    Duex5 Testers
    Hardware wishlist
    42
    76
    12.7k
    • timcurtis67undefined
      timcurtis67
      If there are any left I will buy one.
      • pjr3Dundefined
        pjr3D
        Please add me to the list!
        • Zesty_Lykleundefined
          Zesty_Lykle
          Would love to. But first need to launch the Zesty Nimble.
          This takes all my time at the moment so it would not be fair to those guys that can spend time on it.
          But I am very interested as I am prepping a Diamond nozzle head so need 1 more extruder.
          Also want to start looking into full colour printing so I will need more control.
          Lykle
          Design, make and enjoy life
          Co Creator of the Zesty Nimble
          • BMMalundefined
            BMMal
            I'll sign up for one.
            Duet Ethernet - Most likely the most recent Edge firmware
            Duet X5
            7" Panel Due V2
            Cartesian, 4 Nozzles with Flex3Drives, Heated Chamber, Simple Switch Filament Sensing
            • Neoflerundefined
              Neofler
              Count me for one
              • bbaydarundefined
                bbaydar
                I'd like to help test.
                • Shaoundefined
                  Shao
                  Love to try it out!
                  • johneatoundefined
                    johneato
                    Yes add me to the list
                    • Huguesundefined
                      Hugues
                      Add me too !
                      • mjhall29undefined
                        mjhall29
                        I'd love to help. Please add me.
                        Regards Martin
                        • briangilbertundefined
                          briangilbert
                          Please add me to the list (hopefully having being overseas doesn't mean I miss out) 🙂
                          Co-creator of the Zesty Nimble direct drive extruder
                          • appjawsundefined
                            appjaws
                            Yes please a pre production duex5 board will be great.
                            Thank you for this offer
                            Paul
                            appjaws - Core XYUV Duet Ethernet Duex5
                            firmware 3.5.0-rc.4 Web Interface 3.5.0-rc.4
                            Ormerod 1-converted to laser engraver, Duet wifi
                            OpenSCAD version 2024.03.18
                            Simplify3D 5.1.2
                            • Sparksundefined
                              Sparks
                              Count me in
                              • thevisadundefined
                                thevisad
                                Count me in, I would love to help
                                • croadfeldtundefined
                                  croadfeldt
                                  I'd be interested, especially if it's possible to use the extra heater channels for 12 volt rgb led control. I see no reason why not other than the firmware shutting down the channels due to bogus thermistor readings.
                                    The DueX5 design has 5 additional PWM outputs for fans and LEDs. This is the untried part of the design, so there is a possibility that it won't work properly - which I guess is why Tony didn't mention it in the first post.
                                    • Russ Griesundefined
                                      Russ Gries
                                      If there any any left i also would be interested.
                                      One Day At A Time…
                                      My Main Research Page:
                                      http://rwgresearch.com/open-projects/3d-printing-research/
                                        croadfeldt
                                        I have another use case that might work well here.
                                        One of the FRC teams I mentor for asked me to put together a parts list for a larger 3d printer. Something in the range of 400x200mm. Debating on a larger CoreXY or i3 style…
                                        The relevant portion of this is the bed heaters. I am looking at a split bed in a side by side configuration covered in a single PEI sheet. This should allow for a dual zone heated bed. To do this a thermistor would be installed in each side and each bed would be driven separately. This is where the extra heater or PWM channels would be perfect. I understand that the 2nd bed heater would need to have it's own temperature set and that would require a little training.
                                        Then again, this should be possible with a standard DuetWifi using the 2nd hot end heater output, driving a SSR or external mosfet setup.
                                        • Gregkundefined
                                          Gregk
                                          Please add me to the list as well - thanks.
                                          • capundefined
                                            cap
                                            hi
                                            yes please i got a lot of extra time on my hands just gone part time at work
                                            warning brain may explode
