    Firmware 2.02 Release candidate 3 now available
    Firmware installation
    31
    104
    15.7k
    • Danalundefined
      Danal @dc42
      @dc42 said in Firmware 2.02 Release candidate 3 now available:
      • If a Duet WiFi running in client mode loses the connection to the access point, it retries the connection continuously
      YAY!!!
      Installed. No issues at install. Starting a 2day print on a large-ish delta.
      Firmware Name:	RepRapFirmware for Duet 2 WiFi/Ethernet
      Firmware Electronics:	Duet WiFi 1.02 or later
      Firmware Version:	2.02RC3(RTOS) (2018-10-17b2)
      WiFi Server Version:	1.21
      Web Interface Version:	1.22.4-b1
      A couple of hours, working fine, staying connected:
      Warm-Up Time	Current Layer Time	Last Layer Time	Job Duration
      01m 09s	        06m 12s	                n/a	        2h 43m 09s
                           Estimations
      Based on	Filament Usage	File Progress	Layer Time
      Time Left	54h 05m 48s	118h 09m 10s	167h 39m 59s
      kuhnikuehnastundefined 1 Reply Last reply Reply Quote 0
      • stewwyundefined
        stewwy
        Running well. No problems so far, just moved from 0.0 at center back to 0.0 at edge also been playing with extruder mA so I've redone config.g a couple of times. printing well
        • 3DOesteundefined
          3DOeste
          I was going to post in the other thread, but I just finished a 27hr print with 2.02 RC 2 without issues.
            M600: Filament change pause ¶
            This command is supported for compatibility with other firmwares. It behaves like M226 except that if macro file filament-change.g exists in /sys on the SD card, it is run in preference to pause.g.
            That's great. I did a filament swap last night and was wanting something exactly like this.
            pro3dundefined 1 Reply Last reply Reply Quote 0
            • fmaundefined
              fma
              David, what does 'Implemented the object model framework and a few variables' mean? Is it internal dev stuff, or user features?
              Frédéric
                dc42 administrators @fma
                @fma said in Firmware 2.02 Release candidate 3 now available:
                The object model will underpin three features planned for forthcoming firmware revisions: conditions and loops in GCode, more flexible/more readable menu description files for the 12864 display on the Duet Maestro, and user-configurable fields in Duet Web Control. Currently it is only used in two places:
                • The M408 P1 S"filter" command uses it to return values from the object model. It's not fully working because of a bug in the filter parser, however M408 P1 with no filter returns the complete object model. DWC will use a similar mechanism to retrieve values for user-specified fields.
                • In a G- or M-code command, in place of a numeric parameter it should be possible to use an expression such as [gcodes.speedFactor]. But this isn't useful yet because so few variables are included in the object model, also it's not working because of the same bug in the filter parser.
                The next step is to design the object model. Some of the existing module boundaries (gcodes, platform, move etc.) are not right for the object model, so some redesign/refactoring will be needed.
                • Jacotheronundefined
                  Jacotheron
                  Working on my CNC no issues detected.
                  The object model framework seems to be exactly what I sometimes need. Can't wait, and excited that it will be coming (specifically the conditionals and loops).
                  • incogizmoundefined
                    incogizmo
                    Tested with Duet Maestro and LCD, no stutter or slowdowns on high detail areas like previously. A decent torture test seems to have been Slic3r Gyroid infill. Awesome work!
                      dc42 administrators @incogizmo
                      @incogizmo said in Firmware 2.02 Release candidate 3 now available:
                      Thanks for confirming that it is fixed.
                      • fmaundefined
                        fma
                        Amazing! The future looks good ☺
                        Frédéric
                        • kuhnikuehnastundefined
                          kuhnikuehnast @Danal
                          Interesting thing I found about G30:
                          1. If you use:
                          G30 X20 Y20
                          to probe the bed at a specific point, you always have to calculate the offset of the probe, because the coordinates of the nozzle are used.
