    Firmware 2.02 Release candidate 3 now available
    Firmware installation
    31
    104
    16.3k
      M600: Filament change pause ¶
      This command is supported for compatibility with other firmwares. It behaves like M226 except that if macro file filament-change.g exists in /sys on the SD card, it is run in preference to pause.g.
      That's great. I did a filament swap last night and was wanting something exactly like this.
      pro3dundefined 1 Reply Last reply Reply Quote 0
      • fmaundefined
        fma
        David, what does 'Implemented the object model framework and a few variables' mean? Is it internal dev stuff, or user features?
        Frédéric
          dc42 administrators @fma
          @fma said in Firmware 2.02 Release candidate 3 now available:
          The object model will underpin three features planned for forthcoming firmware revisions: conditions and loops in GCode, more flexible/more readable menu description files for the 12864 display on the Duet Maestro, and user-configurable fields in Duet Web Control. Currently it is only used in two places:
          • The M408 P1 S"filter" command uses it to return values from the object model. It's not fully working because of a bug in the filter parser, however M408 P1 with no filter returns the complete object model. DWC will use a similar mechanism to retrieve values for user-specified fields.
          • In a G- or M-code command, in place of a numeric parameter it should be possible to use an expression such as [gcodes.speedFactor]. But this isn't useful yet because so few variables are included in the object model, also it's not working because of the same bug in the filter parser.
          The next step is to design the object model. Some of the existing module boundaries (gcodes, platform, move etc.) are not right for the object model, so some redesign/refactoring will be needed.
          • Jacotheronundefined
            Jacotheron
            Working on my CNC no issues detected.
            The object model framework seems to be exactly what I sometimes need. Can't wait, and excited that it will be coming (specifically the conditionals and loops).
            • incogizmoundefined
              incogizmo
              Tested with Duet Maestro and LCD, no stutter or slowdowns on high detail areas like previously. A decent torture test seems to have been Slic3r Gyroid infill. Awesome work!
                dc42 administrators @incogizmo
                @incogizmo said in Firmware 2.02 Release candidate 3 now available:
                Thanks for confirming that it is fixed.
                • fmaundefined
                  fma
                  @dc42 said in Firmware 2.02 Release candidate 3 now available:
                  Amazing! The future looks good ☺
                  Frédéric
                  • kuhnikuehnastundefined
                    kuhnikuehnast @Danal
                    Interesting thing I found about G30:
                    1. If you use:
                    G30 X20 Y20
                    to probe the bed at a specific point, you always have to calculate the offset of the probe, because the coordinates of the nozzle are used.
                    Whereas if you use 2:
                    G30 P0 X20 Y20 H0 Z-99999
                    the offset of the probe is already calculated and the real probe coordinates are used but not the "actually" coordinates of the nozzle
                    1. The H- parameter is still not taken into account when probing. Therefore, I performed a little test:
                    M561                                                    ; delete any bed transformation
                    G1 X45.457 Y8.602 Z10 F15000				; go to probing point on floating bed
                    G30 X45.457 Y8.602 H0 S-1   				; define this point as Z=0
                    G30 X45.457 Y8.602 H5 S-1   				; define this point as Z=0
                    G30 P0 X20 Y20 H0 Z-99999 S-1			        ; probe point P0
                    G30 P0 X20 Y20 H3 Z-99999 S-1			        ; probe point P0
                    G30 P1 X20 Y20 H3 Z-99999 S-1			        ; probe point P1
                    This ended up in the results:
                    20:20:45G32 bed probe heights:, mean nan, deviation from mean nan
                    20:20:42G32 bed probe heights: 0.004, mean 0.004, deviation from mean 0.000
                    20:20:39G32 bed probe heights: 0.007, mean 0.007, deviation from mean nan
                    20:20:36Stopped at height 1.399 mm
                    20:20:31M98 P"0:/macros/Test H-Factor"
                    So as the H-factor differs every probe, the results are all the same... 😕
                    greetings kuhni
                    • Adrian52undefined
                      Adrian52 @dc42
                      @dc42 updated to 2.02rc3 and dwc 1.22.4-b1. Prints fine, but at the end of a print, the 'job status' does not seem to finish properly. Previously the 'print another' option would appear, but now I just get greyed out 'pause job' button. Using a Kossel delta. Can select and print another job from the g-code files tab.
                      Adrian52undefined BlueDustundefined chrishammundefined 3 Replies Last reply Reply Quote 0
                      • Adrian52undefined
                        Adrian52 @Adrian52
                        @adrian52 previous version dwc seems to work fine with rc3
                        • pro3dundefined
                          pro3d @Phaedrux
                          @phaedrux
                          Did you test M600 yet?
                          Does it have pause and park feature or does this have to be macros on the side?
                          /Roy
                          Valkyrie DIY High Temp 3D Printer
                          R&D - Engineering Designer - Viking 3D Printers
                          https://vkingprinter.com/
                          • stewwyundefined
                            stewwy
                            Had a problem with the 1.22.4 web interface:
                            Uploading a file the first time using the upload&print button was fine.
                            However if I upload it again with the same filename, having made some slicer settings, and having paused and canceled the original it usually failed the re-upload.
                            Just retrying with 1.22.3 and it works fine
                              Phaedrux Moderator @pro3d
                              @pro3d it will run pause.g by default or filament-swap.g if present. So you have to customize the macro to your needs.
                              • k3lagundefined
                                k3lag
                                @dc42 updated to 2.02rc3 and dwc 1.22.4-b1. Since upgrading whenever I scroll down in DWC it automatically scrolls back up a couple seconds later. Very irritating. I'm using Safari 12.0. This hasn't been a problem with any previous version. It seems to print fine however.
