IDEX Support
60
10.2k
    iDevelo
    My glass is raised 10MM off the alloy bed. The alloy is 550x550 and the glass is 450x450 so i have enough room around the glass to use switches. The switches are on each carriage about 5mm above the nozzle. The carriages move the the edge of the glass and lower down until they hit the switch. I then get the Z reading.
    To level i use a 3 screw system so i only ever have to adjust the front 2 screws. The routine probes the back left corner of the glass and sets Z0. Then the front 2 corners are probed and i get the 2 readings i need to level the bed.
    Now i'm going IDEX i will have a switch on each carriage. It will allow me to level the bed and also set the Z offsets for X/U easily.
      T3P3Tony administrators
      That sounds like a good design. There is not space in the BigBox for that configuration but the probes should allow me to do a similar thing.
      That said if I want to print two objects at once, one per axis, then I need to have the Z height identical for each nozzle
        Alex9779
        @T3P3Tony:
        But I see issues there on the BB because per design the extruders are fixed, you can't adjust them. Well maybe be pushing and pulling but there is no mechanism. So if the offset is too big, lets say more than a layer height, then you will have hard times doing so.
          Can the BB design be changed to provide a height adjustment on one carriage? It would be a shame not to be able to print two identical objects at once. Could one of you raise this on the BigBox forum?
            Alex9779
            Well you could make long holes on one X carriage but that you be a pain to level I think. Best would be to decouple the extruder mounting from the bearing mounts with a part between which can then be height adjusted…
              The design could be modified. one simple way that might work is to make the extruder motor mounting hole elongated. Then start with them slightly loose and rest both hot end tips on the bed in the centre (one the bed is levelled for the X axis). then tighten up ensuring the tips remain incontact with the bed. The one issue with this is one of the titan mounting screws is obscured by the hotend so tighten 3, then remove hotend and tighten last one, replace hotend, and test.
              A complete carriage redesign, that allowed for quick swapping of tools would be good anyway so maybe it could be incorporated into that.
                In fact you would only need to do this for one carriage, which I will do and report how it works
                  Alex9779
                  Yeah it is doable that way, but will hate it ;). Mounting the Titan and have no clicking sound when retracting is not easy and if you wanna move it up and down to level it against another hotend by +-0.05mm… Well I will hate it...
                  But printing multiple copies has no priority for me so I will go with the fixed ones first, I want support prints...
                    Yes its a total hack but It will allow me to get the printer to the point I can print two objects at once - the full carriage redesign will take time.
                      iDevelo
                      Oh so we have the ability to mirror the print and use both extruders at the same time?
                        Yes, see https://duet3d.com/wiki/Configuring_multiple_independent_X-carriages_on_a_Cartesian_printer#Miscellaneous.
                          iDevelo
                          Awesome! I'll make sure both are the same height then 🙂
                            I have a put preliminary build of firmware 1.16 beta 4 at https://dl.dropboxusercontent.com/u/19369680/DuetWiFiFirmware.bin. This supports X axis mapping. So you should now be able to do dual material and mirrored prints on IDEX machines.
                            Some notes:
                            1. I have updated the sample tool change files on the wiki page. In particular, you should not use the G1 R2 commands in the tpost#.g files that I had in the earlier version.
                            2. The reported coordinates are raw, which is deliberate. So the X coordinate shown by DWC is that of the physical X axis regardless of any mapping. Same with M114. If you have a PanelDue and you put the latest 1.15a firmware on it, you can see the U coordinate as well. Eventually, DWC will show the U coordinate as well.
                            3. Make sure that the commands in your homing files that cause the head to back off a few mm after dong course homing have the S2 modifier on them, so that X mapping will not occur on those commands. Similarly, any command you have in homez.h or homeall.g to put the head in a particular position prior to doing a G30 probe should have the S2 modifier to ensure that you put the X carriage there and not the U carriage.
                            4. I suspect there will be a few glitches, such as additional places where X mapping needs to be done. Most likely they will occur when changing between tools. This is something that I can't test fully, because I don't have a dual carriage printer yet.
                              iDevelo
                              Ok I'll keep you updated with my progress and report any issues.
                              I should get some movement this weekend but I doubt I'll beable to print as I'm waiting for a bondtech extruder to arrive. My main aim is to get X/U complete and test homing and bed leveling.
                              I have plenty of time next week to complete this.
                              Thanks for your hard work 🙂
                                I have mirrored printing working on by BigBox IDEX system:
                                I made a few changes to the Wiki so if you are working on this make sure you are using the most up to date examples from there. My configuration does not differ from the example on the wiki other than for steps/mm dimensions and other printer specific stuff.
                                  iDevelo
                                  @T3P3Tony:
                                  https://s9.postimg.org/4rrky828f/Big_Box_IDEX_with_Duet_Wifi.jpg
                                  Well done!
                                    New firmware 1.16 beta 5 with full IDEX support is now on GitHub.
                                      iDevelo
                                      @dc42:
                                      Awesome. I have movement on U!
                                        iDevelo
                                        So far so good!
                                        https://youtu.be/-ALZAlP6Zqw
                                          toshi
                                          I'm begin to design a coreXY printer and this idea of IDEX is an huge improvement I thing and i would like to upgrade with this. Good luck, you are in the good way !
                                          28 out of 60