                          Whereas if you use 2:
                          G30 P0 X20 Y20 H0 Z-99999
                          the offset of the probe is already calculated and the real probe coordinates are used but not the "actually" coordinates of the nozzle
                          1. The H- parameter is still not taken into account when probing. Therefore, I performed a little test:
                          M561                                                    ; delete any bed transformation
                          G1 X45.457 Y8.602 Z10 F15000				; go to probing point on floating bed
                          G30 X45.457 Y8.602 H0 S-1   				; define this point as Z=0
                          G30 X45.457 Y8.602 H5 S-1   				; define this point as Z=0
                          G30 P0 X20 Y20 H0 Z-99999 S-1			        ; probe point P0
                          G30 P0 X20 Y20 H3 Z-99999 S-1			        ; probe point P0
                          G30 P1 X20 Y20 H3 Z-99999 S-1			        ; probe point P1
                          This ended up in the results:
                          20:20:45G32 bed probe heights:, mean nan, deviation from mean nan
                          20:20:42G32 bed probe heights: 0.004, mean 0.004, deviation from mean 0.000
                          20:20:39G32 bed probe heights: 0.007, mean 0.007, deviation from mean nan
                          20:20:36Stopped at height 1.399 mm
                          20:20:31M98 P"0:/macros/Test H-Factor"
                          So as the H-factor differs every probe, the results are all the same... 😕
                          greetings kuhni
                          • Adrian52undefined
                            Adrian52 @dc42
                            @dc42 updated to 2.02rc3 and dwc 1.22.4-b1. Prints fine, but at the end of a print, the 'job status' does not seem to finish properly. Previously the 'print another' option would appear, but now I just get greyed out 'pause job' button. Using a Kossel delta. Can select and print another job from the g-code files tab.
                            Adrian52undefined BlueDustundefined chrishammundefined 3 Replies Last reply Reply Quote 0
                            • Adrian52undefined
                              Adrian52 @Adrian52
                              @adrian52 previous version dwc seems to work fine with rc3
                              • pro3dundefined
                                pro3d @Phaedrux
                                @phaedrux
                                Did you test M600 yet?
                                Does it have pause and park feature or does this have to be macros on the side?
                                /Roy
                                Valkyrie DIY High Temp 3D Printer
                                R&D - Engineering Designer - Viking 3D Printers
                                https://vkingprinter.com/
                                • stewwyundefined
                                  stewwy
                                  Had a problem with the 1.22.4 web interface:
                                  Uploading a file the first time using the upload&print button was fine.
                                  However if I upload it again with the same filename, having made some slicer settings, and having paused and canceled the original it usually failed the re-upload.
                                  Just retrying with 1.22.3 and it works fine
                                    Phaedrux Moderator @pro3d
                                    @pro3d it will run pause.g by default or filament-swap.g if present. So you have to customize the macro to your needs.
                                    • k3lagundefined
                                      k3lag
                                      @dc42 updated to 2.02rc3 and dwc 1.22.4-b1. Since upgrading whenever I scroll down in DWC it automatically scrolls back up a couple seconds later. Very irritating. I'm using Safari 12.0. This hasn't been a problem with any previous version. It seems to print fine however.
                                      dc42undefined Dougal1957undefined zerspaner_gerdundefined fmaundefined paulowiskundefined 5 Replies Last reply Reply Quote 0
                                        dc42 administrators @k3lag
                                        @k3lag said in Firmware 2.02 Release candidate 3 now available:
                                        Which version of DWC were you using previously?
                                        • Dougal1957undefined
                                          Dougal1957 @k3lag
                                          @k3lag I can't reproduce this in Safari 12.0 it appears just fine to me tho I normally use Chrome.
                                          Doug
                                          • zerspaner_gerdundefined
                                            zerspaner_gerd @k3lag
                                            I have that too (with Chrome).
                                            It depends on the screen size, I noticed.
                                            Here are two pictures see scroll bar
                                            jump back (100%)
                                            scrolling works (110%)
                                            But I already had it with the previous version DWC 1.22.1
                                            Board: Duet WiFi 1.03 | Firmware Version: 3.1.1 | WiFi Server Version: 1.23 | Web Interface Version: 3.1.1
