    is it alive or dead
    2.9k
    • yamanundefined
      yaman
      • yamanundefined
        yaman @dc42
        • yamanundefined
          yaman @dc42
          • yamanundefined
            yaman
            is it disable or not function ?
            • yamanundefined
              yaman
              • yamanundefined
                yaman @dc42
                I think the WIFI module is dead
                right now I make order new controller
                but entail it's arrive can I replace with this
                https://www.amazon.com/gp/product/B07BRQTLZG/ref=ox_sc_act_title_1?smid=A144J8BE3R51KJ&psc=1
                is will work if I change the old one with this ?
                  I agree, the WiFi module is dead, because it failed to connect at all the baud rates that were tried. With the right tools (hot air desoldering equipment or very low melting point solder), it can be removed and then replaced. Don't try to remove it without one of those.
                  The ESP-12S that you linked to is the correct module. Or you can use the ESP-07S + external antenna, such as https://www.amazon.com/Chironal-ESP8266-ESP-07S-Wireless-Transceiver/dp/B07M7L1CGL/ref=sr_1_12?s=electronics&ie=UTF8&qid=1548322176&sr=1-12&keywords=esp-07s.
                  yamanundefined 1 Reply Last reply Reply Quote 0
                  • Anidalundefined
                    Anidal
                    This post is deleted!
                    • yamanundefined
                      yaman @dc42
                      so after this disaster what's better option and ( safer ) to put capacitive sensor NPN 24 v
                      end stop E1 or in z probe ?
                      • yamanundefined
                        yaman
                        after search I find this diagram is it will work :
                        My power in 24 Vdc so the capacitive sensor NPN 24 v
                        blue for +
                        brown for -
                        black for signal
                          That diagram is good if your Duet is PCB revision 1.04. With earlier PCB revisions, we recommend using a diode as described in the wiki page con connecting z probes.
                          • yamanundefined
                            yaman
                            • aidarundefined
                              aidar
                              Actually brown is + and blue is ground (-)
                              • yamanundefined
                                yaman
                                yah 😁 I notes that but I was lazy to change the color
                                any way nothing will happen to capacitive sensor it's just will not function .
                                • yamanundefined
                                  yaman @aidar
                                    The diode goes the other way round.
                                    • yamanundefined
                                      yaman @dc42
                                        That's better.
                                        • yamanundefined
                                          yaman
                                          I have Receive the new control unit and I just connect with yat and put old sd card and all setting work fine
                                          also I connect the capacitive sensor and it's work perfect
                                          but still have issue with the screen
                                          note : can you please put this diagram in you web site so if any one has same capacitive sensor NPN can find some data and not make my mistake !*
                                            Thanks for the diagram. I've added it to the wiki page.