                                dc42undefined Dougal1957undefined zerspaner_gerdundefined fmaundefined paulowiskundefined 5 Replies Last reply Reply Quote 0
                                  dc42 administrators @k3lag
                                  @k3lag said in Firmware 2.02 Release candidate 3 now available:
                                  Which version of DWC were you using previously?
                                  • Dougal1957undefined
                                    Dougal1957 @k3lag
                                    @k3lag I can't reproduce this in Safari 12.0 it appears just fine to me tho I normally use Chrome.
                                    Doug
                                    • zerspaner_gerdundefined
                                      zerspaner_gerd @k3lag
                                      I have that too (with Chrome).
                                      It depends on the screen size, I noticed.
                                      Here are two pictures see scroll bar
                                      jump back (100%)
                                      scrolling works (110%)
                                      But I already had it with the previous version DWC 1.22.1
                                      Board: Duet WiFi 1.03 | Firmware Version: 3.1.1 | WiFi Server Version: 1.23 | Web Interface Version: 3.1.1
                                      • k3lagundefined
                                        k3lag
                                        I was using 1.22 and never noticed a problem. I reverted back to 1.22.3 and it behaved the same as the .4b1. However, I figured out that it is related to 'scaling' the web page. If I use the buttons in my browser to either shrink or enlarge the page the problem occurs. It does not occur if it's not being scaled. It appears others have seen the same thing in other browsers. I don't have this problem with any other web pages that I've noticed.
                                        • BlueDustundefined
                                          BlueDust @Adrian52
                                          @adrian52 I also see that the Print Again is missing, and it is super annoying. I keep testing the same parts after making small adjustments, pause, cancel, print again etc... And this got annoying the first time I printed after updating the firmware and web interface.
                                          Fun, that 3 letter word with "u" in the middle.
                                            I've seen an error message on the PanelDue console that hasn't shown up in the Gcode console.
                                            Wifi reported error: incomplete write wifi reported error: incomplete write It shows up twice like that.
                                            It happened once while trying to download a gcode file from the DWC. The download failed in the browser as well.
                                            Then it happened again uploading a Gcode file. But the gcode file seems to have uploaded correctly.
                                            When I saw the error message I checked the DWC console which was up and running but nothing was there.
                                            I then ran a M122 to see the diagnostics and the DWC reloaded and the printer paused for a second mid print and then carried on. When the DWC reloaded I ran M122 again. This time it worked. But doesn't seem to show anything amiss. Nothing was logged to the PanelDue console.
                                            RepRapFirmware for Duet 2 WiFi/Ethernet version 2.02RC3(RTOS) running on Duet WiFi 1.02 or later
                                            Board ID: 08DDM-9FAM2-LW4SD-6JKF0-3SN6N-T2ZBY
                                            Used output buffers: 1 of 20 (20 max)
                                            Static ram: 28532
                                            Dynamic ram: 98720 of which 12 recycled
                                            Exception stack ram used: 512
                                            Never used ram: 3296
                                            Tasks: NETWORK(ready,328) HEAT(blocked,1184) MAIN(running,3484)
                                            Owned mutexes:
                                            Last reset 02:13:18 ago, cause: power up
                                            Last software reset at 2018-10-15 13:21, reason: User, spinning module GCodes, available RAM 3480 bytes (slot 0)
                                            Error status: 4
                                            Free file entries: 9
                                            MCU temperature: min 44.5, current 44.9, max 45.3
                                            Supply voltage: min 23.8, current 23.9, max 24.1, under voltage events: 0, over voltage events: 0
                                            Driver 0: ok, SG min/max 0/1007
                                            Driver 1: ok, SG min/max 0/254
                                            Driver 2: standstill, SG min/max 0/222
                                            Driver 3: ok, SG min/max 0/240
                                            Date/time: 2018-10-21 16:43:25
                                            Slowest loop: 4.63ms; fastest: 0.07ms
                                            Hiccups: 0, StepErrors: 0, LaErrors: 0, FreeDm: 150, MinFreeDm: 150, MaxWait: 0ms, Underruns: 0, 0
                                            Scheduled moves: 191830, completed moves: 191800
                                            Bed compensation in use: mesh
                                            Heater 0 is on, I-accum = 0.2
                                            Heater 1 is on, I-accum = 0.4
                                            Segments left: 1
                                            Stack records: 3 allocated, 0 in use
                                            Movement lock held by null
                                            http is idle in state(s) 0
                                            telnet is idle in state(s) 0
                                            file is doing "G1 X186.602 Y122.915 E0.08193" in state(s) 0
                                            serial is idle in state(s) 0
                                            aux is idle in state(s) 0
                                            daemon is idle in state(s) 0
                                            queue is idle in state(s) 0
                                            Code queue is empty.
                                            === Network ===
                                            Slowest loop: 182.79ms; fastest: 0.08ms
                                            HTTP sessions: 1 of 8
                                            - WiFi -
                                            Network state is running
                                            WiFi firmware version 1.21
                                            WiFi MAC address 5c:cf:7f:ef:4a:74
                                            WiFi Vcc 3.31, reset reason Turned on by main processor
                                            WiFi flash size 4194304, free heap 13216
                                            WiFi IP address 10.10.0.63
                                            WiFi signal strength -40dBm, reconnections 0, sleep mode modem
                                            Socket states: 0 2 0 0 0 0 0 0
                                            === Expansion ===
