CoreXYUV with dynamic load\force balancing.
Example setups and prints
10
42
6.0k
    fma
    First, you video of gantry assembling is very cool πŸ˜‰
    And the result is amazing! Well done.
    FrΓ©dΓ©ric
      Wow that worked out great. Have you noticed a difference in surface finish? ie, ringing?
        brunofporto
        That is wonderful............. speechless! πŸ˜„
        Well.... Five extruders, Diamond 5x hot end.... active dampening..... Some 500mm/s printing tests soon? πŸ˜„
        undefined 1 Reply Last reply 4 Oct 2018, 19:58 Reply Quote 0
          brunofporto
          https://www.youtube.com/watch?v=dd5WqmWIRzw came this in mind πŸ˜„ But these buildings dampeners are passive
          undefined 1 Reply Last reply 4 Oct 2018, 19:00 Reply Quote 0
            Phaedrux Moderator @brunofporto
            @brunofporto Except Deckingmans printer is only slightly less massive than that 700 ton ball.
              deckingman
              @brunofporto @Phaedrux Oh trust me, I looked hard at using a tuned mass damper - https://forum.duet3d.com/topic/6677/corexyuvwa before I went down this route.
              Although that one is 700 tons, it's a very small mass compared to the mass of the building. The main reason it wouldn't work in this situation is because they have to be tuned to the resonant frequency of the structure, and in this case rather than a single frequency, there is a very wide range of frequencies due to the nature of print (and non-print) moves.
              A pity because it would have been a very elegant solution (and probably a damned site cheaper). ☺
              @Phaedrux - that's another 12 sets of Delrin wheel kits I've used, bringing the total up to 52 on this printer. 😭
              undefined 1 Reply Last reply 4 Oct 2018, 20:11 Reply Quote 2
                deckingman @brunofporto
                @brunofporto said in CoreXYUV with dynamic load\force balancing.:
                ........................Some 500mm/s printing tests soon? πŸ˜„
                That's probably pushing things a bit but we'll see........
                Hot end pressure is the killer and there is only so much that compensation can do about that. But, I do have a 0.9mm diameter nozzle so...........
                  Phaedrux Moderator @deckingman
                  @deckingman I think your wheel budget might just exceed my whole printer budget.
                  undefined 1 Reply Last reply 4 Oct 2018, 20:19 Reply Quote 0
                    deckingman
                    @brunofporto Actually, I had already used all 10 of the Duet plus Duex5 drivers and didn't much fancy the complexity of adding two external ones. So at the moment it's either 5 extruders, or 3 extruders with dynamic force cancelling but not 5 extruders and dynamic force cancelling together. That will have to wait for gen 3 Duet.
                    But changing from one configuration to another is simply a matter of swapping two motor connectors on the Duex5 and uploading the appropriate configuration files - about 2 minutes max.
                    undefined 1 Reply Last reply 6 Oct 2018, 19:07 Reply Quote 0
                      deckingman @Phaedrux
                      @phaedrux said in CoreXYUV with dynamic load\force balancing.:
                      Gives me nightmares just thinking about it...........
                      undefined 1 Reply Last reply 5 Oct 2018, 11:41 Reply Quote 0
                        wilriker
                        This is great and crazy altogether! I seriously love it! If I had a CoreXY, I guess I would just copy this build because it's so cool - totally independent of necessity. πŸ˜‚
                        Manuel
                        My Tool Collection
                          brunofporto @deckingman
                          @deckingman said in CoreXYUV with dynamic load\force balancing.:
                          We have a saying around here that you should NEVER sum up hobby and/or pleasure budgets πŸ˜„
                            T3P3Tony administrators
                            Great work Ian. I might have an old RAMPs board + some stepsticks lying about that can be used to get you those two other drivers so you can have 5 colour + dynamic load balancing.
                            undefined 1 Reply Last reply 5 Oct 2018, 14:48 Reply Quote 0
                              deckingman @T3P3Tony
                              @t3p3tony said in CoreXYUV with dynamic load\force balancing.:
                              Thanks Tony - that's kind of you. Hold fire for now though. I've a lot other stuff in hand at the moment and 5 colour plus dynamic force balancing isn't high priority just now (given that I can easily have either\or).
                                token47 @deckingman
                                @deckingman silly you, we are watching. πŸ™‚
                                undefined 1 Reply Last reply 6 Oct 2018, 20:00 Reply Quote 0
                                  token47 @deckingman
                                  It's easy to use motors 9 and 10 on the duet2 itself without expansion. They are present on the (unused) LCD connector and it's just a matter of using two external breakout boards. Like on this image:
                                  undefined 1 Reply Last reply 6 Oct 2018, 19:56 Reply Quote 0
                                    deckingman @token47
                                    @token47 Yes I know, - and if you look a couple of posts up, Tony has already offered to supply the hardware. But it's still a fair amount of wiring, and some configuration changes. Both of which would have to be changed yet again when gen 3 Duet comes out. As and when that happens, I'll be gutting out all the wiring so I don't see much point in adding more at this moment in time.
                                    As I have no immediate need to print 5 colours plus use the dynamic force balancing gantry, it's not worth the effort at this time. If I desperately need to print something using 5 colours, all I need do is swap two stepper motor connectors and upload the original config.g and homing files - about 2 minutes max (oh and print it slow by my standards which is still fast by most peoples ☺ )
                                    BTW, starting as we do with drive number 0, it would be drivers 10 and 11, not 9 and 10, as drives 0 to 4 are on the main board and 5 to 9 on the Duex5.
                                      deckingman @token47
                                      @token47 said in CoreXYUV with dynamic load\force balancing.:
                                      Huh??? Has someone crept in to my study and installed a hidden camera that I don't know about? Have the GRU started to take an interest in me? Is that white Transit van parked down the road not what it seems?
                                      undefined 1 Reply Last reply 8 Oct 2018, 07:30 Reply Quote 0
                                        wilriker @deckingman
                                        Depends on what it seems to be. If it seems to be a surveillance van than everything is right. πŸ˜‚
                                        Manuel
                                        My Tool Collection
                                        undefined 1 Reply Last reply 8 Oct 2018, 07:46 Reply Quote 0
                                          deckingman @wilriker
                                          @wilriker said in CoreXYUV with dynamic load\force balancing.:
                                          Dunno. It's got blacked out windows and is bristling with aerials. There is a satellite dish on top too. I guess the occupants are just watching TV. That would explain the blacked out windows. Oh good, I can relax.......☺
                                          We ought to end this here. Much as I like the fun, this isn't really the place...
                                          26 out of 42
