    is it alive or dead
    2.9k
    • yamanundefined
      yaman @dc42
      I think the WIFI module is dead
      right now I make order new controller
      but entail it's arrive can I replace with this
      https://www.amazon.com/gp/product/B07BRQTLZG/ref=ox_sc_act_title_1?smid=A144J8BE3R51KJ&psc=1
      is will work if I change the old one with this ?
        I agree, the WiFi module is dead, because it failed to connect at all the baud rates that were tried. With the right tools (hot air desoldering equipment or very low melting point solder), it can be removed and then replaced. Don't try to remove it without one of those.
        The ESP-12S that you linked to is the correct module. Or you can use the ESP-07S + external antenna, such as https://www.amazon.com/Chironal-ESP8266-ESP-07S-Wireless-Transceiver/dp/B07M7L1CGL/ref=sr_1_12?s=electronics&ie=UTF8&qid=1548322176&sr=1-12&keywords=esp-07s.
        yamanundefined 1 Reply Last reply Reply Quote 0
        • Anidalundefined
          Anidal
          This post is deleted!
          • yamanundefined
            yaman @dc42
            so after this disaster what's better option and ( safer ) to put capacitive sensor NPN 24 v
            end stop E1 or in z probe ?
            • yamanundefined
              yaman
              after search I find this diagram is it will work :
              My power in 24 Vdc so the capacitive sensor NPN 24 v
              blue for +
              brown for -
              black for signal
                That diagram is good if your Duet is PCB revision 1.04. With earlier PCB revisions, we recommend using a diode as described in the wiki page con connecting z probes.
                • yamanundefined
                  yaman
                  • aidarundefined
                    aidar
                    Actually brown is + and blue is ground (-)
                    • yamanundefined
                      yaman
                      yah 😁 I notes that but I was lazy to change the color
                      any way nothing will happen to capacitive sensor it's just will not function .
                      • yamanundefined
                        yaman @aidar
                          The diode goes the other way round.
                          • yamanundefined
                            yaman @dc42
                              That's better.
                              • yamanundefined
                                yaman
                                I have Receive the new control unit and I just connect with yat and put old sd card and all setting work fine
                                also I connect the capacitive sensor and it's work perfect
                                but still have issue with the screen
                                note : can you please put this diagram in you web site so if any one has same capacitive sensor NPN can find some data and not make my mistake !*
                                  Thanks for the diagram. I've added it to the wiki page.
