    IDEX Support
    60
    10.5k
    • Alex9779undefined
      Alex9779
      Yeah it is doable that way, but will hate it ;). Mounting the Titan and have no clicking sound when retracting is not easy and if you wanna move it up and down to level it against another hotend by +-0.05mm… Well I will hate it...
      But printing multiple copies has no priority for me so I will go with the fixed ones first, I want support prints...
        T3P3Tony administrators
        Yes its a total hack but It will allow me to get the printer to the point I can print two objects at once - the full carriage redesign will take time.
        • iDeveloundefined
          iDevelo
          Oh so we have the ability to mirror the print and use both extruders at the same time?
            Yes, see https://duet3d.com/wiki/Configuring_multiple_independent_X-carriages_on_a_Cartesian_printer#Miscellaneous.
            • iDeveloundefined
              iDevelo
              Awesome! I'll make sure both are the same height then 🙂
                I have a put preliminary build of firmware 1.16 beta 4 at https://dl.dropboxusercontent.com/u/19369680/DuetWiFiFirmware.bin. This supports X axis mapping. So you should now be able to do dual material and mirrored prints on IDEX machines.
                Some notes:
                1. I have updated the sample tool change files on the wiki page. In particular, you should not use the G1 R2 commands in the tpost#.g files that I had in the earlier version.
                2. The reported coordinates are raw, which is deliberate. So the X coordinate shown by DWC is that of the physical X axis regardless of any mapping. Same with M114. If you have a PanelDue and you put the latest 1.15a firmware on it, you can see the U coordinate as well. Eventually, DWC will show the U coordinate as well.
                3. Make sure that the commands in your homing files that cause the head to back off a few mm after dong course homing have the S2 modifier on them, so that X mapping will not occur on those commands. Similarly, any command you have in homez.h or homeall.g to put the head in a particular position prior to doing a G30 probe should have the S2 modifier to ensure that you put the X carriage there and not the U carriage.
                4. I suspect there will be a few glitches, such as additional places where X mapping needs to be done. Most likely they will occur when changing between tools. This is something that I can't test fully, because I don't have a dual carriage printer yet.
                • iDeveloundefined
                  iDevelo
                  Ok I'll keep you updated with my progress and report any issues.
                  I should get some movement this weekend but I doubt I'll beable to print as I'm waiting for a bondtech extruder to arrive. My main aim is to get X/U complete and test homing and bed leveling.
                  I have plenty of time next week to complete this.
                  Thanks for your hard work 🙂
                    I have mirrored printing working on by BigBox IDEX system:
                    I made a few changes to the Wiki so if you are working on this make sure you are using the most up to date examples from there. My configuration does not differ from the example on the wiki other than for steps/mm dimensions and other printer specific stuff.
                    • iDeveloundefined
                      iDevelo
                      @T3P3Tony:
                      https://s9.postimg.org/4rrky828f/Big_Box_IDEX_with_Duet_Wifi.jpg
                      Well done!
                        New firmware 1.16 beta 5 with full IDEX support is now on GitHub.
                        • iDeveloundefined
                          iDevelo
                          @dc42:
                          Awesome. I have movement on U!
                          • iDeveloundefined
                            iDevelo
                            So far so good!
                            https://youtu.be/-ALZAlP6Zqw
                            • toshiundefined
                              toshi
                              I'm begin to design a coreXY printer and this idea of IDEX is an huge improvement I thing and i would like to upgrade with this. Good luck, you are in the good way !
                                Cool idex on corexy? That's a first as far as I am aware!
                                • botundefined
                                  bot
                                  I believe that dc42 came up with the idea of coreidexy on this forum, and harvested some ideas from the reprap forums. It is an idea that certainly has promise.
                                  *not actually a robot
                                    yes but the first implementation 🙂
                                    • chrishammundefined
                                      chrishamm administrators
                                      I've just finished some preliminary work on Duet Web Control to support multiple axes. If you are using an IDEX configuration, you can try out my latest 1.13 beta 2 for Duet WiFi which is available here: https://www.dropbox.com/s/3eaafeubpfhsyge/DuetWebControl-1.13-b2.bin?dl=0. More features are coming soon!
                                      Duet software engineer
                                      • iDeveloundefined
                                        iDevelo
                                        Oh man!
                                        • iDeveloundefined
                                          iDevelo
                                          @chrishamm:
                                          Actually now i can't create Macros. I get an error saying could not update the file.
                                          • iDeveloundefined
                                            iDevelo
                                            And i can't roll back. I uploaded the stable version and it asks if i want to install but it never does. How can i manually install the old version?
