    Pressure advance input from instrument measurement
    21
    3.2k
      Nice work!
      Pressure advance assumes that the extrusion system exhibits elasticity such that there is a compression that is proportional to extrusion rate. Your measurements show that the additional force needed is proportional to extrusion rate. Therefore, if the system behaves as a linear spring (compression proportional to force), then the pressure advance algorithm is correct.
      The elasticity is made up of the compressibility of the filament in the Bowden tube, the stretchiness of the Bowden tube, and the motor elasticity. We can calculate the motor elasticity. Therefore, from your measurements we can calculate the minimum pressure advance needed, which should be close to the actual value needed in a direct drive extruder. the
      nopheadundefined 1 Reply Last reply Reply Quote 0
      • brunofportoundefined
        brunofporto
        Wonderful work!!!!!!
        That is a good work for a scientific/engineering paper!
        How about measure dynamically. From a slow speed, then a sequence of steps.
        It is a simple, static, measurement that could also show extruder/filaments issues that we use the laser sensor today. It is brilliant 😄
        I bet that if I use a spring mechanism then read the displacement using my laser sensor I could also measure force.
        • nopheadundefined
          nophead @dc42
          @dc42 With a small nozzle most of the force is proportional to flow rate but with a larger one, i.e., 0.6mm it is possible to get the force reduce as you increase speed due to the plug at the transition dominating.
          There it also the secondary effect that extruding faster means the plastic is cooler as it flows through the nozzle as it has has less time to heat. Less noticeable with hot ends with a large melt zone.
          It would be great to be able to measure the pressure at the nozzle. Large commercial extruders manage to do that somehow.
          adavidmundefined deckingmanundefined 2 Replies Last reply Reply Quote 0
          • adavidmundefined
            adavidm @nophead
            @nophead said in Pressure advance input from instrument measurement:
            Could something like this work? I dread to think what it costs with the amplifier, readout, etc.
            https://www.kistler.com/?type=669&fid=75071&model=document
            adavidmundefined T3P3Tonyundefined 2 Replies Last reply Reply Quote 0
            • adavidmundefined
              adavidm @adavidm
              @adavidm Or this one, for temp and pressure:
              https://www.kistler.com/en/product/type-6188a/
              • Urbanundefined
                Urban
                @adavidm The sensors you link to has a temperature limit off around 200C due to the fact that they are based on silicon. For higher temperatures GaNi (Gallium Nitride - also used for LED's) sensors would increase the temperature, but a few years ago (hmm... maybe ten years ago) they where only on research level. For some injection moulding machines Mercury is used to carry the pressure to a colder place where they can be measured with the sensors like the ones you linked to.
                • nopheadundefined
                  nophead @Urban
                  @urban how do they account for the relatively large expansion of the mercury due to the heat?
                  I was thinking of perhaps a stiff diaphragm with a plate near to it to form a variable capacitor. The second plate could be attached to something cold with air in between, so nothing to expand with the heat.
                  • Urbanundefined
                    Urban
                    @dc42 As I understand it Pressure Advance is a linear compensation.
                    1. From the first curve one can see that for high temperatures the curve will go through origo. For lower temperatures there would be an offset. Shouldn't Pressure Advance have the form a+bx?
                    2. They are also temperature dependent. Then there need to be a temperature component in the formula as well. I have found that a Bi-Cubic formula can approximate this fairly well.
                    The formula
                    The graph where the doted lines are from the formula and the solid lines from measurement
                    • Urbanundefined
                      Urban
                      @nophead I don't know how thermal expansion is handled, but I suspect it is water cooled. My work was with the GaNi sensors.
                      • Urbanundefined
                        Urban
                        @brunofporto I have done some dynamic measurements, mostly with the intent to study retract.
                        The graph shows three repeated tests. I don't remember the exact settings.
                        1. The graph starts with an S-curve type acceleration. The hotted was primed a few minutes before the test.
                        2. The force build up to close to 8N initially
                        3. The force is reduced once everything gets going
                        4. The retract takes place and the force is reduced to -1 N. This is the holding force and independent of how much you retract it will not be lower. I think this is caused by plastic deformation of warm filament near the heat break. 1N is the force you get for all filaments I have tested.
                        5. The plastic deformation relaxes the force to zero in less than a second.
                        6. The force build quickly after the un-retract when the retract state have been for one second. The un-retract length was the same as the retract length.
                        The waviness you can see in curves from 4-10s (peak to peak around 1 s) are caused by the gears in the planetary gear used in the extruder.
                        The very smal jitter in the curve is the full steps of the stepper. I use a Trinamic with 16 micro steps and interpolation to 256 micro steps.
                        nopheadundefined 1 Reply Last reply Reply Quote 3
                        • gmedlicottundefined
                          gmedlicott
                          Great info on nozzle pressure vs temperature and feed rate. So at 250'C you can feed almost 5x as fast as at 210'C for the same nozzle pressure (with your configuration of course)!
                          On your dynamic graph, a correctly set pressure advance constant will shift the linear rising pressure slope, but won't cure the post-rise excess pressure overshoot I don't think. For that, a different algorithm would be needed.
                          • nopheadundefined
                            nophead @Urban
                            @urban The ripple due to gearing is a shock. I thought involute gears are supposed to be constant velocity. I have often wondered if a timing belt drive would be better as it has less backlash and probably more constant velocity.
                              deckingman @nophead
                              It would be great to be able to measure the pressure at the nozzle. ..................
                              This is something that I have given a lot of thought to over the years. One way would be to use a Diamond hot end but only feed filaments into two of the inputs and fit a transducer into the third input. Sadly, I don't have the resources (financial or otherwise) to pursue this.
                              brunofportoundefined 1 Reply Last reply Reply Quote 0
                                brunofporto @deckingman
                                @deckingman I think the main problem is the price of the pressure sensor that can handle that temperature. It renders this method, of measuring pushing force right at the hotend, a very nice approach!
                                It is measuring pressure after all, with a little friction but... it just needs to correlate with the nozzle area 😄
                                deckingmanundefined nopheadundefined 2 Replies Last reply Reply Quote 0
                                  deckingman @brunofporto
                                  @brunofporto said in Pressure advance input from instrument measurement:
                                  @deckingman I think the main problem is the price of the pressure sensor that can handle that temperature. ..............................................
                                  Yes, absolutely. Many years ago, I worked for an engineering consultancy and we were measuring pressures in real time inside the combustion chambers of internal combustion engines. I think I'd have to sell my house to buy the equipment we were using. ☺
                                  • nopheadundefined
                                    nophead @brunofporto
                                    @brunofporto The problem is it isn't a little friction. I can easily dominate the force with PLA because it is not very viscous but it is very rubbery past its glass transition and creates a lot of friction like a tyre.
                                    If we could measure the pressure in the melt chamber accurately and in real time we could create a servo loop.
                                      brunofporto @nophead
                                      @nophead Sure - a nice masters or phd thesis to go for 😄
                                        T3P3Tony administrators @adavidm
                                        @adavidm the sensor you linked could work for this application in an appropriately modified hotend:
                                        Sensor face exposed to the molten plastic @ <450C but the remainder insulated from the heater block. Only practical for testing but still it could be an option.
                                        • stewwyundefined
                                          stewwy
                                          One way of lowering the temperature would be to fill a heatbreak with very low melting point solder and put a diaphragm of silicone at each end, that would bring the temp down at the measuring point. you would need to work out a correction factor though.
                                          • Wurstkartonundefined Wurstkarton referenced this topic
