    Duet 2 Maestro BLTouch Wiring
    35
    9.1k
    • cabal2000undefined
      cabal2000 @eMadman
      @emadman @dc42
      SO let me get this right
      Black/brown - ground
      Red - 5Volt
      White - Z_PROBE_MOD
      Orange - Z_PROBE_IN
      genghisnico13undefined 1 Reply Last reply Reply Quote 0
      • genghisnico13undefined
        genghisnico13 @cabal2000
        @cabal2000 Almost, I installed mine yesterday:
        Red - 5Volt
        Orange - Z_PROBE_MOD
        White - Z_PROBE_IN
        cabal2000undefined 1 Reply Last reply Reply Quote 0
          cabal2000 @genghisnico13
          @genghisnico13 Thanks brother. Ordered a BLtouch yesterday. Been trying to configure a Orion Piezo for the past week in which I have given up on it, Plan B=BLTouch!!!
            I have updated the instructions for connecting a BLTouch on the wiki.
            cabal2000undefined 2 Replies Last reply Reply Quote 0
              cabal2000 @dc42
              This is what I have in the config.g for ES and Z-Probe
              M574 X1 Y1 S0 ; Set active low endstops
              M574 Z1 S2 ; Set endstops controlled by probe
              M307 H3 A-1 C-1 D-1 ; Disable heater on PWM channel for BLTouch
              M558 P9 H5 F100 T2000 ; Set Z probe type to bltouch and the dive height + speeds
              G31 X0 Y0 Z0 P25 ; Set Z probe trigger value, offset and trigger height
              M557 X15:285 Y15:285 S20 ; Define mesh grid
              Wiring
              Red-5volt
              Orange Z_Probe_MOD
              Black and Brown- Ground
              White - Z_PROBE_IN
              Red light on the BL-Touch just keeps blinking and does nothing.
                cabal2000 @cabal2000
                @cabal2000
                NEVERMIND!!!1
                Got that figured out but now I am getting a "Error: Invalid servo index 3 in M280 command" error when i try a test
                  cabal2000 @dc42
                  @dc42 Is there a PINOUT diagram for the Maestro? I am thinking my issue is I have the wrong pin set in the config files
                    https://duet3d.dozuki.com/Wiki/Duet_2_Maestro_Wiring_Diagram
                    Use pin 64 (P64) in the M280 commands, and don't use I1. You don't need to use M307 to disable a heater.
                      cabal2000 @dc42
                      Thanks DC42. That did the trick. Was getting tired when I was reading up on it all. Very VERY new to duet boards, was using Ramps before this and had that pretty much figured out when I switched over. Maybe its time to start a Maestro only Wiki??
                        A separate Maestro-only wiki would involve a lot of duplication because so many things are the same as for the other Duets. I updated the section on connecting and configuring a BLTouch to cover the Maestro immediately after I posted my previous reply.
                        • gnydickundefined
                          gnydick @dc42
                          @dc42 I can't figure out where the heck the GPIO pins are in the wiring diagram for the maestro. Help!
                            T3P3Tony administrators @gnydick
                            @gnydick GPIO for what?There is a small Expansion header:
                            But the Maestro has less expand ability than the other Duet 2s.
                            • gnydickundefined
                              gnydick @T3P3Tony
                              @t3p3tony I want to hook up LED lights, and I just need a signal pin and ground. I found all of the charts on the wiki, but mapping them to what's in the diagram isn't straight forward. I thought I had figured it all out, but after hooking everything up, nothing happened.I used TWD0/PA3 as logical pin 62. That was after pulling up two web pages side by side to map the wiring diagram to the "using servo, etc." page, to then map to the pinout page. There really should be a mapping of logical pin numbers to exact physical pin on the board.
                                I have added expansion pin names to the table at https://duet3d.dozuki.com/Wiki/Using_servos_and_controlling_unused_IO_pins?#Section_Duet_2_Maestro. It should be able to use the TWD0 pin as GPIO provided that you never issue a M260 or M261 command. Sending either of those commands will configure the pin for I2C, making it unavailable as GPIO.
                                gnydickundefined 1 Reply Last reply Reply Quote 1
                                • gnydickundefined
                                  gnydick @dc42
                                  @dc42 Thanks. The names were very close on the other document, but not exact. This helps greatly! CC: @Shep
                                  • Kenny66undefined
                                    Kenny66
                                    Having an issue now where the BLTouch works fine during G29 S0 bed mesh, but only deploys about half the time when using G30 S-1. Even sometimes right after starting up the machine and homing is done, I run G1 X150 Y150 Z50 and then G30 S-1 and it only deploys about half the time.
                                    This is being used on a printer that has an endstop at Z max and I'm using the BLTouch for Z0 and bed mesh.
                                    In config.g
                                    M574 X2 Y2 Z2 S0
                                    M558 P9 H5 F250 T5000
                                    G31 P25 X-52 Y30 Z1.5
                                    M557 X0:310 Y35:330 S40
                                    In deployprobe.g
                                    M280 P64 S10
                                    In retractprobe.g
                                    M280 P64 S90
                                      Phaedrux Moderator @Kenny66
                                      @kenny66 Try this to see if the problem with dropping the pin is mechanical. Send the servo command to have the probe enter test mode where it just repeatedly deploys and retracts the probe. Let it do that for 15 minutes or so and try and keep an eye on it or at least listen for it. If the pin is getting stuck for some reason eventually it will get stuck while doing this test.
                                      It's not a bad idea to take the pin out of the probe body by removing the set screw at the top and checking everything to see if it's dirty or damaged. Clean it with some soap and water and isopropyl alcohol and reassemble it.
                                      The next culprit would be an intermittently failing wire that could be breaking connection when the print head is moving.
                                      • Kenny66undefined
                                        Kenny66
                                        I've checked those things but the pin drops and retracts fine during a G29 S0 bed mesh. (64 probe points) The only time it's intermittent is doing a G30 S-1. It's really weird.
                                        • Agniusmundefined
                                          Agniusm
                                          Hi. @dc42 , is it possible to wire bltouch using this guide to duet 2 wifi?
                                          Looks like duet wifi has all pins on Z probe connector except 5V:
                                          GROUND
                                          Z_PROBE_MOD
                                          Z_PROBE_IN
                                            Phaedrux Moderator @Agniusm
                                            @Agniusm See here
                                            https://duet3d.dozuki.com/Guide/Ender+3+Pro+and+Duet+Maestro+Guide+Part+5:+Upgrades/54#s228
                                            DIY-O-Sphereundefined 1 Reply Last reply Reply Quote 0
