 ; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned on
            M106 P1 S1 I0 F500 H1 T45 ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
            M106 P2 S1 I0 F500 H1 T45 ; Set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned on
            M563 P0 D0 H0 ; Define tool 0
            ; Automatic power saving
            M911 S10 R11 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; Set voltage thresholds and actions to run on power loss
            pro3dundefined 1 Reply Last reply Reply Quote 0
            • pro3dundefined
              pro3d @FxxToo
              @fxxtoo
              You can not have M92 X different from Y... It will then move wrong Please set those the same and then do the tests
              Valkyrie DIY High Temp 3D Printer
              R&D - Engineering Designer - Viking 3D Printers
              https://vkingprinter.com/
              FxxTooundefined 1 Reply Last reply Reply Quote 0
              • FxxTooundefined
                FxxToo @deckingman
                @deckingman
                No I didn't try swapping the steppers . I bought the steppers new from a local supplier for another job. I stripped them off the previous application to use them on the printer. I have others. I will check out how to swap the motor to another driver.. maybe that will work thanks!
                rj
                • FxxTooundefined
                  FxxToo @pro3d
                  @pro3d
                  Thanks for the reply. I did have them set at being equal. After rebuilding it and making sure that I was parallel and the X was 90 degrees to the Y. I had exactly the same issue as before. If I did the test, it show the correct movement. When I did G90 x100, it would move about 3 mm as well. Which tells me that one motor is Not moving at the same speed as the other. It stopped when I changed the M92 . I am pretty confident that mechanically I am correct. That leaves an issue with the Duet card.
                  rj
                  • JoergS5undefined
                    JoergS5 @FxxToo
                    @fxxtoo First sorry, I meant M92, not G92. I meant resetting to same settings for both steppers.
                    The test I propose is to check the steppers and controllers themself, described in the commissioning part. Belt movement is measuring the stepper moves exactly. Looking at X and Y movements can have several reasons if they are not correct.
                    I had a new idea: your steppers are set to 1.5 A. Please check your steppers if they are types to have 2 A max current or more. If your steppers have less, this can lead to problems.
                    • FxxTooundefined
                      FxxToo @JoergS5
                      @joergs5
                      The steppers nema 23 and are 1.8 amps per phase. I am thinking of how to measure the belt movement. I am taking the motors off to measure the pulley, just in case. I am hoping it is something simple. Thanks!
                      RJ
                      JoergS5undefined pro3dundefined 2 Replies Last reply Reply Quote 0
                      • JoergS5undefined
                        JoergS5 @FxxToo
                        @fxxtoo I thought about the pulleys slipping. This depends on the tension you have on the belts.
                        1.5 A seems to be ok for 1.8 steppers. There is some valuable information in
                        https://duet3d.dozuki.com/Wiki/Choosing_and_connecting_stepper_motors
                        Nema23 has more torque than 17er, so you might not notice the slip.
                        You can file into the shaft, but I prefer nondestructive means like loctite 221.
                        • pro3dundefined
                          pro3d @FxxToo
                          @fxxtoo
                          I think you should up your accel a little. 500 is very low - I dont know if it will help but you could try 1000 as I see you have 10 in jerk
                          • FxxTooundefined
                            FxxToo @pro3d
                            @pro3d
                            Thanks! I have been trying to figure this belt, timing or driver issue out and haven't got into the finer tweaks yet. I will try that.
                            rj
                              deckingman
                              IMO, higher acceleration is likely to make things worse. Start slow, get everything working, then increase speed and acceleration in small steps.
                                deckingman
                                Try this. Do a longish move in X, say 100 mm and measure the Y distance and direction. Then swap the A and B motors (the ones that do X and Y). Repeat the X move. If the movement in Y changes direction, then it's an issue with the motor. At least that will eliminate one variable.
                                • FxxTooundefined
                                  FxxToo @deckingman
                                  @deckingman
                                  Excellent I will try that. I was just starting to pull the Duet board out. Wiil try that right after lunch. and Post the results.
                                  Do you mean remap the motors or physically swap the motors?
                                  Thanks!
                                  RJ
                                    Phaedrux Moderator @FxxToo
                                    @fxxtoo I would think to physically swap them.
                                    • FxxTooundefined
                                      FxxToo @Phaedrux
                                      @phaedrux
                                      Thanks. I just did that. Same thing. ARRGG!
                                      RJ
                                      Phaedruxundefined mrehorstdmdundefined 2 Replies Last reply Reply Quote 0
                                        @fxxtoo at least you know it doesn't follow the motor, so the motors are ok.
                                        • FxxTooundefined
                                          FxxToo @deckingman
                                          @deckingman
                                          just finished swapping the steppers. I left the M92 the same. Before I swapped the motors, I did a G1 x250, the head did not move in the Y. I just did a I did a G1 x250 and Y did not move. So the same as before.
                                          RJ
                                          • FxxTooundefined
                                            FxxToo @Phaedrux
                                            @phaedrux
                                            Thanks. At least that is some progress.
                                            RJ
                                            JoergS5undefined 2 Replies Last reply Reply Quote 0
