    Duex5 Testers
    Hardware wishlist
    42
    76
    12.7k
    • Huguesundefined
      Hugues
      Add me too !
      • mjhall29undefined
        mjhall29
        I'd love to help. Please add me.
        Regards Martin
        • briangilbertundefined
          briangilbert
          Please add me to the list (hopefully having being overseas doesn't mean I miss out) 🙂
          Co-creator of the Zesty Nimble direct drive extruder
          • appjawsundefined
            appjaws
            Yes please a pre production duex5 board will be great.
            Thank you for this offer
            Paul
            appjaws - Core XYUV Duet Ethernet Duex5
            firmware 3.5.0-rc.4 Web Interface 3.5.0-rc.4
            Ormerod 1-converted to laser engraver, Duet wifi
            OpenSCAD version 2024.03.18
            Simplify3D 5.1.2
            • Sparksundefined
              Sparks
              Count me in
              • thevisadundefined
                thevisad
                Count me in, I would love to help
                • croadfeldtundefined
                  croadfeldt
                  I'd be interested, especially if it's possible to use the extra heater channels for 12 volt rgb led control. I see no reason why not other than the firmware shutting down the channels due to bogus thermistor readings.
                    The DueX5 design has 5 additional PWM outputs for fans and LEDs. This is the untried part of the design, so there is a possibility that it won't work properly - which I guess is why Tony didn't mention it in the first post.
                    • Russ Griesundefined
                      Russ Gries
                      If there any any left i also would be interested.
                      One Day At A Time…
                      My Main Research Page:
                      http://rwgresearch.com/open-projects/3d-printing-research/
                        croadfeldt
                        I have another use case that might work well here.
                        One of the FRC teams I mentor for asked me to put together a parts list for a larger 3d printer. Something in the range of 400x200mm. Debating on a larger CoreXY or i3 style…
                        The relevant portion of this is the bed heaters. I am looking at a split bed in a side by side configuration covered in a single PEI sheet. This should allow for a dual zone heated bed. To do this a thermistor would be installed in each side and each bed would be driven separately. This is where the extra heater or PWM channels would be perfect. I understand that the 2nd bed heater would need to have it's own temperature set and that would require a little training.
                        Then again, this should be possible with a standard DuetWifi using the 2nd hot end heater output, driving a SSR or external mosfet setup.
                        • Gregkundefined
                          Gregk
                          Please add me to the list as well - thanks.
                          • capundefined
                            cap
                            hi
                            yes please i got a lot of extra time on my hands just gone part time at work
                            warning brain may explode
                            • Paulhutundefined
                              Paulhut
                              Please add me to the list as well.
                              Thank you.
                              • joestefanoundefined
                                joestefano
                                Add me to the list please. what is the time frame on shipping assuming initial testing goes well?
                                  T3P3Tony administrators
                                  UPDATE:
                                  We will be emailing all those who have expressed interest in the next couple of days (before the end of Tuesday 18 Oct) to let you know the cost and planned delivery schedule. Also you will need to confirm your details so we can raise PayPal invoices.
                                  For those who have expressed interest through the forum only, I will use your forum email address so please check this one if it's not your primary address.
                                  • iDeveloundefined
                                    iDevelo
                                    I'll take one if you have any spare. I will use it to test out IDEX on my surrender build.
                                    • jmjcokeundefined
                                      jmjcoke
                                      I will buy one.
                                      Joshua Coke
                                      Trick Laser Metal Max with Smart Effector
                                      Duet Wifi
                                      Zesty Nimble
                                      Mosaic Pallette+
                                      At work
                                      Renishaw AM250/400/ RenAM500M/500Q Powder Bed Fusion (Metal 3D Printers)
                                      • Adamfilipundefined
                                        Adamfilip
                                        Sign me up.
                                        • mjhall29undefined
                                          mjhall29
                                          Should i have heard anything yet ?
                                          Regards Martin
                                            The email is sitting in my draft folder just waiting to confirm one more detail and it will go out. Hopefully this morning
